Yamaha 02R digital mixing console.
Post your own hardware/software reviews.
Re: Yamaha 02R digital mixing console.
Postby VTypeV4 » Wed Apr 01, 2020 8:20 pm
I too am from the live scene - I've been doing it for the best part of 20 years. My digital story started about ten years ago with a friends Soundcraft 328XD - great sounding console. The association with the 02R goes back almost as far and both the Yamaha and the Soundcraft got me into live multi-track recordings using a PC and MOTU interfaces.
ImageIMG_20200329_214141 by VTypeV4, on Flickr
ImageIMG_20200329_213446 by VTypeV4, on Flickr
My two 'live' consoles are dormant in a small local venue but my super jacked up 'home' console (dual unity) has been brought into service with a mini home setup. :bouncy:
VTypeV4
Synkronize Music Group: Mastering House, Multi-track recording and bespoke tuition services.
www.synkronize.co.uk & www.facebook.com/synkronizemusicgroup
Equipped with Yamaha, A&H, JBL, Sony, TC Electronic, DBX and MOTU.
Postby hinnerker » Thu Apr 02, 2020 7:29 am
Nice setup !
I also want to use a "double Unity" - Setup with the "Finalizer" TC card as an Insert in the LR sum and the second card with the M2000 Software as an intern FX Unit.
But at the moment i have problems to setting the things up. I can use the Finalizer Card as an LR Insert in SLOT 3 with extended routing, but i dont understand the signal flow with the M2000?
Both cards (M2000 and the Finalizer card) are without I/O extensions.
Could you give me a hint, which card i should establish in which Slot and how to setup the routing for the both M2000 engines on the other card.
I dont understand the routings for the M2000 card. I want to use this card with AUX 1 and AUX 2 without lost of Input channels. Until now i could establish the M2000 card only in Slot 3 with extend routing and get my constellation working with AUX 1 and AUX 2 as the Input and routing directly to LR sum.
Its a mess with the routings of the consol, if you are familiar with analog desks...
We had simply some cables to route any effect to any Return Channel... :thumbup:
The manual i do have are incredible about describing the Routing options with the cards.
Would be great, if you can show me your Setup of the Dual TC card desk on the I/O section and the routings.
Another last point about the software. Do you have newer Software for the TC Cards?
I do have the 2.11 Software now on the card but i read, there is a newer software ?
What did change ?
Should i also change the Eproms to V2.16 instead of V2.15 at the moment?
What are the changes?
Sorry for all the questions... but i hope i can save a lot of time in researching all the things.
There are enough other things i want to change on the desk (for example adding direct outs/Inserts for Channel 9-16 to connect my Motu devices. I already studied the service sheets with the PCB and there could be a simple solution to get more direct outs. Normally the desk has only 8 Inserts on the first 8 Channels and i am going to solder 8 additional Jacks for the Channels 9-16 to connect 1-16 to the Motu. In most cases this should be enough for my needs. I have also 3 ADAT Cards coming with the desk, but i dont want to make things more complicated with more and more Outboard gear.
I have tried to connect the 3 Adat cards with my second Motu (a 2408 with 24 Channels of ADAT) but this makes things not easier for me :lol:
I also do own 2 x Lexicon Nuverb cards (each on an old Mac, the Nuverb cards are the same hardware like a Lexicon 300 !!) with a ADDA converter (Flying Cow) i plan to use in the future.
That would be a lot of work to realize all the things... so i want to spent not more time in finding the optimal routing in the Yamaha desk for the 2 TC Cards. :thumbdown:
Thanks for your reply and i am happy to find a collegue from "Live Business"... :lol:
Regards
Henry
hinnerker
Postby VTypeV4 » Thu Apr 02, 2020 10:40 am
Looking good so far..
This is taken from another person I helped earlier this year..
"Go to the digital i/o pages (3/5), select slot 3 and make sure AUX 1-8 are highlighted - centre row of options..
With that done, now go to the main Unity control page (MIDI 5/5). At the bottom of the page, make sure 'EXT.RT' is highlighted.
Above each engine is the source of audio for them. You should be able to select a different aux for each one - I use aux 5 for engine one and aux 6 for engine 2 although you can pick any it allows you to.
Now, below the engine selections are the routing returns, I simply select ST LR so the 17/18 and 19/20 faders and their respective 'on' buttons control the returns of each engine straight into the L/R bus of the 02R.
This configuration will work for the dual M2000"
Because your cards don't have the external I/O, configuration might be a little trickier. I'd put your 'M2000' card in slot three and run it 'extended routing' mode so you can return the FX to L/R (as above) then the 'Finalizer' card in slot four..
