Yamaha 02R digital mixing console.
Re: Yamaha 02R digital mixing console.
Postby Wintersun Project » Mon Jan 07, 2019 10:53 pm
Bitter is reading a FULL 24 bit on recapture, no loss of bits, and the audio sounds pristine
im going to have to use something much more surgical to make sure though.
Wintersun Project
Postby Wintersun Project » Tue Jan 08, 2019 10:00 am
oops
Wintersun Project
Postby Wintersun Project » Tue Jan 08, 2019 1:43 pm
MusicScope confirms im getting the dynamic range of 24 bit and there are no unused bits at 24 bit, no blue bits showing at all on the analysis.
so basically im getting 24 bit data out of those TDIF-II cards.
Back through lightpipe and back into my UAD Apollo, super clean no noise.
However, using the yamaha lightpipes is a totally different kettle of fish
they will not do 24 bit without the split and reassemble trick yamaha use.
Ive also bounced a 20bit audio file through as 24 bit and it shows 4 blue unused bits on the play through, so i dont know what the crack is here, all i can say is, if you used the TDIF 2 cards and flick the 24 bit dip switches on im getting fully usable 24 bit I/o with a full channel count, none of this half the channels garbage ! Certainly no noise, i cant find any noise on the capture at all, even fully cranked on the focals !
One things for sure, it sounds great so im going to just get on with using it from here without worrying one way or the other, like Hugh pretty much said, its more than good enough to do the necessary whatever the weather :)
Wintersun Project
Postby Hugh Robjohns » Tue Jan 08, 2019 4:58 pm
Wintersun Project wrote:...all i can say is, if you used the TDIF 2 cards and flick the 24 bit dip switches on im getting fully usable 24 bit I/o with a full channel count...
Well, that's a good result, and it makes sense, and 20 bits via ADAT is perfectly workable and really won't be inferior to most 24-bit converters' performance anyway!
Postby VTypeV4 » Wed Jan 09, 2019 11:30 am
Wintersun Project wrote:One things for sure, it sounds great so im going to just get on with using it from here without worrying one way or the other, like Hugh pretty much said, its more than good enough to do the necessary whatever the weather :)
This, exactly this. I couldn't agree more. It's great to see there's at least one other person happy with the results from their 02R. :thumbup:
VTypeV4
Synkronize Music Group: Mastering House, Multi-track recording and bespoke tuition services.
www.synkronize.co.uk & www.facebook.com/synkronizemusicgroup
Equipped with Yamaha, A&H, JBL, Sony, TC Electronic, DBX and MOTU.
Postby manfromplanet » Wed Mar 06, 2019 12:35 pm
I never looked at it this way : "Conventional 32-bit floating point desks have to pass 24 bit audio mantissas between signal processing stages, whereas a fixed point desk can maintain longer word-lengths throughout the signal processing chain... so there is less need for interstage rounding/dithering and that may well retain low-level detail that is lost in floating point systems" Interesting thought as I have read and thought I understood the details between floating and fixed point... but that statement makes more sense that anything else I have read about it. Any way, I came back here to see if this conversation was still on.
I am glad to see that there is some love for the 02r out there... if you look at some other forums you hear the term "boat anchor" and "door stop" used quite a bit.
I will just say that the 02r's capabilities are better than anything I have to give it... and leave it at that. and I wanted to try this emoticon:
:beamup:
MPX
manfromplanet
Postby VTypeV4 » Sun Mar 10, 2019 1:20 am
I too am pleased there's both a current-day discussion and some love for them. :bouncy:
Whilst they'll never hit the legendary status of something like a Fender Strat or Vox AC30, I do feel they deserve their own place in both history. Maybe I'm biased a little because of my personal involvement with these things over the last 5 years or so but I still feel they're capable and relevant.
ImageXs 02r 19 by VTypeV4, on Flickr
Two of the three I own in operation at work this weekend - March 2019.
VTypeV4
Re: Yamaha 02R digital mixing console. TC unity license
Postby rexomatic » Sat Mar 30, 2019 8:39 am
Hi All
I have the 02r with ADAT etc, love it
Also has the unity card but I need a license to recall alot of the stuff there - I can use a few of the finalizers but not much else
Manufacturer drew a blank with generating a license - does anyone know where I can get a license please?
Best
R
rexomatic
Postby VTypeV4 » Sun Mar 31, 2019 9:33 am
I don't think TC do them anymore which is a frustration..
It was suggested (I can't recall where) that you can reset the memory on Unity cards by taking the battery out briefly. This apparently will give you both licenses for 100 hours of service - when it runs out just reset and go again.. It's a bit inconvenient to pull it apart - maybe you could leave the battery out although saving things might be a nightmare?
It's a pain TC don't really support them anymore but because they still sound so good, it's hard to remember they're 20 years old. IMO they sound at least as well if not better than my M1 unit..
Hope you have some success and sorry I can't be much help but the above might give you a solution for the short term. :thumbup:
VTypeV4
Postby Mike Stranks » Thu Apr 04, 2019 3:04 pm
Gentlemen: As someone who spends most of his time at the shallow-end of the forum helping newcomers become more-proficient swimmers, can I say what a pleasure it's been to venture up to the deep-end and read your learned and civilised discourse. :)
Thanks! :thumbup:
Postby VTypeV4 » Fri Apr 05, 2019 2:54 pm
Thanks, Mike. :clap: :SOS:
VTypeV4
Postby Bme » Sat Apr 20, 2019 10:55 am
Hello folks,
I've a couple TC unity cards for my 02R console.
Unfortunately I lost the license codes.
I tried TC electronic but they destroyed their codegenerator and their archive.
Now I'm reengineering; based on the serial number I try to find out the license code.
But I need some valid licence codes (M2000 and/or Finalizer) with the according serial numbers.
Who can help me with this information.
If I found out I can probably help others who also lost their license code or maybe want to enable the M2000 or Finalizer.
Thanks.
Bme
Postby VTypeV4 » Sun Apr 21, 2019 11:30 pm
I'll fish mine out in the next few days, this might be helpful if you can work it out.. :bouncy:
VTypeV4
Postby Bme » Wed Apr 24, 2019 10:57 pm
@VTypeV4: That would be great!
Thanks in advance.
But probably I need some more combinations of serial numbers and license codes.
Every help is more than welcome.
Bme
Postby VTypeV4 » Sun May 05, 2019 2:34 pm
UnitY Option License
Serial Number :6300234
Option :M2000 D.C. Set To ON
License Code :LIC5476D48A57341EEEF9C5
Serial Number :6001327
License Code :LIC54C6D48A500FFBEEF935
Option :Finalizer D.C. Set To ON
License Code :LIC54C6D58A500FFBEEF936
BME, let me know how you get on.. Cheers, Matt
VTypeV4
