Mastering audio for TV Broadcast for the first time!
Hey guys, new here. So I have to mix/master audio for a Music program (with some dialogue) that will be broadcast on TV. Any suggestions for optimally carrying out this type of work in an efficient manner is appreciated.
The TV Channel Broadcast Specs are as follows:
2.0 Compliance with Technical Specification Guide
2.2 All audio content has to comply with technical requirements set out in ATSC A/85RP. Dynamic range must be suitable for television broadcast with target loudness level -24 LKFS. Audio should be mixed such that the measured average loudness of any Lt/Rt mix shall be equivalent to the measured average loudness of 5.1 audio within +/- 2 dB.
2. Accepted File-Based Formats
Due to the wide variety of file-based formats, they will only accept file-based material after it has been thoroughly tested. After the test period, they will determine the acceptability of the file-based material from a supplier.
2.1 Generally, file-based material formats shall be:
2.1.5 Audio Codec: PCM AES, 24 Bit, 48kHz, 8 Channels (see Table 1 SMPTE 320M-B Channel Allocation)
4. Audio Formats & Channel Assignment
4.1 They will only accept material with stereo or 5.1 multi-channel audio. All audio must be able to be output baseband audio following SMPTE 320M-B channel allocation.
4.2 For file-based material, they will accept material which has channel allocation described in metadata.
4.3 If file-based material metadata cannot describe the channel allocation, and for all other material, they will only accept material that conforms to SMPTE 320M-B channel allocation.
4.4 If DV is not provided a stereo down mix is required on Ch 7 and 8.
Table 1 . SMPTE 320M-B Channel Allocation
Channel / Description
Ch 1 / Left
Ch 2 / Right
Ch 3 / Centre
Ch 4 / LFE
Ch 5 / Left Surround
Ch 6 / Right Surround
Ch 7 /Aux A
Ch 8 / Aux B
5. Described Video
5.1 When available, Described Video should be provided for all material. Described Video will consist of a channel 1 and 2 stereo mix for material with stereo-only audio, or a stereo down-mix derived from channels 1 through 6 for 5.1 material, combined with center-panned voice description audio.
5.2 Described Video audio shall be assigned to SMPTE 320M-B “Aux A” and “Aux B”.
6. Audio Loudness
They will only accept material where loudness is maintained at -24 LKFS within +/- 2dB, based on the ATSC A/85 recommended practice.
6.1 For single-segment material, they will measure the integrated loudness over its full length.
6.2 For multi-segment material, they will measure the integrated loudness of the full length of one randomly selected segment.
6.3 Loudness measurements will be made with an ATSC A/85 compliant audio monitor to ensure compliance.
6.4 For material that contains multi-channel audio, described video, and/or a stereo down-mix, -24 LKFS shall be maintained for each component
6.4.1 The 5.1 multi-channel main programs shall be -24 LKFS
6.4.2 The described video program shall be -24 LKFS.)
8. Audio-Video Synchronization (Lip Sync)
They will only accept material where the audio material is tightly synchronized to the video material.
8. 1 The overall tolerance in audio-video synchronization shall fall within +15ms and -45ms. In other words, audio shall lead video by no more than 15ms and shall be delayed by no more than 45ms from video.
Ch 1 / Left
Ch 2 / Right
Ch 3 / Centre
Ch 4 / LFE
Ch 7 /Aux A
Ch 8 / Aux B
5. Described Video
6. Audio Loudness
