Extremely small receiver IEMs (In Ear Monitor) NO BELTPACK
Page 1 of 2
PostPosted: Mon Nov 04, 2019 9:12 pm
by lackmaster
I'm very familiar and experienced with the current and past main-stream IEM systems from the typical manufacturers (Shure, Senn, etc). I am a signer that does many impersonations per performance with many quick changes all night. I am not able to find a solution for an IEM receiver that is SMALL, independent of needing a belt, and does not even need to be attached to clothing.
I'm rather frustrated that in the last 20 years, non of the IEM makers have come up with a system that does NOT use a beltpack!
This is for live performance, so any bluetooth solutions do not apply as the latency is too big. So it must be an RF solution.
Does anyone know of an IEM system that could be attached via maybe tape to the skin, or so small that it's built into the Earbud cable like many bluetooth earbuds have?
Re: Extremely small receiver IEMs (In Ear Monitor) NO BELTPACK
PostPosted: Mon Nov 04, 2019 9:53 pm
lackmaster wrote:I am not able to find a solution for an IEM receiver that is SMALL, independent of needing a belt, and does not even need to be attached to clothing.
I'm rather frustrated that in the last 20 years, non of the IEM makers have come up with a system that does NOT use a Beltpack!
Well, there are plenty of handheld radio mics that have an integrated transmitter instead of a belt pack.... ;-)
But if you are using a headset or lavalier mic, a beltpack transmitter is still the only option. Sennheiser make a pretty compact UHF one, and in situations where a conventional pocket or belt fitting is inappropriate, it is frequently fitted to an elastic chest band to hold it in the small of the back, or strapped to the inside of a thigh. These techniques are often used for dancers in skimpy costumes, for example, such as on shows like Strictly Come Dancing, etc. Suitable elastic pouches are usually custom made by the costume department, but some of the well-known broadcast audio suppliers have suitable offerings or can get them made.
The technology doesn't yet allow something built into an earbud cable... The physically smallest system I'm aware of is the new Rode WirelessGo which looks impressive. It's digital and operates in the 2.4GHz band, so there will be more latency than an analogue UHF system... The specs say its 6ms. More info here:
https://www.rode.com/wirelessgo
PostPosted: Mon Nov 04, 2019 11:17 pm
by lackmaster
I'm referring to the beltpack RECEIVER for in-ear monitors.
PostPosted: Tue Nov 05, 2019 12:29 am
by Dan LB
RF beltpacks (TX or RX) do not *need* to be worn on a belt.
Provided you are always wearing *some* clothing covering your torso during your act, you could wear a suitable garment (perhaps a tight-fitting vest with a pocket stitched into the back of it that will hold the IEM pack) which allows you to wear whatever you want over it and allows costume changes.
There are commercially available products too.
Have a look at the ‘back strap’ by URSA straps.
https://ursastraps.com/product/backstraps/
Dan
PostPosted: Tue Nov 05, 2019 10:49 am
lackmaster wrote:I'm referring to the beltpack RECEIVER for in-ear monitors.
Oops! :oops: Sorry... misread your post.
PostPosted: Tue Nov 05, 2019 11:09 am
by Wonks
Just getting old. ;)
PostPosted: Tue Nov 05, 2019 11:11 am
Tell me about it! :think:
PostPosted: Tue Nov 05, 2019 11:32 am
by Aural Reject
Hugh Robjohns wrote:Tell me about it! :think:
Why? Wouldn't you just forget?
I'll go now.....
PostPosted: Tue Nov 05, 2019 11:47 am
Do I know you? :lol:
PostPosted: Tue Nov 05, 2019 2:16 pm
by Aural Reject
Hugh Robjohns wrote:Do I know you? :lol:
Hopefully only when I ask real questions and you ignore the silly ones...of which there are plenty! :bouncy:
PostPosted: Fri Nov 08, 2019 3:02 pm
by Virgovision
Phonak in ear monitor. If you are not in a very noisy environment. Not cheap but rx is just the bit you put on your ear! New one is called Roger!!!
PostPosted: Fri Nov 08, 2019 5:49 pm
by Wonks
Virgovision wrote:Phonak in ear monitor. If you are not in a very noisy environment. Not cheap but rx is just the bit you put on your ear! New one is called Roger!!!
https://www.raycom.co.uk/product/phonak ... -receiver/
https://www.raycom.co.uk/product/phonak ... ansmitter/
With an audio range of 100Hz to 7.2kHz, it's not going to be audiophile quality sound, but good enough to hear voice or backing music. It's not an isolating earpiece, so not great in a very noisy environment.
Not cheap, but it should meet your needs. At least the batteries are fairly inexpensive.
PostPosted: Fri Nov 08, 2019 8:47 pm
Ooh... Lots of people suggesting the same thing! Sorry to be late back in this thread. The Phonak in-ear receive is what I would suggest, too.
https://www.phonak-communications.com/e ... -prompter/
It is often used for presenter talkback duties in TV studios. Not sure how secure it would be for someone doing a dance routine -- should your act involve such a thing -- but a bit of surgical tape carefully placed would probably prevent its loss during energetic routines. It certainly would avoid any costume change issues... If the budget can take the strain.
PostPosted: Fri Nov 08, 2019 9:14 pm
I can find no mention of latency in the web pages? It is a digital system and designed for comms rather than music so latency is maybe not a consideration?
OTOH if the OP is not singing, or at least, not using the earpiece for vocal foldback latency may not be an issue for him either.
PostPosted: Sat Nov 09, 2019 3:22 am
by Dan LB
Sam Spoons wrote:I can find no mention of latency in the web pages? It is a digital system and designed for comms rather than music so latency is maybe not a consideration?.
I haven’t used one in a while but If I remember correctly latency is around 25ms and they’re not designed for hi fidelity music reproduction. As Hugh says, they are often used for presenter talkback in TV studios.
Dan
