what fuse do I need, yamaha emx66m
Postby ciarancussen » Mon Oct 19, 2020 11:43 pm
I'm confused on what fuse i need for my mixer. It says F1Al 250V on the blown fuse (took out in photo). any help appreciated... https://drive.google.com/file/d/1oC0x5L ... sp=sharing
ciarancussen
Re: what fuse do I need, yamaha emx66m
Postby Mike Stranks » Tue Oct 20, 2020 8:47 am
Welcome! :thumbup:
The 'blacked-out' info on the circuit board is stating a 1.2 amp 250 volt fuse. But why it's blacked-out I'm not sure...
Do you know why the fuse blew?
Postby Tomás Mulcahy » Tue Oct 20, 2020 9:40 am
Are you in the UK or US? Is the unit the 110V or 250V model?
Tomás Mulcahy
Postby Hugh Robjohns » Tue Oct 20, 2020 9:44 am
ciarancussen wrote:I'm confused on what fuse i need for my mixer. It says F1Al 250V on the blown fuse (took out in photo). any help appreciated...
The general rule is you replace like for like... An F1A fuse is a 1 amp quick-blow (fast) fuse. Given Mike's detective work, it looks like you could possibly increase that to F 1.25A.
The question is, why did it blow? Fuses can just spontaneously die through old age or vibrational fatigue in mobile gear... but usually they blow because of a fault.
Postby ciarancussen » Tue Oct 20, 2020 11:03 am
It’s a 250v version. Not sure why the fuse blew as I got the mixer with some speakers second hand.
ciarancussen
Postby Hugh Robjohns » Tue Oct 20, 2020 12:02 pm
Had it been working normally for extended periods without issue before the fuse went? Any indication of a problem -- smoke, nasty noises, high temperatures -- before it blew?
Postby BJG145 » Tue Oct 20, 2020 5:06 pm
Mike Stranks wrote:The 'blacked-out' info on the circuit board is stating a 1.2 amp 250 volt fuse. But why it's blacked-out I'm not sure.
That's really weird. That's bugging me now.
What they say. Stick in another one and cross your fingers.
Postby wireman » Tue Oct 20, 2020 5:10 pm
I assumed that only one was supposed to be blacked out based on supply voltage.
wireman
Postby BJG145 » Tue Oct 20, 2020 5:12 pm
Ingenious. I'll buy that. They started redacting and got carried away,
Postby BJG145 » Tue Oct 20, 2020 5:23 pm
...now, I don't know anything about fuses. But one thing they didn't scribble out is: "T4A". As far as I can see from a bit of Googling, this is "slow-blow", but the one you took out is "F1A" which is "fast-blow".
The game's afoot.
Postby Mike Stranks » Tue Oct 20, 2020 6:19 pm
Dr Watson here...
This is the relevant bit of the service manual:
Full manual available at: https://drive.google.com/file/d/1xnYSPSF7Tm1iYmctkVIgHUGtl_Ljj7b1/view?usp=sharing
Postby AlecSp » Tue Oct 20, 2020 7:41 pm
Tranceformer - magic!
AlecSp
Postby BJG145 » Tue Oct 20, 2020 7:50 pm
Mike Stranks wrote:Dr Watson here
...except...
You know my method. It is founded upon the observation of trifles.
Postby BJG145 » Tue Oct 20, 2020 8:18 pm
Looking back to an earlier page of the service manual, there's this:
What is all this J and U stuff...? Are these descriptions for the fuse in different versions of the circuit board...? It's not very clear. But it seems quite plausible that the one you removed blew because it's the wrong type.
Postby Hugh Robjohns » Tue Oct 20, 2020 9:57 pm
BJG145 wrote:Looking back to an earlier page of the service manual, there's this:
It's quite likely the same raw PCB is used in multiple designs with different ratings. Hence the crossed out options.
Hence my earlier question: Had it been working normally for extended periods without issue before the fuse went?
And: Any indication of a problem -- smoke, nasty noises, high temperatures -- before it blew?
If it had been working normally before hand, the removed fuse was probably the right value (or close to it). Ditto if the unit developed an obvious fault immediately prior to it popping.
But reading the specs for that unit, with such a large inrush current, I was surprised it was an F (fast-blow) fuse... I would have expected a T (anti-surge) fuse.
