Leader opinion - May 2018 and Speaker Measurements
For feedback and suggestions about the SOS magazine, app, web site or forums.
Re: Leader opinion - May 2018 and Speaker Measurements
Postby blinddrew » Fri Jun 01, 2018 11:46 am
Phil Ward wrote:
desmond wrote:
Phil Ward wrote:As mentioned, the paper, or an edited version of it, did indeed appear in the final and hen's teeth rare issue of Studio Sound magazine. I've no idea if anybody complained about it, although doing so would have been somewhat academic as the magazine had already closed by the time anybody got to read the piece. Having said that, I also vaguely remember that the final issue of Studio Sound was printed in very small numbers so only its advertisers got a copy (and hence had to pay their ad fees). No actual readers or subscribers ever clapped eyes on it.
This one?
Studio Sound, December 2001 (final issue)
http://www.americanradiohistory.com/Archive-Studio-Sound/00s/Studio-Sound-2001-12.pdf
Page 44, "Why the NS10?" article...
Yeah, that's the one. I had no idea it was available on line.
P
Just had a read, thanks Phil and Desmond. :)
Postby desmond » Fri Jun 01, 2018 11:56 am
blinddrew wrote:Just had a read, thanks Phil and Desmond. :)
Almost the full collection of Studio Sound is available there - one of the reasons why I wouldn't consider it for mu:zines - and there's a wealth of stuff there. If I didn't have, ugh, other magazines* to read, I'd like to dip into the content of those for sure...
* Currently, issues of International Musician from 1975 - which is a whole other world for me...
Postby Hugh Robjohns » Fri Jun 01, 2018 12:07 pm
It's a useful resource, but such a shame the scans are so awful -- it makes a lot of the detail from adverts and diagrams unintelligible.
Postby Phil Ward » Fri Jun 01, 2018 1:24 pm
Oh god now I'm going to have to try and resist reading old bass guitar reviews and features in International Musician.....
Phil Ward
Freelance audio product designer/writer: https://musicandmiscellany.com Hi-Fi Prints: https://audio-icons.com
Postby Phil Ward » Fri Jun 01, 2018 1:35 pm
Hugh Robjohns wrote:
In the professional TV/film world, the monitor screens are graded to indicate their quality and resolution, with the very best and most accurate being 'grade 1'. I wish we did the same for loudspeakers. The monitors you describe above would be 'grade 3' (or lower)... they make noise, but they are severely compromised!
Yes Hugh that'd be cool. Maybe we should do something like that in the reviews?
Have you seen this:
https://www.thxstandard.com/#!/category ... rs/sub/40/
THX has started publishing tests on active nearfield monitors and calculating an overall "score" for each one. I think they're doing a reasonably job of it except for one fatal elephant/room error – it's all frequency domain. As you might imagine, I've been in touch. They responded with, "We agree that adding time domain parameters will augment the frequency domain characterization and it is something we are considering for the future." I wonder if anything will happen :-)
P
Phil Ward
Postby Hugh Robjohns » Fri Jun 01, 2018 4:02 pm
THX are all about their 'standards' and documenting things so they can charge for a 'THX-approved' marker on manufacturers' products that the hi-fi and home-cinema markets seem to value.
Personally, I've never been convinced that their standards are quite all they should be though -- they are often quite narrowly focused in a way that limits their true value IMHO, and this is a classic case in point!
Still, at least they rate speaker self-noise (kind of) which will please Dave! :lol:
Postby James Perrett » Fri Jun 01, 2018 7:44 pm
Hugh Robjohns wrote:I know Andrew is special, but he isn't unique -- even I got a copy of that final issue! :-D
I've just been out to the garage to check my collection of Studio Sound mags to confirm that I'm definitely B-list (it ends at November 2001). :(
On a different note - didn't the BBC have grade one and grade two monitors? As I understand it, model numbers starting LS5 were grade one while models starting LS3 were grade two.
Postby Hugh Robjohns » Fri Jun 01, 2018 8:47 pm
The Beeb certainly designated different designs as grade 1 or grade 2 monitors. Grade 1 was supposed to be a necessity when assessing the placing of mics, for mixing, and for quality assessment, while grade 2 speakers could be used in less critical roles (eg, production monitoring)
However the LS3 and LS5 terms originally denoted the speaker's intended application. LS3 speakers were for use in OB trucks and small edit-suites where space was restricted, while the much larger LS5 speakers were for studio control rooms and studio floors.
There were several cases where the same basic design was designated with both LS3 and LS5 numbers, because their physical form or finish was optimised for OB or studio use. For example, the LS5/1 was the studio version of the LS3/1. The 3/1 had the (dual) tweeters mounted in front of the woofer and the cabinet was painted in Hammerite grey, while the 5/1 used the same drivers, but placed vertically one above the other on the larger baffle, and had a veneered cabinet. Similarly, the LS5/11 and LS3/4c are closely related ceiling corner speakers for studio (VT suites, mostly) and OB truck applications.
As it happens, the LS5/8 was indeed a grade 1 (as was the 5/11), while the LS3/5 (and 3/4c) were grade 2s, which may be where the confusion comes from... although, even more confusingly, the numbering policy got a bit muddled in the later years when all OB and studio designs were lumped together under the LS5 designation, including the Beeb's final two in-house models, the 5/9 and 5/12.
Postby James Perrett » Fri Jun 01, 2018 9:48 pm
Thanks for the explanation Hugh - my knowledge of BBC monitors is limited to the well known ones - hence the confusion.
Postby The Red Bladder » Sun Jun 03, 2018 2:04 am
Hugh Robjohns wrote: I know Andrew is special, but he isn't unique --
Someone who works here (a young woman) said only yesterday that I was 'inspirational' and that my brain seems to work differently to other people. I was so taken aback that I completely forgot to get her to expand on that topic. I would have loved to have heard more!
This was over a spicy Arabic dish with all the trimmings that I made for the gang, as work kept noses to the grindstone until 10pm. Perhaps the more exotic spices I used had somehow effected her - who knows!
But it just goes to show that you are not the only person to have noticed that I am special! Word is beginning to spread!
The Red Bladder
Postby Hugh Robjohns » Sun Jun 03, 2018 3:05 pm
:lol: :thumbup:
