Matching Speakers to Amps
Page 1 of 1
PostPosted: Mon Oct 14, 2019 3:06 pm
by awdl22125
I have recently purchased a Behringer XR18 and to go with it a second hand KAM KCA 1600 Power Amp. The amp is rated at 2 x 400W RMS @ 4 Ohms & 2 x 250W RMS @ 8 Ohms. My band uses Peavey PA Speakers with tops and subs, the subs are rated at 4 ohms and I think the tops are too. Wouls this be ok in terms of matching?
Re: Matching Speakers to Amps
PostPosted: Mon Oct 14, 2019 3:25 pm
by Sam Spoons
Depending on the power handling of the speakers* and providing you have a crossover (usually built into the sub) then yes you'll be fine. If you just connect the sub and top to one channel without a crossover you risk destroying the amp as the net impedance would be 2 ohms.
* between 200 and 400 watts continuous would be ok.
PostPosted: Mon Oct 14, 2019 3:29 pm
by awdl22125
Thanks for the reply, the speakers are 250/500 watts so that should be ok. How would I know if the subs have a built in crossover? they are passive not active
PostPosted: Mon Oct 14, 2019 3:34 pm
by Wonks
You could try looking up a spec sheet online for them.
PostPosted: Mon Oct 14, 2019 4:53 pm
by Sam Spoons
Or they'll have a 'link' or 'thru' socket or something appropriately labelled on the back. If they don't you do have a problem to solve. Easiest way might be to buy another used power amp and use the HPF/LPF in the XR18 to match the subs and tops (you'll only need to burn up one extra output as the subs can quite happily be run in mono).
PostPosted: Tue Oct 15, 2019 4:28 pm
by DanR
Sam Spoons wrote:Depending on the power handling of the speakers* and providing you have a crossover (usually built into the sub) then yes you'll be fine.
Yes. I used to run 4 passive cabs from one power amp. Peavey EuroSys with an FBT amp.
The subs had 1/4” jack in and out with built in passive crossover.
With the system in question, it looks like each speaker would get 200W if the subs have a crossover built in.
