Dynamics and EQ on the Hammond B3 / Leslie Setup
Postby trunkdog » Fri May 14, 2021 7:18 pm
Would some kind soul offer advice on proper dynamics and EQ for the Hammond B3 / Leslie setup in both a recording and live setting? I can find a good deal on mic technique but nothing on dynamics and EQ.
When doing my research I thought I'd be inundated with advise given the iconic stature of the Hammond B3 / Leslie.
A search at the Keyboards & Synthesis forum turned up no mention of "Hammond"; can that be real?
I have difficulty, particularly in EQ'ing as the droning of the rotor works against my natural instincts.
Thanks in advance for any and all suggestions or experiences.
trunkdog
Thx - td
Re: Dynamics and EQ on the Hammond B3 / Leslie Setup
Postby Hugh Robjohns » Fri May 14, 2021 7:25 pm
It shouldn't need EQ -- the drawbars are the EQ, really -- and I've never needed much in the way of dynamics processing either -- that's what the right foot is for on the expression pedal.
But if your player is not that great, then I'd look at a gentle leveller -- an optical compressor maybe with slowish attack and release times, and a moderate ratio of maybe 3:1 or less.
Postby The Red Bladder » Fri May 14, 2021 11:50 pm
A droning of the Leslie should not be easily audible. Perhaps you are recording it too quietly? Hammonds like to be noisy!
The Red Bladder
Postby James Perrett » Sat May 15, 2021 12:47 am
The Red Bladder wrote:Perhaps you are recording it too quietly?
Or applying too much compression?
Postby AlecSp » Sun May 16, 2021 6:52 pm
The Red Bladder wrote:A droning of the Leslie should not be easily audible. Perhaps you are recording it too quietly? Hammonds like to be noisy!
I've yet to hear a quiet one!
AlecSp
Postby Trevor Johnson » Sun May 16, 2021 7:08 pm
Apart from the first few seconds of 'warm up', and turn off, the practice Johannus organ I play, with Leslie type speakers, makes no discernible 'Leslie' noise.
Trevor Johnson
Postby Dave B » Sun May 16, 2021 11:17 pm
Hugh Robjohns wrote:It shouldn't need EQ -- the drawbars are the EQ, really
I've never done the real thing, but I do find that a gentle low cut can tame the bottom end a bit when mixing with a band. My modern Hammond (sk2) can push out a fair bit of bass end, so I permanently have the low end shelved rather than boom over the bass.
Dave B
