Robert Lofgren wrote:Wing has two option cards. One internal (populated when ordering) and one external like on the x32.
The internal one can be fitted with either sg or dante. This means that you can record up to 128ch of audio if you want to
X/M32 V4 firmware update released, and Wing news(ish)
• Page 2 of 2 • 1, 2
Re: X/M32 V4 firmware update released, and Wing news(ish)
From Robert Lofgren, a beta tester, over at the PSW forums,
- DGL.
- Frequent Poster
Sounds promising. What's 'sg'?
The Elf - Jedi Poster
Stereo channels can be controlled by a single DCA fader on the X32 and the latest firmware, I think, allows custom layers so, although you have only 8 DCAs you can mix and match their faders in a custom layer.
The Wing does look a seriously nice bit of kit for the money though. Not that I'll be selling my X32C anytime soon, it does everything I need and more, especially since I've mostly retired
Sam Spoons - Jedi Poster
It'll be WSG, or Waves SoundgridThe Elf wrote:Sounds promising. What's 'sg'?
- DGL.
- Frequent Poster
Gotcha. Thanks.DGL. wrote:It'll be WSG, or Waves SoundgridThe Elf wrote:Sounds promising. What's 'sg'?
If those are lights pointing down at the I/O connections, then that's a good idea.
Wonks - Jedi Poster
Yep, and the brightness is adjustable.Wonks wrote:If those are lights pointing down at the I/O connections, then that's a good idea.
Also, if it wasn't already spotted, the top section is wider that the I/o section so in theory it will fit on a smaller table if necessary.
And Stageconnect will be freely usable by anyone with no licencing cost or cost to acquire the datasheets, that should help adoption of what looks to be a quite useful standard.
- DGL.
- Frequent Poster
Er, no.Sam Spoons wrote:Stereo channels can be controlled by a single DCA fader on the X32 and the latest firmware, I think, allows custom layers so, although you have only 8 DCAs you can mix and match their faders in a custom layer.
If only that were the case, though...
- AlecSp
- Regular
