Looking for information on specific gear
Postby Jenda Oceans » Wed Sep 02, 2020 6:42 pm
Hello, I am looking for a specific piece of gear but I'm not sure if it even exists. I have attempted searching for it but have had poor results. So, I thought someone here may have the knowledge I seek.
I am looking for a small portable EQ with low and high pass filters. Preferably it would have stereo in and out. I have considered an EQ guitar effects pedal but was hoping there were other options I am not aware of.
Jenda Oceans
Re: Looking for information on specific gear
Postby Hugh Robjohns » Wed Sep 02, 2020 7:48 pm
Is the for use with microphone signals? Line level? Instrument level?
Balanced or unbalanced?
Battery powered or mains powered?
Just filters, or filters with 2- / 3-band EQ?
Postby Jenda Oceans » Wed Sep 02, 2020 8:04 pm
I believe this would be line level as I want to connect a Teenage Engineering Pocket Operator to it. But, in the future I may add some other small synthesizers as well. I have ordered a PO-14 Sub and a Zoom MS-70CDR effects pedal. The pedal has two left and right TS ins and outs I believe and I planned on connecting a 3.5" TRS to 1/4" TS Y- cable between the PO-14 and the Zoom. Battery operated would be preferred.
Jenda Oceans
Postby Sam Spoons » Wed Sep 02, 2020 10:19 pm
Not necessarily battery powered but a small digital mixer would do what you need, say a Behringer XR-12?
Postby Jenda Oceans » Wed Sep 02, 2020 10:42 pm
Thank you for the recommendation, the XR-12 looks interesting. Unfortunately it wouldn't be suitable for my application. What I'm trying to achieve is a small portable audio palette to stay creative and retain some of my humanity while I am forced into extreme overtime at work. I have lost all ability to practice and create at home so I am determined to find some way to resist the oppressive forces attempting to restrain me. In addition to the two pieces of equipment I listed previously I also have an old Tascam DP-004 recorder that I plan on using. I just thought it would be useful to have the ability to twist a knob or slide a pad or something to adjust a filter and EQ. The filter is more important to me though so the EQ isn't absolutely necessary.
Jenda Oceans
Postby Sam Spoons » Thu Sep 03, 2020 9:26 am
Dedicated and adjustable HPF and LPFs are rare and expensive and probably found amongst modular synth hardware. Analogue mixing desks often have a LPF but rarely a HPF. The only way I can see you getting what you want at a reasonable cost is with something like the XR.
TBF, as a guitar player I'm not hugely familiar with modern synth hardware so there may be something out there.
Postby MarkPAman » Thu Sep 03, 2020 9:41 am
How about a stereo 3 way crossover, and take the output from the mid band?
For instance: https://www.behringer.com/product.html?modelCode=P0CCT
- I've no idea if you'd count this as small & portable enough, and it's certainly not battery powered.
MarkPAman
Postby shufflebeat » Thu Sep 03, 2020 10:30 am
This sounds like a job for iPad/interface and controller. I'm not sure what would be appropriate but certainly a route to explore
Do you already have an iPad?
Do you particularly want to stay analogue/avoid digital or are you open to just getting the job done well?
What's your budget?
shufflebeat
Postby Jenda Oceans » Thu Sep 03, 2020 1:15 pm
I don't currently have any Apple devices. During my research I stumbled across the Korg Monotron Delay. During one of the videos I watched it appeared to have the ability to adjust the filter of any sound coming into it. This may suit my needs. Honestly, I'm trying to keep cost low (under $100 USD) I think I'll investigate this Monotron Delay a bit more. Thanks for the suggestions everyone.
Jenda Oceans
Postby James Perrett » Thu Sep 03, 2020 2:26 pm
An old Drawmer DS201 2 channel noise gate has variable high pass and low pass filters. The only problem is that it is a 19" rack device.
Postby al_diablo » Thu Sep 03, 2020 2:44 pm
Would something like a kaoss pad mini do what you need? They're just over your budget but probably in the right price bracket second hand
al_diablo
Postby Mike Stranks » Thu Sep 03, 2020 4:31 pm
Sam Spoons wrote:... Analogue mixing desks often have a LPF but rarely a HPF....
I think you'll find it's the other way around... ;) :)
Easily done, says one who's done it himself several times in forum posts. :lol:
Postby Sam Spoons » Thu Sep 03, 2020 5:10 pm
You are right of course :blush: :D
Postby Jenda Oceans » Thu Sep 03, 2020 6:10 pm
The Kaoss pad mini 2 looks interesting. I have this feeling like I'm going to buy more gear than I initially anticipated. If anyone is familiar with the Korg Monotron Delay how would I record from it? Via the headphone out? I don't see any other outputs on it.
Jenda Oceans
