RIG set-up question from a noob
Re: RIG set-up question from a noob
Postby Steven11 » Mon Jul 20, 2020 11:26 am
Hugh Robjohns wrote:Nope. The KL only has one mix bus, so all inputs are combined, including the effects return, to feed both the main outputs and the monitoring outputs. Check out the block diagram on page 12 of the manual.
Right, it makes sense and I don't know why I thought that for a moment. Must have been dazed & confused after all the thinking about this stuff ahahah :beamup:
In any case I'll live without this feature for now.
Hugh Robjohns wrote:And if the volume pedal has separate dual mono ins and outs, as per the diagram in the manual, you'd need splitter cables.
Yes thinking about it, it would have been convenient if also the effects loop jack on the Key-Largo had been two mono jacks, as opposed to the single stereo jack, because almost all the stero effects pedals I've been seeing out there have the dual jack connection. Well not a big problem anyway...
Steven11
