Yamaha 02R digital mixing console.
Post your own hardware/software reviews.
Re: Yamaha 02R digital mixing console.
Postby Bme » Wed Apr 24, 2019 10:57 pm
@VTypeV4: That would be great!
Thanks in advance.
But probably I need some more combinations of serial numbers and license codes.
Every help is more than welcome.
Bme
Postby VTypeV4 » Sun May 05, 2019 2:34 pm
UnitY Option License
Serial Number :6300234
Option :M2000 D.C. Set To ON
License Code :LIC5476D48A57341EEEF9C5
Serial Number :6001327
License Code :LIC54C6D48A500FFBEEF935
Option :Finalizer D.C. Set To ON
License Code :LIC54C6D58A500FFBEEF936
BME, let me know how you get on.. Cheers, Matt
VTypeV4
Synkronize Music Group: Mastering House, Multi-track recording and bespoke tuition services.
www.synkronize.co.uk & www.facebook.com/synkronizemusicgroup
Equipped with Yamaha, A&H, JBL, Sony, TC Electronic, DBX and MOTU.
Postby Bme » Mon May 06, 2019 5:12 pm
@ VtypeV4
Thanks!!
I'm quite sure about the missing Finalizer lic code:
License Code :LIC5476D58A57341EEEF9C6
Please try this code and give me feedback if it is accepted in your machine.
I'm still working on the algorithm. Quite a puzzle
By the way: are you sure about the serial number of this card.
Is this number written on the card?
This is the first time I see the serial number starting with 63...
And can you give me the details of the interfaces of your cards (input ADAT and so on)
To others: I can use some more license codes and serial numbers.
Bme
Postby VTypeV4 » Mon May 06, 2019 8:04 pm
This will be superb if you can work it out. :clap:
I have a different card in the other 02R so I'll get the serial from that too - I don't have the codes for it but it seems happy to operate both M2000 and Finalizer sections..
I think the serial is on the load up page - I've got it written down how to check them. And yes, I'm quite sure as I got these straight from TC themselves a few years back after giving them my serial numbers.
Both my cards have the ADAT / TDIF I/O section and have the latest (2.12?) drivers.
The 02Rs are themselves are loaded with the Unity cards in SLOT 3, a standard Yamaha ADAT card in SLOT 1 & 2 and an AES in one and a TDIF in the other installed in SLOT 4, Both run v2.16 operating chips.
VTypeV4
Postby Bme » Thu May 09, 2019 12:08 pm
@VtypeV4
Thanks for your answers.
I'm still working on the codes.
Is the code working which I gave?
Maybe I need the dealer codes as well. These codes can be obtained from the TC unity status screen on the 02R.
@ others: I like to have more license & serial codes. Please help me.
Another question: I have a Digital Surround Panel from Soundware SP02.
A special unit for the Yamaha 02R.
But I have no manual. There is nothing on internet. The company is not responding.
Who can help me?
Bme
Postby VTypeV4 » Fri May 10, 2019 11:44 am
BME, I'll post a proper reply Sun / Mon but thought these may help too.. I'll get the reference codes next week too..
ImageTc serial by VTypeV4, on Flickr
Cheers, Matt :thumbup:
VTypeV4
Postby Bme » Fri May 10, 2019 1:22 pm
@Matt,
Thanks.
The "ST" command gives more details about the card (dealer code and so on).
The second image gives a new serial number (without a license code I presume).
Bme
Postby VTypeV4 » Tue Sep 10, 2019 11:13 pm
BME, not sure if you still frequent the forum - I've got two more Unity cards if you're still interested in code cracking? :SOS:
Image02R unity updates by VTypeV4, on Flickr
This 02R is now a mixing monster! :beamup:
VTypeV4
Postby Bme » Wed Sep 11, 2019 6:50 am
Sure! I’m working on it and I can still use more combinaties of serial codes and licence codes.
Bme
Postby VTypeV4 » Wed Sep 11, 2019 2:22 pm
Ok, brilliant.. I've got the serials on Flickr but it won't let me connect right now (train wifi) so will post when I can. I'm working away for a few days now so I'll do the ST command thing when I get back near the 02r..
Thanks. :thumbup:
VTypeV4
Postby VTypeV4 » Thu Sep 12, 2019 9:17 am
Slot 3 and 4 respectively..
VTypeV4
Postby Bme » Thu Sep 12, 2019 10:28 pm
And do you have the licence codes for me?
Bme
Postby VTypeV4 » Fri Sep 13, 2019 7:41 pm
They weren't supplied with the cards but I'll do the 'ST' command when I get back near them - I'm away till monday..
VTypeV4
Postby VTypeV4 » Tue Sep 17, 2019 3:42 pm
I've hit a stumbling block.. I thought the ST command would display the codes (because they're active) but seems it doesn't, frustratingly. :thumbdown:
The dealer codes are both CF17 but that's about all I can get out of them..
I didn't dare press the initialize button just in case it asked for codes..
What do you think, BME?
VTypeV4
Postby Bme » Tue Sep 17, 2019 4:11 pm
You need only the licentie-codes if you reset the card (sometimes if you change the Batterij).
Or if you want to enable an extra engine on your card.
Are both engines on both cards enabled?
Sometimes the licence codes are written in the manual by hand.
If not, you have to ask the seller.
This issue is the main problem: there is no easy way to discover the codes. TC Electronic doesn’t provider the codes anymore. That’s why I try to find the relation between the serialnumbers and the licence codes.
Hopefully you can provide the combinations.
Bme
Postby VTypeV4 » Thu Sep 19, 2019 10:22 am
Pending a reply from the seller at this point - fingers crossed. :tongue:
VTypeV4
