Live Streaming problem: sound in left ear only
Postby CyrilWohrer » Sat Nov 07, 2020 6:26 pm
Hi there,
I did my first Facebook Live today, using my Sony ZV-1 camera and my Shure Sm7, both of which I plugged into my MacBook Pro directly. Aside from the synching issue, I encountered a *big* problem, namely that the sound was recorded only in the left ear. How can I fix this problem? How can those watching my Live hear me in both ears, not just the left?
Thanks,
Cyril
CyrilWohrer
Re: Live Streaming problem: sound in left ear only
Postby The Elf » Sat Nov 07, 2020 6:46 pm
Hi Cyril, and welcome. :thumbup:
We are going to need a lot more information to begin trying to help.
For a start, how is all your equipment connected?
Are you aware that one mic can only give a mono signal? The SM7 is a standarrd mic with an XLR output, so you must be going via a mic pre-amp of some description and then to USB - how? How are you handling the mic to pan it to the stereo centre?
What software are you using to handle the audio mix?
Postby shufflebeat » Sat Nov 07, 2020 8:41 pm
I've been exploring OBS recently and find the separate channels of my interface are hard panned L/R.
I've considered using a small mixer to take care of the stereo field but have to explore further to see what options might be available within the software.
There is a mono/stereo in audio prefs apparently but that's a bit drastic for my use.
shufflebeat
Postby Mike Stranks » Sat Nov 07, 2020 9:06 pm
Welcome from me too! :thumbup:
I know nothing about Apple anythings, but I'll take a stab at what might have happened...
Did you perchance connect your SM7B to the computer using a lead like this:
or this:
If the leads aren't wired correctly - and I find that XLR to anything often aren't - then that would account for the left-hand channel only sound.
If you are connecting like this then you need to make, or get someone to make, a lead with pin connections as follows (using a 3-pin XLR female socket and a 3.5mm 'stereo'/TRS mini jack plug):
XLR pin 1 to the sleeve of the jack-plug;
XLR pin 2 to the tip AND ring of the jack-plug;
XLR pin 3 to the sleeve of the jack plug.
Of course, if you're not connecting your mic in this way then I refer you to The Elf's earlier post! :lol:
Postby shufflebeat » Thu Nov 19, 2020 10:01 am
Looks like Cyril hasn't checked back but just in case anyone else has the same issue this is my mini exploration of Voicemeeter copied from elsewhere on the forum which I suspect would have informed his quest:
Well, I've had a play with Voicemeeter tonight and, unless I've missed something fundamental, it seems pretty straightforward. Everything's labelled logically and does what it's told.
After installing the laptop needed a restart which always gives me the shivers but no issue. I sparked up again with the SSL2+ hooked up and as it is the default driver when available VM grabbed it for audio and the hardware inputs were already assigned when I started VM.
The VM driver showed up as an audio device in Reaper which in turn appeared as the virtual input in VM.
Bus A goes back to the SSL for headphone or main monitors and bus B goes wherever I send it within the laptop, in this case to Zoom.
The only thing I found strange was that the separate mic channels didn't seem to be default panned hard left and right as they were in OBS but "mostly left" and "mostly right". I hit the "mono" button on both of them anyway so it was irrelevant. The panel above the mic channel fader had me scratching my head for a few minutes because it's not a pan control as it appeared to me but a kind of XY joypad for tone settings, very neat but bypassed.
There's a pretty nifty looking set of audio tools that came along with the installation for further tweakage. I fired up the standalone 15 band EQ which can be assigned to either bus at the nudge of a button. Sounded perfectly adequate.
No real dramas with Reaper, VM and Zoom all running together. I tried incorporating OBS as well for a chuckle and everything seemed to cooperate until my little old laptop ran out of steam.
It's a 9 from me. I'm only withholding the last 1 in case time reveals an issue and because I'm a grumpy old sod.
shufflebeat
