Behringer X32 need more outputs?
Postby Hello2084 » Sat Mar 27, 2021 5:57 pm
Hi, I am new here so hello!
I am building a system. I currently have an X32. However I need more than 16XLRs.
I was thinking of getting a X32 rack, and I could link them ( I also have a nice 19" cabinet ). Any better ideas?
Could I use a 6.3mm TRS balanced to XLR connector wire to gain an extra 6 outputs via the AUX outs?
Any other ideas? Any help appreciated.
Sid
Hello2084
Re: Behringer X32 need more outputs?
Postby blinddrew » Sat Mar 27, 2021 7:10 pm
How many outputs do you need?
What options does the AES/EBU out give you?
Postby The Elf » Sat Mar 27, 2021 7:30 pm
There may be other ways of doing this, depending on what you're trying to achieve.
What are these outputs going to be used for?
Postby Hello2084 » Sat Mar 27, 2021 7:36 pm
22. I had been thinking of using that AES connection to my Behringer 2496. That has 6 XLR outs, and I am not using it ATM. Could it do it?
But I like the control from the X32, the ability to run a great deal of it from an ipad, or PC remotely. The X32 rack is also good value for money, unless there is a better way?
Or any other methods?
Hello2084
Postby Hugh Robjohns » Sat Mar 27, 2021 7:57 pm
Hello2084 wrote:Could I use a 6.3mm TRS balanced to XLR connector wire to gain an extra 6 outputs via the AUX outs?
Yes, assuming the routing arrangements work for your application.
Postby Hello2084 » Sat Mar 27, 2021 8:44 pm
Oh that would be great news. I was getting worried when someone on another forum said my X32 had 16 outputs total and using the 6 aux outs would lose me 6 XLR outputs.
Well I suppose if I could do it that way, and use the AUX outs that would be great. I might have to use the 2 RCA outputs on the X32. But using my DX2496 ultradrive pro for 1-2 of the outputs, if needed is no big deal TBH.
So to confirm, one way or another, my X32 gives me 22 outputs simultaneously, that can be XLR? (With my normal output control, slightly reduced on the AUXs, but the main ones: EQ, compression etc still there?)
And, if really needed, the AES/EBU can let me use the DX2496?
If so, that is awesome. Thanks everyone, and Behringer too!
Hello2084
Postby The Elf » Sat Mar 27, 2021 9:02 pm
The Elf wrote:There may be other ways of doing this, depending on what you're trying to achieve.
(If these outputs are for artist monitoring, for instance, there's potentially a better way using P16Ms...)
Postby AlecSp » Sat Mar 27, 2021 11:34 pm
Hello2084 wrote:So to confirm, one way or another, my X32 gives me 22 outputs simultaneously, that can be XLR? (With my normal output control, slightly reduced on the AUXs, but the main ones: EQ, compression etc still there?)
If you use 6.35mm to XLR converters for the six aux outs, then yes.
However, depending on what you want to feed them, you might find that the internal routing is your limiting factor.
You asked the simple question as to whether you can have more than 16 outputs. But failed to explain what you wanted to do with them.
AlecSp
Postby Hello2084 » Sun Mar 28, 2021 6:03 am
Hi,
They would be running to sound outputs.
Everything from DZR315s (simply) to custom cabinets (L 2x D4400TI-ND, R 2x D4400TI-ND), which need the X32 to give me hi/low cut, limits, EQ etc).
It is quite a complex system due to various different components, which all need these settings because their different frequency ranges, power etc.
Hello2084
Postby uselessoldman » Sun Mar 28, 2021 9:30 am
I have both SD16 and the SD8 they have 8 XLR outputs each. There is also I guess the ADAT option and the Behringer ATA8200 would give you an extra 8 XLR outputs per unit installed.
uselessoldman
Postby Sam Spoons » Sun Mar 28, 2021 10:59 am
Hello2084 wrote:Oh that would be great news. I was getting worried when someone on another forum said my X32 had 16 outputs total and using the 6 aux outs would lose me 6 XLR outputs.
No the aux's are available in addition to the XLR outputs but you only have 16 buses (plus L/R, not sure OTTOMH whether you can use L/R as an extra two fully independent buses)
The RCA sockets duplicate the TRS sockets on Aux 5 and 6, not sure where the DRX comes in?
The outputs don't have eq/compression etc as such, they are simply analogue outputs fed from the D/A convertors. You need to use buses to supply the processing.
The AES/EBU output mirrors the main outs
Your's is an unusual use case and the best way to see if it works is to try it. I'm still unclear about what your requirement is, 22 different speaker channels which all need different eq and compression? More detail please.
Postby Funkyflash5 » Sun Mar 28, 2021 3:26 pm
Depending on your signal mixing need, you may want to use your matrices to feed the auxes
Funkyflash5
Postby AlecSp » Sun Mar 28, 2021 3:37 pm
Funkyflash5 wrote:Depending on your signal mixing need, you may want to use your matrices to feed the auxes
You may need to use your matrices. You still haven't really explained exactly what you're trying to do - but it sounds like you have the design in your head.
We have at least ascertained that you can easily get 22 XLR outs from the X32. Now go off and see if you can achieve your goal using mixbuses and matrices.
AlecSp
Postby Sam Spoons » Sun Mar 28, 2021 4:05 pm
AFAIK the matrixes can only receive signals from buses of which you only have 16 in the X32. I plan to go and have a fiddle this evening as learning more about my X32 is always worthwhile, whether I'll learn anything to assist the OP I don't know though (if I do I'll post back later)...
Postby Hello2084 » Mon Mar 29, 2021 1:35 pm
Hi,
It sounds like I will need the DCX2496 in order to take the main L/R input and do the crossovers/cuts/EQ etc.
I have most of the system purchased. It takes in a central L/R source. Then it will go out to many separate items. For a LCR setup. It is not recording or anything, just a system for listening.
This is a c/p of part of it:
1. TL / BL DZR315: Via daisy chain
2. TR / BR DZR315: Via daisy chain
3. CC TS315 + CC TS315 then via daisy chain
4. 2 x BT68 via E - 1500 tamp 1 L 4Ohm 1430w Ch1
5. 2 x BT68 via E - 1500 tamp 1 R 4Ohm 1430w. Ch2
7. BS SRX828P: Input x 2 on SW1 (B) = RED        8. TS SRX828P: Input x 2 on SW2 (T) = ORANGE
9. 2 x BT58 via 4-700 tamp 1 810w  4Ohm Ch1
10. 2 x  BT78 via 4-700 tamp 1 CC 4 Ohm 810w  Ch2
11. 2 x 2 via splitter D4400TI-ND via 4-700 tamp 1 Ch3 , 810w 4Ohm
12. 2 x 2 via splitter DS18PRO-DRN2 via 4-700 tamp 1 Ch4, 4Ohm 810w
13. 2 x 6MR500-NDY, via 4-700 tamp 2, 4Ohm 810w Ch3
14. 2 x 5MR450-NDY, via 4-700 tamp 2, 4Ohm 810w Ch4
15. 1 x 12MR2000-NDY, 1 x 12MR2000-NDY 4Ohm 1800w
16. 1 x 12MR2000X, 1 x 12MR2000X 4Ohm 1800w
Get the idea?
I already have most of the items. The off the shelf parts are running, up to channel 8.
90% of other items purchased but not finished. This is not a complete list.
Unusual I know. But the 4 DZR315s (2L, 2R). Along with the JBL SRX828P x 2 is a lovely system. But , for example, the 4 BT68s (2L, 2R). Truly sound great, adding so much to the highs of the system. Adding the rest would all need the same level of control I already have.
Hello2084
