Matching Speakers to Amps
Postby awdl22125 » Mon Oct 14, 2019 3:06 pm
I have recently purchased a Behringer XR18 and to go with it a second hand KAM KCA 1600 Power Amp. The amp is rated at 2 x 400W RMS @ 4 Ohms & 2 x 250W RMS @ 8 Ohms. My band uses Peavey PA Speakers with tops and subs, the subs are rated at 4 ohms and I think the tops are too. Wouls this be ok in terms of matching?
awdl22125
Re: Matching Speakers to Amps
Postby Sam Spoons » Mon Oct 14, 2019 3:25 pm
Depending on the power handling of the speakers* and providing you have a crossover (usually built into the sub) then yes you'll be fine. If you just connect the sub and top to one channel without a crossover you risk destroying the amp as the net impedance would be 2 ohms.
* between 200 and 400 watts continuous would be ok.
Postby awdl22125 » Mon Oct 14, 2019 3:29 pm
Thanks for the reply, the speakers are 250/500 watts so that should be ok. How would I know if the subs have a built in crossover? they are passive not active
awdl22125
Postby Wonks » Mon Oct 14, 2019 3:34 pm
You could try looking up a spec sheet online for them.
Postby Sam Spoons » Mon Oct 14, 2019 4:53 pm
Or they'll have a 'link' or 'thru' socket or something appropriately labelled on the back. If they don't you do have a problem to solve. Easiest way might be to buy another used power amp and use the HPF/LPF in the XR18 to match the subs and tops (you'll only need to burn up one extra output as the subs can quite happily be run in mono).
Postby DanR » Tue Oct 15, 2019 4:28 pm
Sam Spoons wrote:Depending on the power handling of the speakers* and providing you have a crossover (usually built into the sub) then yes you'll be fine.
Yes. I used to run 4 passive cabs from one power amp. Peavey EuroSys with an FBT amp.
The subs had 1/4” jack in and out with built in passive crossover.
With the system in question, it looks like each speaker would get 200W if the subs have a crossover built in.
DanR
Users browsing this forum: The Elf
