Schematic needed for Fender Fortis 15BT
Postby haysy » Sat Mar 28, 2020 7:16 am
Hi
one of these went flash and pop on me recently and a local amp tech is trying to fix it. He says it’s the T Pro-2 module that he needs the schematic for. Apparently Fender get them from a company in Holland but they won’t play ball with the schematic. Official Fender forum closed 20th March ironically and so far no response from their tech support team.
It’s a long shot but would anyone have access to this schematic?
thanks
chris
haysy
Re: Schematic needed for Fender Fortis 15BT
Postby ef37a » Sat Mar 28, 2020 3:53 pm
Try thefretboard.co.uk
Lot of top gitamp teks over there.
Postby Wonks » Sat Mar 28, 2020 4:17 pm
It's unlikely as it's a fairly new module, and seems to be made by a Danish audio company. So I doubt that they are making the schematic available to all and sundry. Best to go down the authorised repair route. If this is in the UK, then it's probably still under warranty.
Postby haysy » Sat Mar 28, 2020 8:44 pm
Thanks for the advice guys, much appreciated.
haysy
Postby RMCL » Fri Apr 03, 2020 10:44 am
The T-PRO2 is a 2 channel amplifier module developed by Pascal Audio in Copenhagen see https://www.pascal-audio.com/product/t-pro2/
Suggest you send an email to info@pascal-audio.com asking if there is a service manual/schematic available for the T-PRO2 and asking about replacement modules
RMCL
Postby haysy » Fri Apr 03, 2020 11:02 am
Thanks RMCL
We contacted them and they wouldn’t play ball with schematic. Replacement module is 220 euros! Only paid 200 for the Fortis secondhand so not a really attractive option. Might turn the cab into passive as I have a rack power amp to drive it, the speakers are good.
haysy
