Fame MS 58 Mk II Dynamic Microphone.
Re: Fame MS 58 Mk II Dynamic Microphone.
Postby Wonks » Wed Sep 19, 2018 3:57 pm
Modifications made to the MS 58; pin 1 (ground) linked just to the XLR screw tab, Pin 2 (+) black wire, pin 3 (-) red wire.
This has made a significant difference to the mic. The output signal level is now about equal to the SM58 and all the noise has gone.
The Fame MS 58 Mk II now sound a lot closer to the SM58. The MS 58 still sounds slightly brighter to my ears, and more prone to sibilance and has the more obvious handling noise.
I've re-done the frequency response charts (using white noise this time which I should have done before) and they now look closer. The previous sub-60Hz response peak on the Fame MS 58 has now gone. (I did also use pink noise for comparison as I'd used that before and the LF peak was gone from that as well). The mics were again positioned in between the main driver and tweeter, 10 cm from the monitor. Note that these are rough graphs and the results would look slightly different given perfect test conditions, but I think they are good enough for a comparison.
Here's the Fame MS 58 Mk II.
And here's the Shure SM58.
The Fame still shows higher frequency peaks than the SM58, and the dip in the response from approximately 4.5kHz to 6.5kHz is a lot greater than the dip in the SM58's response between approximately 6kHz and 8kHz. With my voice, the mics showed similar response to plosives, but the Fame sounded overall a little bit brighter and suffered more with sibilance. Please note that I can't hear above 10kHz any more so the mics may sound more different to those with better ears than mine.
I've also done a voice recording comparison between them with my mouth about an inch away from the mic. Here's a straight, no processing at all version:
https://soundcloud.com/stormy-simon/shu ... 8-straight
And here's one with a 12 db/octave 100Hz high pass filter on, as most live desks would have one one so this would be a more realistic vocal sound from a PA:
https://soundcloud.com/stormy-simon/shu ... -hp-filter
The SM58's body is filled with epoxy and a transformer, which partly explains its increased weight over the Fame. But that epoxy is probably also responsible for helping damp the mic body, resulting in a lower handling noise than the Fame. The SM58's handling noise was quite low in frequency, so would lessen when a HP filter was used, whereas the Fame's handling noise was maybe twice as loud and generally of a much higher frequency, so less likely to be reduced with a HP filter. You probably wouldn't notice it being hand-held in a loud rock track, but it's more likely to stand out with a singer hand-holding the mic in a piano accompanied ballad.
What I haven't been able to do yet is see how feedback resistant it is in a live situation. Or know whether it has the robustness of a real SM58 and will still be working in 20 years despite looking severely beaten up.
I omitted mentioning a few minor things that I planned to in the initial review, so here they are for completeness.
1) There is no polar pattern diagram for the mic at all. The mic is simply described as 'unidirectional'.
2) The mic came supplied with a 5/8" threaded plastic mic clip, very much like a Shure clip, but there was no 5/8" to 3/8" adapter included.
3) There was no plastic pouch for the mic supplied, as is often the case.
So I really need to revise my opinion of the Fame MS 58 from my initial opinion. It definitely needs converting to balanced operation and ensuring that the shell is grounded; which if you can use a soldering iron, is a matter of a few minutes. It will be slightly brighter sounding than an SM58, which will be good for some voices and bad for others, but probably nothing turning down the treble on the desk couldn't cope with. It's going to be best left on a stand rather than being hand-held.
So for a £17.20 vocal mic when on a tight budget, then providing you can modify it, I think it's doing OK. I'd still recommend going for some of the more professional budget offerings such as the AKG D5, which is under £70 and regarded by many as a lot better than an SM58, but if you've only got £25 spare and you need a stage mic, then given basic soldering skills, then it's going to be useable.
Postby Janneman » Wed Sep 19, 2018 4:09 pm
Thank you Wonks for this nice review and lot of work.
Janneman
Kind regards,   Jan van Duren
Postby Hugh Robjohns » Wed Sep 19, 2018 4:27 pm
:thumbup: :clap: A worthy investigation. Thanks Wonks.
Postby Rich Hanson » Wed Sep 19, 2018 4:31 pm
And you owe a qualified apology to it for saying it is worse than a C1000 :bouncy:
Rich Hanson
Postby Wonks » Wed Sep 19, 2018 4:57 pm
Well, as bought, it was. As modified, it's probably a bit better than one. Though you'd never knock a nail in with it. :D
Postby Rich Hanson » Thu Sep 20, 2018 8:54 am
Wonks wrote:Well, as bought, it was. As modified, it's probably a bit better than one. Though you'd never knock a nail in with it. :D
Challenge accepted :-D
Rich Hanson
Postby ManFromGlass » Thu Sep 20, 2018 1:19 pm
Great stuff, Mr. Wonks!
Will it survive immersion in a half pint of beer? (This is not a dare :headbang: )
Postby Wonks » Thu Sep 20, 2018 1:34 pm
That's a waste of half a pint of good beer!
Postby blinddrew » Thu Sep 20, 2018 1:40 pm
Doesn't have to be good beer, you can use Carling for testing purposes.
Postby Wonks » Thu Sep 20, 2018 1:45 pm
There are limits to what I will buy!
Postby Wonks » Mon Sep 24, 2018 1:10 pm
Errata: I've just realised I'd got the XLR pinout wrong, and had pins 2 and 3 crossed over in the photo-mark-up and text. So the red wire does go to pin 2 and the black wire to pin 3.
Sorry chaps.
Postby Hugh Robjohns » Mon Sep 24, 2018 5:37 pm
Doh! I should have spotted that -- pin 3 is always the one in the middle on an XLR! :headbang: So that makes much more sense -- black as the cold side and red as the hot. :-)
Postby Wonks » Mon Sep 24, 2018 6:15 pm
Though Shure use red and blue, with blue to pin 2 (+) and red to pin 3 (-).
