Yamaha 02R digital mixing console.
Post your own hardware/software reviews.
Re: Yamaha 02R digital mixing console.
Postby Hugh Robjohns » Tue Feb 11, 2020 12:43 am
:D Just goes to show, it's really not the gear that makes the difference! It's the sound going in, and what you do with it! :think:
Postby VTypeV4 » Wed Feb 12, 2020 3:59 pm
Very true, Hugh! :thumbup:
Whilst I'm unlikely to ever win any accolades for my mixing, I'm still very much a fan of my 02Rs after 6-7 years of and the TC Unity cards take them to the next level - I would happily mix anything on them. My DM2000 is very much 'bigger, better and shinier' but the differences between the two (I feel at least) isn't night and day like many would expect.. :clap:
Baily, can you explain your issues in a bit more detail and for pics, use flickr or such similar..
VTypeV4
Synkronize Music Group: Mastering House, Multi-track recording and bespoke tuition services.
www.synkronize.co.uk & www.facebook.com/synkronizemusicgroup
Equipped with Yamaha, A&H, JBL, Sony, TC Electronic, DBX and MOTU.
Postby Kwackman » Wed Feb 12, 2020 4:05 pm
Baily wrote:It recognizes it in Utility - slot 3, but there is only --- --- --- --- at tape 1/2 etc.
I haven't used an 02R in many years, but, can you put the "cursor" over one of those "---", and if so, if you rotate the data wheel, does it give you any choices?
Kwackman
Postby Baily » Wed Feb 12, 2020 4:52 pm
Hi there. Thanks for trying to help me with my 02 R. I can see, that it recognizes the UNIT card, but cant get an input/output. Here is some pictures.
Edited link to display images - JP
Baily
Postby VTypeV4 » Wed Feb 12, 2020 5:50 pm
Configuring the cards isn't the easiest or simplest of tasks and requires a bit of backwards and forwards around the menu system..
Without meaning to insult your intelligence, how did you have it configured before?
The M2000 units are driven from the bus or auxes configurable via the digital i/o page which are then usually selectable on the Unity engines page. As I recall in the inputs to drive the processors are highlighted above 'engine 1' and 'engine 2' and the output options are positioned below.
As for the Finalizer, it needs to be driven as an L/R insert requiring a different config on the digital i/o page. If remember correctly, you'll need to have auxes 6/5 selected on that page then either hold or double press (I can't recall, sorry) and it will give you the insert option.
You'll also find the card better to use running it in 'extended routing mode' so you don't waste any analogue or tape inputs
You can't drive any of the processing straight from the channels - you need to via a bus / aux or insert.
I don't know whether your card is the extra i/o type but the configuration for the outputs are on the digital i/o page whereas the inputs are on the unity page but they have zero processing available other than level control. I use these as FX returns to save mix channels on my 02Rs..
Hope that helps.
VTypeV4
Postby VTypeV4 » Thu Feb 13, 2020 2:13 am
ImageUnity help by VTypeV4, on Flickr
This is the config on my main 'live' 02R although I have one with two TC cards in which was even more convoluted to configure without losing inputs.
Judging by your pictures, I think you need to enable 'Extended Routing' to allow 'internal' returns to be selected on the Unity page. Hope that helps - these things aren't the easiest!
VTypeV4
Postby Baily » Thu Feb 13, 2020 10:19 am
Hi Vtype.
I'm really grateful that you want to help me. The problem is that I can see the UNIT-Y card but the process from the microphone input into the card is wrong. Utility page 2 shows what's installed, but I can't change anything. Otherwise it says mic 1/2 etc. Utility page 5 has an input of 0. Here I can not get signal through. Tried to cut the connexion to Extern, but didnt help. I know that Im doing something wrong.
Can you see the pictures Im sending?
https://imgur.com/a/72QXCal
Baily
Postby VTypeV4 » Thu Feb 13, 2020 1:22 pm
No worries, hope we get it sorted. :thumbup: I can't see your image on the last post, sorry.
I'm assuming your card is an additional i/o unit and the difficulty you're having is getting signal into it and into your mix?
Go to Utility page on the unity card - this one: Access it page by typing '@@' and pressing 'DMP' on the normal Unity screen.
Image02R unity updates by VTypeV4, on Flickr
Once here, type 'IOST' into the command line and this should give the available i/o options so see what that throws up first, please.