"To use the finalizer, you'll need to go to Digital i/o page (3/5) again and where you previously had all the auxes selected. De-select auxes 5-6 by selecting the ST L below aux 5 and then double clicking it. By doing that, it should change the selection from 'ST L' to 'Ins L' and the one next to it to 'Ins R'..
Once you have this sorted, load one of the finalizer pre-sets on one of the engines (I think it's usually engine 2) then change the routing on the main Unity page. You need to select the input on that engine to 'Ins LR' (above the engine select) and it's output (below engine select) to 'ST LR'..
I haven't got an 02R in front of me so this is mainly from memory - I think this is all correct but I'll have a look later if you struggle.
Make sure you have a preset saved on your 02R for both configs - it's much easier than re-routing every time you need the 'other' config"
Hope that helps. ;) I'll address the other questions a little later.
Best of luck! :thumbup:
VTypeV4
Postby hinnerker » Fri Apr 03, 2020 7:34 am
Thanks for the reply...
You wrote:
"To use the finalizer, you'll need to go to Digital i/o page (3/5) again and where you previously had all the auxes selected. De-select auxes 5-6 by selecting the ST L below aux 5 and then double clicking it. By doing that, it should change the selection from 'ST L' to 'Ins L' and the one next to it to 'Ins R'.."
Doesnt work with two card configuration. If i take my Finalizer - Card "standalone" in SLOT 3, the routing you described works correct since weeks in my desk, but with the second card (both M2000 engines activated) i didnt find a way to establish both cards (the Finalizer should work as an Stereo Insert "pre Fader" and the M2000 Card with either Aux 1&2 / 3&4 / 5&6 / 7&8 as input and routed directly to LR Stereo su.
The aim is, to have both FX Engines on the AUXilliaries as Input and the Finalizer Card as a "Master EQ" inserted.
I have ordered now ODD/EVEN Roms with Version 2.16 OS, so maybe its a question of the OS why this doesnt work on my desk.
Which Version you are using in your desk?
Regards
Henry
hinnerker
Postby VTypeV4 » Sat Apr 04, 2020 12:19 pm
Hi Henry..
I'm unaware of the detail differences between v2.15 and v2.16 EPROM - I've never had the earlier version. I've also only had v2.12 of the UNITY software too..
I'm not sure why it won't let you do both given the cards are in different configs.
I can understand it not letting you share aux across the cards but the fact you're using one as in insert and the other as send / return, I can't understand. To drive my cards, I have to use aux 1 & 2 and 5 & 6 - I'll see if it let me do the Finalizer insert later..
It's such a shame you can't run both in extended routing mode as that would make life so much easier!
VTypeV4
Postby hinnerker » Sun Apr 05, 2020 12:40 pm
oh, you have got the Version 2.12... any possibility to get the software package?
Maybe they have changed someting, what makes life easier for me?
I can establish each card "standalone" the Finalizer as an Insert with return to ST.
Works perfect with the two Stereo channel - pairs 17/18 and 19/20 if i Flip to the Finalizer Engine. But this works only if extended routing is activ.
The M2000 card works with both engines also if card is in extended routing. If not, i can not select anything else , only 5/6 Out or 7/8
So i dont understand the whole routing section...
What does it mean, if only these two pairs are selectable... Where i find the FX returns from the engines if Out 5.6 or 7.8 is selected?
hinnerker
Postby VTypeV4 » Wed Apr 08, 2020 5:06 pm
I've just had a flick through the manual and it seems that your returns (because you can't run two cards in EXT.RT mode) are trying to return on your analog inputs 5/6 and 7/8..
You'll need to go to the DI/O page and find where the input source is selected, then enable in the inputs from that respective slot - you should then have your returns albeit at the expense of analogue inputs.
Those returns are also normally available at the card out but you won't be able to 'see' them as I think you said neither Unity has the I/O port. The only reason I haven't had to give any analogue inputs up is that A: only use the M2000 processing and B, I take the returns out of one of the cards and return into the other via the ADAT port then use the 'extra' 8 inputs (only on additional I/O cards) to return them..
Sorry that's so very convoluted. :headbang:
ImageIMG_20200308_001119_resized_20200308_121231200 by VTypeV4, on Flickr
VTypeV4
Postby hinnerker » Thu Apr 09, 2020 3:05 pm
Another Question...
is there any chance to route the M2000 Outs via ADAT to my Motu 2408 V1 and analog back for example analog inputs 21/22 and 23/24 into the desk?
The Motu do have 3 banks, A, B, C with 8 Channels each. On bank could be mirror to analog!
Maybe that could be a way?
Regards
Henry
hinnerker
Postby VTypeV4 » Thu Apr 09, 2020 5:08 pm
To put it simply, no, sorry..
You can only output the M2000 returns internally - the only way to route it 'out' would be via the outputs of that card and given your cards don't have the additional I/O, you're stumped, sadly..
VTypeV4
