Mackie pro fox V3 10 speaker hook up
• Page 1 of 1
New to this here and am hoping you all might be able to help me . I am wondering if I can run my mains , 2 subwoofers and 2 monitors and control them independently with my Mackie pro fx v3 10 channel mixer ? Right now I am daisy chaining my mains and my subs together but would love to be able to Separate them . Thankful for any input you might have ..
- puppychow
- New here
Re: Mackie pro fox V3 10 speaker hook up
I'm not a PA expert - just a enthusiastic amateur - but I think that those that would be able to provide you with expert advice will need to know about how the speakers are powered and if you use a crossover in the subs in a separate one.
Irrespective of the potential routing out of the mixer the key issue will be how to keep the right bits of the audio spectrum in the respective speakers.
So key questions are
Are you using powered or passive speakers?
If you are using passive what amp / crossover arrangement do you use?
If you are using powered speakers do you use the band passed output to the mains?
What Subs have you got?
What Mains have you got?
Are you willing to purchase any more kit to get the job done?
Murray B - Regular
And why do you want to separate them?
blinddrew - Jedi Poster
I am doing a live show where I will have an audio snake run to the stage , and i would like to be able to adjust everything from 50’ in front of the stage vs having to go up and raise or lower the levels of the subs ..
- puppychow
- New here
But still hasn't told us, despite being asked, what speakers are being used, if/how they're being controlled, and how they're hooked up.puppychow wrote:I am doing a live show where I will have an audio snake run to the stage , and i would like to be able to adjust everything from 50’ in front of the stage vs having to go up and raise or lower the levels of the subs ..
Give the information you were asked for, and you might find some responses that could help you.
- AlecSp
- Regular
They are Behringer active mains and the way I’m using them now I am daisy chaining the subs to these , Behringer active subs and Behringer active monitors . I am running the mains and subs out of the main outs and the monitors out of the control room outs .
- puppychow
- New here
Also I do not know if I answered the question about “band passed output to mains” as I’m not sure what exactly that is .
- puppychow
- New here
Not really that helpful. It's like saying I need a new valve gasket for my Ford....puppychow wrote:They are Behringer active mains and the way I’m using them now I am daisy chaining the subs to these , Behringer active subs and Behringer active monitors
That said, your mixer is hardly that functional. Looks like its only outputs are the mains and control room.
What are you trying to achieve by this? And would I be right to guess that this is for DJ use?
Looks like there are two ways you could control sub & top volumes separately
1) Use the FX send to drive the subs - obviously, this is likely to render the internal FX unusable
2) Run as a mono system, and send one side of the master signal to the subs and the oher side to the tops. Use the channel pan pot to adjust the sub/top balance.
- AlecSp
- Regular
If your tops have a built in HPF then you could use the control room outs to feed the subs. I'm assuming you use the fx sends for the monitors but that is not ideal as they are post fader.
If the tops don't have HPF's then you are stuck with slaving them from the sub's HPF output if you want the rig to work as intended.
Sam Spoons - Jedi Poster
Simplest solution with your mixer is to buy an active crossover.
See here: https://www.thomann.de/gb/crossovers.html?oa=pra for the sort of thing that's available.
I'm not suggesting you buy from them; all the major retailers sell a range of crossovers.
- Mike Stranks
- Jedi Poster
He said he was driving them from the Control Room output. All pretty ropey, really, but that little mixer gives you very few options. It was that which made me wonder what the actual usage is, and made me suspect DJ. Sadly, useful information hasn't been that forthcoming.Sam Spoons wrote: I'm assuming you use the fx sends for the monitors but that is not ideal as they are post fader.
- AlecSp
- Regular