If it's an ADAT / TDIF card, you'll need to choose between the two platforms 'in' and the same 'out' but it should show you the current settings on the next line down after typing the above into the command line.
IOAA means ADAT in and out.
IOAT means ADAT in, TDIF out.
IOTA means TDIF in, ADAT out.
IOTT means TDIF in and out.
Type any of the 'IO--' to configure the inputs and outputs how you prefer.
https://warehousesound.com/r/tcUNITYmanual.pdf
Have a look at page 12 in the manual to configure how the console / card process your audio inputs. Because your card is in Slot 3, by using the the 'extended' i/o, you should be able to use your FX returns without losing any mic or tape inputs. If you wanted to use the inputs from your card, you'll need to give up mic inputs 1-8 and configure the input source in the 02R menu system - can't quite remember where that is but I'm sure it's not too buried in the operating system.
Hope that helps. :SOS:
VTypeV4
Postby Baily » Thu Feb 13, 2020 4:11 pm
Hi
It says AES EBU IO card
Baily
Postby DGL. » Thu Feb 13, 2020 6:35 pm
Mike Senior wrote:Just by the by, and not sure whether someone mentioned this already, but as regards the perceived sound-quality deficiencies some people have expressed about the original 02R: Frank Fillipetti recorded and mixed James Taylor's 'Hourglass' on it, winning a Best Engineering Grammy. Even used the built-in preamps, which I've heard a lot of people bad-mouthing.
Which is good enough for me...
:roll:
Although to show their use in a modern genre from ~98/99 onwards till about 2012/3 Scooter used 02r's in their studio, replacing a large MCI? analogue desk. They ended up having about 6 of them for the various rooms, with two in the main studio (and I believe even used live). I will say that the Rick mixed/mastered stuff did always sound pretty good so the 02r's mustn't have been a hinderance.
DGL.
Postby VTypeV4 » Fri Feb 14, 2020 12:04 am
I see lots of arguments on FB on any number of audio pages by 'professional' users (keyboard warriors more like!) suggesting how terrible the sonic quality of even some quite well respected consoles. Typically , the most common subjects are X32 / M32, A&H Qu, Yamaha M7 / Ls9 etc..
Personally, if someone can't get a decent mix out of the above - let alone anything older - then maybe they're in the wrong trade? Ha. :headbang:
I'll stick with my 02Rs - some of my best work has been done with them. :thumbup:
VTypeV4
Postby VTypeV4 » Fri Feb 14, 2020 12:10 am
Baily, I'll have a look at one of my 02Rs tomorrow if you're still struggling. :thumbup:
VTypeV4
Postby Sam Spoons » Fri Feb 14, 2020 12:38 am
While the 02R was not one of them the mag did a comparison of various mic preamps which suggested that pretty much any decent pre is capable of delivering 'release quality' results. No reason to think the 02R preamps should not do so. Once it's past the ADC then it's just numbers........
I have an X32 Compact in the studio and I know it is me not the mic preamps if I fail to deliver.
Postby Baily » Fri Feb 14, 2020 9:39 am
VTypeV4 wrote:Baily, I'll have a look at one of my 02Rs tomorrow if you're still struggling. :thumbup:
Hi my friend
You are my life line to the 02 R :thumbup: :thumbup: :thumbup:
Baily
Postby VTypeV4 » Fri Feb 14, 2020 6:11 pm
It's a shame not everyone sees it like this but yes, I very much feel the same with my Yamahas and A&H.. :thumbup:
Hi my friend
All good man, we'll try to get you sorted! :ugeek:
VTypeV4
Postby VTypeV4 » Sun Feb 16, 2020 11:16 am
Baily, did you manage to get it configured or are you still having difficulty? :SOS:
VTypeV4
Postby Baily » Sun Feb 16, 2020 12:48 pm
VTypeV4 wrote:Baily, did you manage to get it configured or are you still having difficulty? :SOS:
Can you send my a PB, then I can show the picture of this mixer (who makes me feel dumb)
Baily
Postby VTypeV4 » Sun Feb 16, 2020 12:59 pm
You can although I seem to have difficulty with the PM thing on here - alternatively email me with pictures? Either or both is fine..
VTypeV4
Postby VTypeV4 » Sun Feb 16, 2020 7:42 pm
There's some more Unity Cards back in service now - brilliant. :SOS:
VTypeV4
