Neumann KH 120A monitors
Re: Neumann KH 120A monitors
Postby ConcertinaChap » Tue Feb 16, 2016 11:34 am
One small thing. The basic volume of the speakers is determined by an input gain pot and an output level switch with four values. In both cases I have to have these on their minimum values or else I am limited in the control I have earlier in the chain. It's not a problem (and certainly doesn't affect my liking for these monitors) but it would be nice if both pot and switch allowed lower values. The Genelec 8030 has just one front mounted volume control and this certainly can go lower than the Neumanns.
ConcertinaChap
Postby Guy Johnson » Sat Mar 05, 2016 11:01 pm
I should have mentioned that the KH 120s are very quiet.
Guy Johnson
This is my few words.
Postby Forum Admin » Thu Mar 10, 2016 4:00 pm
Guy Johnson wrote:I should have mentioned that the KH 120s are very quiet.
By "very quiet" do you mean they are not very loud, or that they don't exhibit much background noise?
SEARCH 11,325 SOS Reviews/Techniques articles: www.soundonsound.com/search
Postby Hugh Robjohns » Thu Mar 10, 2016 4:46 pm
:D I'm pretty sure he means the latter! ;)
Postby AdrianTatar » Thu Mar 10, 2016 4:53 pm
ConcertinaChap wrote: The Genelec 8030 has just one front mounted volume control and this certainly can go lower than the Neumanns.
The Genelecs have front mounted volume control but on the rear panel are used dip switches that can't be used without a screwdriver, and this is a model to be used as a mobile device but you are not able to change the settings on different location.
Like Hugh says a few months there is no day and night.
AdrianTatar
Postby Forum Admin » Thu Mar 10, 2016 4:57 pm
Err, just take the screwdriver with you on location too? No biggie...
Postby Mixedup » Thu Mar 10, 2016 5:03 pm
Forum Admin wrote:Err, just take the screwdriver with you on location too? No biggie...
Yes... I do think the title 'engineer' is a little overused these days ;)
Mixedup
Postby ConcertinaChap » Thu Mar 10, 2016 10:46 pm
Hugh Robjohns wrote: :D I'm pretty sure he means the latter! ;)
Quite so. My problem is to get them to be quiet enough ...
AdrianTatar wrote:Like Hugh says a few months there is no day and night.
Que?
PS Actually that's a low shot. I use the 8030s not on the road, which is a normal use for them. Even on the road a ballpoint pen would suffice to make adjustments. They are really excellent monitors. It is a measure of the quality of the KH120s that they are better.
ConcertinaChap
Postby Hugh Robjohns » Fri Mar 11, 2016 12:17 am
Quite so. My problem is to get them to be quiet enough...
I don't really understand why, Chris. With the output level set at 94dBSPL, and the input sensitivity at the minimum -15dB, the actual output level will be 79dB SPL at 1metre with a 0dBu input level.... Which is not loud, and is one of the recommended acoustic reference levels for small rooms.
These Neumann monitors reveal their Germanic design in their precise level calibration options, based on receiving standard reference input levels. And that being the case, have to assume that either you are working with them extremely close to your listening position, you like monitoring at unusually low levels, or your source signal is extremely hot -- and I suspect the last is the most likely.
If you can't adjust the gain structure of the monitoring chain easily, some 10dB inline pads migh make life easier!
Postby ConcertinaChap » Fri Mar 11, 2016 11:17 am
Fair comment. I've got the speakers fairly but not abnormally (I would have said) close and I've calibrated them for my preferred level of 70dB using the volume control of my Apollo 8. As I've said, with the controls on the monitors at minimum it isn't a problem. What would make the issue irrelevant would be if the speaker trim controls on my MC2.1 were actually accessible, but that's also a discussion we've had before :)
Cheers,
Chris
Edited to add PS, it's all trivial stuff really, I don't want to take away from some excellent monitors and an excellent monitor controller.
ConcertinaChap
Postby Hugh Robjohns » Fri Mar 11, 2016 11:36 am
ConcertinaChap wrote:As I've said, with the controls on the monitors at minimum it isn't a problem.
Fair enough. One of the nice Neumann chaps contacted me about this thread and pointed out that the Genelec 8030's front panel volume control goes from about -60dB up to 0 dB of attenuation. In contrast the KH 120 has back panel controls that adjust the sensitivity of the loudspeaker to the input signal. It's a different technical approach. In the view of Neumann (and I agree with them!), volume control should be done at the source. The problem with the 8030 approach is that setting the two loudspeakers in a pair to precisely matched levels is very hard unless you leave the pots on max.
:) Yes... Of course, once set up correctly they no longer need to be accessible -- it's a set once and forget kind of deal -- but I do appreciate how hard they can be to get at when configuring the system initially! I just turned it over and laid it on its lid while setting things up...
Quite right. There is no such thing as perfection! (although I'm very hard pressed to find fault at all with my Crookwood monitor controller or KH310s... :) )
Postby John Willett » Sun Jun 12, 2016 5:18 pm
I used the forerunner K+H O110 for many years (before I upgraded to the Geithain RL906) and compared the O110 to the KH120A when they first came out.
The differences were so minimal that they were almost the same.
The KH120A would still be my No.1 choice for a pair of monitors at the £1k mark.
Numann now do the KH805 sub if you need to go lower than the 53Hz of the 120 - but the 120 are clean and accurate down to the point where they run out of steam.
John Willett
Postby forumuser793939 » Wed Feb 15, 2017 3:49 pm
The genelecs and the Neu's are both very good.
Though I preferred the ADAM A7X in my tests so bought them. They translate very well. They also look a hell of a lot better too. :bouncy:
forumuser793939
Postby Hugh Robjohns » Wed Feb 15, 2017 5:34 pm
Beauty is in the eye of the beholder! :wave: :lol:
Postby ConcertinaChap » Fri Feb 24, 2017 10:46 pm
Nah, much too fussy ... ;)
ConcertinaChap
