Is This Legal?
For feedback and suggestions about the SOS magazine, app, web site or forums.
Re: Is This Legal?
Postby Dave B » Wed Jan 22, 2020 9:53 am
N i g e l wrote:My gateway is on a time switch*, 1/2 for security & 1/2 to give me a hint that its time for bed and the internet will still be there tomorrow night .
But somebody might be wrong on the internet _right now_ ... how can you sleep knowing that??? :shocked: :shocked: :shocked:
:bouncy: :headbang:
Dave B
Re: Is This Legal?
Postby Folderol » Wed Jan 22, 2020 10:42 am
:bouncy: :headbang:
https://www.xkcd.com/386
Nuff sed?
Re: Is This Legal?
Postby ConcertinaChap » Thu Jan 30, 2020 8:31 pm
Folderol wrote:I've also got into the habit of switching my router off at random intervals.
According to a BT engineer I was talking to once the exchange will interpret this as problems on the line and will reduce the speed of your connection in an effort to reduce the disconnections.
ConcertinaChap
Re: Is This Legal?
Postby Folderol » Thu Jan 30, 2020 8:43 pm
I think that applies to frequent disconnects, not one every few days (or even a week or two).
Re: Is This Legal?
Postby ConcertinaChap » Thu Jan 30, 2020 9:10 pm
The engineer didn't specify so you might be right. OTOH you didn't say how often you switched off ;)
ConcertinaChap
Re: Is This Legal?
Postby Martin Walker » Thu Jan 30, 2020 11:30 pm
I had a power cut a month or two back , and my download speed had dropped by about 30% when the power returned a few seconds later.
So, in my experience, a single blackout can indeed be interpreted as a serious problem on the line :headbang:
Re: Is This Legal?
Postby N i g e l » Fri Jan 31, 2020 12:55 am
:bouncy: :headbang:
Nuff sed?
Wow ! who could have known ? There *ARE* wrongs on the WWW but ....the WWW is still here, days later. If I was a Bot the logic would explode my brain.
Sensibly, I will give the timer an extra 5 minutes and have a serious think about the situation. :headbang:
Re: Is This Legal?
Postby Rich Hanson » Fri Jan 31, 2020 4:08 pm
I have been told by a usually reliable source that if you are going to disconnect from your ADSL you need to leave it for at least 20 to 30 minutes, anything shorter will be interpreted as a fault, with a drop in speed to try to fix it - as you have discovered. A long disconnect will lead to a full re-negotiation of the connection once the router is reconnected, and sometimes can lead to a slightly faster speed. YMMV.
Rich Hanson
Re: Is This Legal?
Postby ManFromGlass » Fri Jan 31, 2020 4:20 pm
Being on satellite is like a giant party line. One of the tricks when speeds drop is to shut the system off for 60 seconds. When rebooted one is supposedly closer to the front of the line and speeds return to normal. Satellite is still crap and speeds fluctuate every 5 minutes. Satellite is the only option unless I want to build 110 foot tower to get above the trees.
Re: Is This Legal?
Postby Martin Walker » Fri Jan 31, 2020 6:17 pm
Rich Hanson wrote:I have been told by a usually reliable source that if you are going to disconnect from your ADSL you need to leave it for at least 20 to 30 minutes, anything shorter will be interpreted as a fault, with a drop in speed to try to fix it - as you have discovered. A long disconnect will lead to a full re-negotiation of the connection once the router is reconnected, and sometimes can lead to a slightly faster speed. YMMV.
Actually, that ties in with my experience as well - I also disconnect all my gear from the mains if I go on holiday (typically a week away), and on several occasions when I reconnect and boot up my connection speed has been better.
Must try that again overnight to see if I get an improvement :thumbup:
Users browsing this forum: ef37a
