Yamaha 02R digital mixing console.
Re: Yamaha 02R digital mixing console.
Postby VTypeV4 » Tue Sep 10, 2019 11:13 pm
BME, not sure if you still frequent the forum - I've got two more Unity cards if you're still interested in code cracking? :SOS:
Image02R unity updates by VTypeV4, on Flickr
This 02R is now a mixing monster! :beamup:
VTypeV4
Synkronize Music Group: Mastering House, Multi-track recording and bespoke tuition services.
www.synkronize.co.uk & www.facebook.com/synkronizemusicgroup
Equipped with Yamaha, A&H, JBL, Sony, TC Electronic, DBX and MOTU.
Postby Bme » Wed Sep 11, 2019 6:50 am
Hi,
Sure! I’m working on it and I can still use more combinaties of serial codes and licence codes.
Bme
Postby VTypeV4 » Wed Sep 11, 2019 2:22 pm
Ok, brilliant.. I've got the serials on Flickr but it won't let me connect right now (train wifi) so will post when I can. I'm working away for a few days now so I'll do the ST command thing when I get back near the 02r..
Thanks. :thumbup:
VTypeV4
Postby VTypeV4 » Thu Sep 12, 2019 9:17 am
Slot 3 and 4 respectively..
VTypeV4
Postby Bme » Thu Sep 12, 2019 10:28 pm
And do you have the licence codes for me?
Bme
Postby VTypeV4 » Fri Sep 13, 2019 7:41 pm
They weren't supplied with the cards but I'll do the 'ST' command when I get back near them - I'm away till monday..
VTypeV4
Postby VTypeV4 » Tue Sep 17, 2019 3:42 pm
I've hit a stumbling block.. I thought the ST command would display the codes (because they're active) but seems it doesn't, frustratingly. :thumbdown:
The dealer codes are both CF17 but that's about all I can get out of them..
I didn't dare press the initialize button just in case it asked for codes..
What do you think, BME?
VTypeV4
Postby Bme » Tue Sep 17, 2019 4:11 pm
You need only the licentie-codes if you reset the card (sometimes if you change the Batterij).
Or if you want to enable an extra engine on your card.
Are both engines on both cards enabled?
Sometimes the licence codes are written in the manual by hand.
If not, you have to ask the seller.
This issue is the main problem: there is no easy way to discover the codes. TC Electronic doesn’t provider the codes anymore. That’s why I try to find the relation between the serialnumbers and the licence codes.
Hopefully you can provide the combinations.
Bme
Postby VTypeV4 » Thu Sep 19, 2019 10:22 am
Pending a reply from the seller at this point - fingers crossed. :tongue:
VTypeV4
Postby VTypeV4 » Fri Dec 13, 2019 12:57 am
BME, I put a post here too - maybe that will shed some light?
https://www.facebook.com/groups/1494173914205235/
I changed the battery on one of the Unity cards this evening but hooked up a dummy battery to keep the memories / codes intact..
VTypeV4
Postby digis5000 » Thu Jan 16, 2020 2:31 pm
recently, i changed the battery of the Unity card. Now, it shows "No valid Software found on the Unity card, please upload...". Does anybody have the Upload Software "TC-Unity Software.asp", so i can upload via 02R Host port?
digis5000
Postby VTypeV4 » Thu Jan 16, 2020 7:26 pm
PM me your email - not entirely sure if it's what you'll need but I'll send it over - I downloaded this folder a while back from the TC site.. :SOS:
I changed the battery on one of mine a few weeks back but hooked up a temporary battery to the terminals whilst I had the old one out just in case it threw a wobbly - I appreciate that doesn't help you now but might be worth considering for next time.
Lastly, not sure what version of Windows you're running but last time I used the software, it was on XP..
Best of luck. :thumbup:
VTypeV4
Postby digis5000 » Fri Jan 17, 2020 4:03 am
here is a license code:
UnitY Option License
Serial Number :6300270
Option :Finalizer D.C. Set To ON
License Code :LIC5476D58A57343AEEF9E2
digis5000
Postby VTypeV4 » Fri Jan 17, 2020 6:54 pm
Files sent so let us know how you get on - best of luck. :thumbup:
VTypeV4
Postby VTypeV4 » Fri Jan 17, 2020 6:57 pm
Serial Number :6000973
Option :M2000 D.C. Set To ON
License Code :LIC54C5D48A570F19EEF9AA
Serial Number :6000801
License Code :LIC54C4D48A500FF5EEF905
Serial Number :6002353
License Code :LIC54C2D48A500FE5EEF933
For anyone who is good at cracking codes?
VTypeV4
