X/M32 V4 firmware update released, and Wing news(ish)
Re: X/M32 V4 firmware update released, and Wing news(ish)
Postby DGL. » Mon Nov 18, 2019 10:35 pm
From Robert Lofgren, a beta tester, over at the PSW forums,
Robert Lofgren wrote:Wing has two option cards. One internal (populated when ordering) and one external like on the x32.
The internal one can be fitted with either sg or dante. This means that you can record up to 128ch of audio if you want to
DGL.
Postby The Elf » Mon Nov 18, 2019 10:42 pm
Sounds promising. What's 'sg'?
Postby Sam Spoons » Mon Nov 18, 2019 10:55 pm
Stereo channels can be controlled by a single DCA fader on the X32 and the latest firmware, I think, allows custom layers so, although you have only 8 DCAs you can mix and match their faders in a custom layer.
The Wing does look a seriously nice bit of kit for the money though. Not that I'll be selling my X32C anytime soon, it does everything I need and more, especially since I've mostly retired :D .
Postby DGL. » Mon Nov 18, 2019 11:02 pm
The Elf wrote:Sounds promising. What's 'sg'?
It'll be WSG, or Waves Soundgrid
DGL.
Postby The Elf » Mon Nov 18, 2019 11:04 pm
Gotcha. Thanks.
Postby Wonks » Mon Nov 18, 2019 11:08 pm
If those are lights pointing down at the I/O connections, then that's a good idea.
Postby DGL. » Mon Nov 18, 2019 11:17 pm
Wonks wrote:If those are lights pointing down at the I/O connections, then that's a good idea.
Yep, and the brightness is adjustable.
Also, if it wasn't already spotted, the top section is wider that the I/o section so in theory it will fit on a smaller table if necessary.
And Stageconnect will be freely usable by anyone with no licencing cost or cost to acquire the datasheets, that should help adoption of what looks to be a quite useful standard.
DGL.
Postby AlecSp » Tue Nov 19, 2019 1:47 am
Sam Spoons wrote:Stereo channels can be controlled by a single DCA fader on the X32 and the latest firmware, I think, allows custom layers so, although you have only 8 DCAs you can mix and match their faders in a custom layer.
Er, no.
If only that were the case, though...
AlecSp
