QSC TouchMix 16 has how many mono inputs
Postby sound space » Sun Nov 17, 2019 3:52 am
Hi
I am planning on buying the QSC TM16. It has 16 mono in, 2 stereo in, a USB stereo in, and a talkback in.
I am wondering how many mono channels i can get out of it if i have to cater for a big set up.
Talkback can apparently be routed to the Main out, so, leaving aside the USB stereo in, I am imagining i can have 19 mono inputs. All i need to do is convert two of the mono 1/4 inch cables to a stereo input to have them feed both sides of the PA. Is that the case?
Thanks for any feedback.
sound space
Re: QSC TouchMix 16 has how many mono inputs
Postby AlecSp » Sun Nov 17, 2019 3:57 pm
I'd question why you're planning to buy a mixer that you suspect will be too limited for what you're going to put through it?
If you're genuinely going to need more than 16 ins, then get a mixer with more than 16 proper ins. Either a TM30, if you're wedded to TouchMix, or one of the many other options that will do more. For a little more money, you'll save yourself a world of frustration.
AlecSp
Postby Wonks » Sun Nov 17, 2019 4:17 pm
How many line and mic inputs? The stereo ins are line-only. If you very occasionally need more inputs, then I'd suggest getting a small analogue mixer to feed into a stereo pair.
Any more regular use and you are really better off getting a bigger mixer.
Postby Sam Spoons » Sun Nov 17, 2019 6:38 pm
Buy an X32 Rack and an SD8 for 24 mic inputs, 6 line inputs and 16 line outputs. Costs about £100 less than a TM16.
Postby sound space » Wed Nov 20, 2019 5:31 am
My apologies for not being clearer. I have an x32 compact so can cover bigger gigs,
and I have an x32 rack as back up for it. I bought the rack when I first got the x32 but have found the screen on it not useable enough for any live work, even as a back up. I realise it is not intended for this so thought the TM16 would be a better back up to the X32 and in fact would replace it for most gigs.
Thank you for your suggestions. I was hoping the TM16 might have a mono routing solution to the 2 stereo channels, but in this case I agree that a good support solution is to carry a small analogue desk (which I do anyway) to feed in to a stereo pair…
sound space
Postby Sam Spoons » Wed Nov 20, 2019 12:49 pm
I also have an X32 rig (Compact and Rack), my small mixer is a Mackie DL1608, if I need more than 16 inputs I'll take the Compact as I don't want to be mixing more without physical faders. I find the Rack works fine when used with an iPad or two but, as you have discovered, the onboard screen and controls are not so friendly and I would not try to mix a show using them. Mine gets used as a stage box and backup mixer. The only advantage I can see with the QSC over the Rack/iPad is convenience of everything on one box.
Postby Dave B » Wed Nov 20, 2019 1:10 pm
my 2c ...
I'll defend the TM16 to my dying breath, but I'd still say that, like most gear, it only works for certain applications and if it doesn't fulfil the requirements, there's a lot of gear out there that will. The advantage that it has is that you can run a gig from the unit if your wifi is iffy. But that does mean that it has to be somewhere accessible (ideally in a good listening position), so I use mine with a couple of stage boxes. Simple, cheap and bullet proof. But not for everyone.
My backup is an XR18 which has almost the same number of inputs and can be a stagebox. It's a bit fiddly for my liking when it comes to setting up - but it's almost a 1/3 of the price of a TM16.
If I wanted more channels, I'm not 100% sure that I'd move to a TM30 ... I'm sure it's amazing, but part of me really likes the idea of the A+H QU series and digital snakes. More expensive, yes, but very cool...
Dave B
Postby Sam Spoons » Wed Nov 20, 2019 2:51 pm
Digital snakes are brilliant (especially after countless early hours tear downs coiling a muddy 24/8 analogue snake). The Rack works as a stage box for the Compact via AES50/Cat6, the XR series don't unfortunately (unless they have fixed it with a fw upgrade). If WiFi is dodgy you can hard wire PC/Mac but none have a USB Host capability (which the Mackie DL series do) so you can't plug in an iPad/Tablet.
I have an XR12 and apart from the WiFi only being 2.4GHz it's a useful little box. Now if it worked as a stage box over AES50.......
Re: QSC TouchMix 16 stage box
Postby Marcrv67 » Sun Mar 28, 2021 7:31 pm
Can I use a stagebox with my tm 16
I'm sick to death of a long analogue snake wanted go to a cat 5 cable
Marcrv67
Postby Hugh Robjohns » Mon Mar 29, 2021 11:14 am
The TM16 doesn't have a suitable digital input for a digital snake system.
However, you could use one of the completely standalone digital snakes which have breakout boxes for both the stage and FOH ends, connected by a catx cable. You'd then need a short loom to hook the FOH box into your console.
Something like the Roland S-1608 stage box and S-0816 FOH box?
Other brands make similar things...
Postby Dave B » Mon Mar 29, 2021 12:03 pm
If you are happy to use multiple cat5 cables, you can always use analogue audio over cat5 - Thomann do breakout cables/boxes in sets of 4 and others are available. I'm looking into it at the moment as a modular approach to less cabling. I have 2 analogue stage boxes with thick cables that I use on larger stages so that's a lot to lug around / manage...
Dave B
Postby AlecSp » Tue Mar 30, 2021 10:40 am
Marcrv67 wrote:Can I use a stagebox with my tm 16
The whole point of lunchbox mixers is that they *are* the stagebox - mixer on stage, then run control on a remote device using wi-fi or wired cat 5 connection (or both) depending on your desier for resilience. Yes, on a device like the TM with on board control, you lose that, but that's the trade-off for losing the analog snake.
If you really want a stagebox & mixer combination, you have the wrong product. Plenty of options out there.
Hugh Robjohns wrote:However, you could use one of the completely standalone digital snakes which have breakout boxes for both the stage and FOH ends, connected by a catx cable. You'd then need a short loom to hook the FOH box into your console.
While it would work, it'd be quite the rigmarole (and cost).
Feels like the solution we'd have put up with 10-15 years ago, but would feel daft these days with so many much better options available.
AlecSp
Postby Hugh Robjohns » Tue Mar 30, 2021 10:46 am
AlecSp wrote:While it would work, it'd be quite the rigmarole (and cost).
Very true... but he did ask.
I would agree with your earlier observation that perhaps the OP has the wrong tool for the job.
Postby The Elf » Tue Mar 30, 2021 11:36 am
It does seem odd that you'd choose a mixer with *less* inputs that you'd need then try to find ways to get around the problem you've bought for yourself. Instead choose a mixer that has the capacity you want.
And here's the big secret...
Whatever number of channels you *think* you need - you can add at least 50% to that number in reality - and double it, if possible!
Postby Wonks » Tue Mar 30, 2021 12:41 pm
The Elf wrote:It does seem odd that you'd choose a mixer with *less* inputs that you'd need then try to find ways to get around the problem you've bought for yourself. Instead choose a mixer that has the capacity you want.
I fear you are replying to the OP's 2019 post, Elf, rather than the 2021 Cat5 stage-box question.
