Neumann KH 120A monitors
Re: Neumann KH 120A monitors
Postby Guy Johnson » Fri Feb 05, 2016 10:35 pm
As to the 'why' on the low end, I don't know much ... I just know what they DO :)
Thanks for the info, Hugh, I'll have a look.
Guy Johnson
This is my few words.
Postby Stoney » Mon Feb 15, 2016 5:56 pm
Got these too recently, largely off the back of Hugh's (many) recommendations :)
(Plus listening in stores - but the environments weren't that great).
I think I may still be in the burn-in phase, but already they are light years beyond anything I've heard in a home setting before.
Thanks Hugh! (and Guy for the review)
Stoney
Postby Hugh Robjohns » Mon Feb 15, 2016 6:16 pm
Stoney wrote:I think I may still be in the burn-in phase...
The Neumann gurus are adamant that their speakers don't require 'burning in', and I've not noticed any obvious character changes from first switch-on with any of the ones I've reviewed (or owned).
Postby Guy Johnson » Mon Feb 15, 2016 11:09 pm
Nor have I — however, I did pink noise them for a few hours to start with.
Guy Johnson
Postby Stoney » Tue Feb 16, 2016 11:01 am
OK great - was just going off what I'd heard about monitors before, not based on the monitors' actual performance.
Stoney
Postby ConcertinaChap » Tue Feb 16, 2016 11:34 am
One small thing. The basic volume of the speakers is determined by an input gain pot and an output level switch with four values. In both cases I have to have these on their minimum values or else I am limited in the control I have earlier in the chain. It's not a problem (and certainly doesn't affect my liking for these monitors) but it would be nice if both pot and switch allowed lower values. The Genelec 8030 has just one front mounted volume control and this certainly can go lower than the Neumanns.
ConcertinaChap
Postby Guy Johnson » Sat Mar 05, 2016 11:01 pm
I should have mentioned that the KH 120s are very quiet.
Guy Johnson
Postby Forum Admin » Thu Mar 10, 2016 4:00 pm
Guy Johnson wrote:I should have mentioned that the KH 120s are very quiet.
By "very quiet" do you mean they are not very loud, or that they don't exhibit much background noise?
SEARCH 11,325 SOS Reviews/Techniques articles: www.soundonsound.com/search
Postby Hugh Robjohns » Thu Mar 10, 2016 4:46 pm
:D I'm pretty sure he means the latter! ;)
Postby AdrianTatar » Thu Mar 10, 2016 4:53 pm
ConcertinaChap wrote: The Genelec 8030 has just one front mounted volume control and this certainly can go lower than the Neumanns.
The Genelecs have front mounted volume control but on the rear panel are used dip switches that can't be used without a screwdriver, and this is a model to be used as a mobile device but you are not able to change the settings on different location.
Like Hugh says a few months there is no day and night.
AdrianTatar
Postby Forum Admin » Thu Mar 10, 2016 4:57 pm
Err, just take the screwdriver with you on location too? No biggie...
Postby Mixedup » Thu Mar 10, 2016 5:03 pm
Forum Admin wrote:Err, just take the screwdriver with you on location too? No biggie...
Yes... I do think the title 'engineer' is a little overused these days ;)
Mixedup
Postby ConcertinaChap » Thu Mar 10, 2016 10:46 pm
Hugh Robjohns wrote: :D I'm pretty sure he means the latter! ;)
Quite so. My problem is to get them to be quiet enough ...
AdrianTatar wrote:Like Hugh says a few months there is no day and night.
Que?
PS Actually that's a low shot. I use the 8030s not on the road, which is a normal use for them. Even on the road a ballpoint pen would suffice to make adjustments. They are really excellent monitors. It is a measure of the quality of the KH120s that they are better.
ConcertinaChap
Postby Hugh Robjohns » Fri Mar 11, 2016 12:17 am
Quite so. My problem is to get them to be quiet enough...
I don't really understand why, Chris. With the output level set at 94dBSPL, and the input sensitivity at the minimum -15dB, the actual output level will be 79dB SPL at 1metre with a 0dBu input level.... Which is not loud, and is one of the recommended acoustic reference levels for small rooms.
These Neumann monitors reveal their Germanic design in their precise level calibration options, based on receiving standard reference input levels. And that being the case, have to assume that either you are working with them extremely close to your listening position, you like monitoring at unusually low levels, or your source signal is extremely hot -- and I suspect the last is the most likely.
If you can't adjust the gain structure of the monitoring chain easily, some 10dB inline pads migh make life easier!
Postby ConcertinaChap » Fri Mar 11, 2016 11:17 am
Fair comment. I've got the speakers fairly but not abnormally (I would have said) close and I've calibrated them for my preferred level of 70dB using the volume control of my Apollo 8. As I've said, with the controls on the monitors at minimum it isn't a problem. What would make the issue irrelevant would be if the speaker trim controls on my MC2.1 were actually accessible, but that's also a discussion we've had before :)
Cheers,
Chris
Edited to add PS, it's all trivial stuff really, I don't want to take away from some excellent monitors and an excellent monitor controller.
ConcertinaChap
