JBL EON One Pro
JBL EON One Pro
Postby KiwiRocker » Sun Dec 01, 2019 12:55 am
These units come as a single unit. I want to use in a left & right configuration.
Can you get the second unit as a bass unit and tower without the mixer? Thanks....Larry
KiwiRocker
Re: JBL EON One Pro
Postby Wonks » Sun Dec 01, 2019 1:11 pm
No. Just buy another one. Ignore the fact it's got a mixer built-in.
For dual mono, just feed one from the pass-through output of the first one. For stereo, you'd be best getting a small external mixer and using that to feed the two sides (though battery powered mixers are pretty rare but a standard one and a suitable battery pack should suffice).
I that doesn't help, you may need to explain in more detail about what you're trying to achieve, and if you need to be fully independent of mains power.
