Feb 2020 - Making Sense of Speaker Specifications - graph confusion.
For feedback and suggestions about the SOS magazine, app, web site or forums.
Postby Wonks » Sun Jan 26, 2020 3:27 pm
Paper edition. On graphs 5 and 6 of the "Making Sense of Speaker Specifications" article, there appear three identical green arrows, labelled 2nd Harmonic, 3rd harmonic and THD (9x dBSPL) .
I presume they were originally supposed to point to the three different coloured lines , but as it is, they make no sense. Maybe they worked when the graphs were bigger, but as it appears in the magazine, they are simply wrong and seem to infer the arrows indicate the positions of 2nd and 3rd harmonics.
It's made more confusing by the caption which states that "Ideally all distortion should be eliminated (green arrows). Also, the graph arrangement has changed so that the graphs are not side by side as the caption indicates, so overall the caption should read "Harmonic distortion at 90 (top) and 95 (bottom) dB SPL. THD (Green), second (blue) and third (red). Ideally all distortion should be eliminated".
The green arrows should go, as well as the 2nd harmonic, 3rd harmonic and THD text along the top of each graph, just leaving the 90 dB SPL and 95 dB SPL text.
On Graph 7, those pesky green arrows appear again.
They point to nothing, and the caption text again confuses the issue further. "Ideally, the SPL for a certain distortion level should be maximised (green arrows)".
I'm not at all sure what is being said here, unless it's along the lines that ideally, the SPL level should be the same for all frequencies for a given THD value. If so, that certainly isn't conveyed in the graph + text.
Could someone have a look at this and hopefully update the web version?
Re: Feb 2020 - Making Sense of Speaker Specifications - graph confusion.
Postby Sam Inglis » Sun Jan 26, 2020 8:20 pm
My understanding is that the green arrows aren't intended to point to specific features of the graph, just to reinforce the idea that lower is good (in the first one) and higher is good (in the second one).
Sam Inglis
Postby Wonks » Sun Jan 26, 2020 8:38 pm
I really don't think so, Sam. Something's gone wrong. A full-frequency graph doesn't have 2nd and 3rd harmonics at specific points as the arrows indicate (especially when the indicated 3rd harmonic frequency isn't even the correct frequency for the indicated 2nd harmonic frequency).
Postby Folderol » Sun Jan 26, 2020 9:04 pm
Without seeing the associated text I actually find the graphs quite confusing anyway.
... but then I'm easily confused, some would say.
Postby Hugh Robjohns » Sun Jan 26, 2020 9:20 pm
I must admit, I briefly stumbled over the graphs when I first looked over the subbed article, but then realised the intention from the article context. So Sam is quite right: the arrows are intended to suggest all distortion should be reduced in the first and SPL maximised in the second.
Here's a response direct from the author:
Andrew Goldberg wrote:The arrows are there to indicate that distortion at all frequencies should be minimised, i.e. all the lines should be as low as possible on the graph.  Ignore that they happen to line up with the text at the top of the graph.  This is completely coincidental.  I had not noticed that!  In the original Word doc they were side by side but they got moved during layout and the text was not revised to reflect this.  Apologies for that.
For the SPL graph the opposite is true, the lines should be has high as possible.  Here there is no text in the header to cause confusion.  The SPL lines do not need to be flat, they just need to be as high as possible so there is headroom in the system.  The closer one is playing the audio to the displayed lines the higher the distortion will be.
I hope that clear up these points.
Cheers,
Andrew Goldberg
Postby Hugh Robjohns » Sun Jan 26, 2020 9:25 pm
Wonks wrote:A full-frequency graph doesn't have 2nd and 3rd harmonics at specific points as the arrows indicate...
The harmonics titles across the top were originally part of the key to the graph colours. It was an unfortunate coincidence that they happened to line up with the arrows.
In hindsight, the graph could have been illustrated in a better way -- perhaps with a single fat arrow, for example... But it wasn't.
We'll look at making the Captions more explicit for the online version.
Postby Folderol » Sun Jan 26, 2020 9:34 pm
Quite a lot of such graphs simply have heading text 'Lower is better' or 'Higher is better' as appropriate. No possible confusion then.
Postby James Perrett » Mon Jan 27, 2020 2:24 am
I don't have anything to add to the graph discussion, but I just wanted to say that it is great to see someone with the knowledge and experience of monitor design that Andrew Goldberg has writing in the magazine. Mind you, with the likes of Phil Ward and Hugh writing for the mag it already set a high standard for monitoring expertise.
Postby Watchmaker » Mon Jan 27, 2020 3:17 am
I just ignored the graphs. The article was a great articulation and helped focus my understanding greatly. It also inspired me to take the first steps in room treatment and I spent much of the day working at getting my first reflections and ITD under control. (see: https://www.soundonsound.com/techniques/sos-guide-control-room-design
Fortunately I see all kinds of rationalizations that clearly justify buying the KH80's I've been drooling over. I hope I get a discount!
Watchmaker
Postby Eddy Deegan » Mon Jan 27, 2020 3:22 am
I need to re-read it a few times with a second tab for ongoing duckduckgo searches because bits of it are in a language my brain struggles to comprehend, but that's my problem not SOS's!
Seriously though, it's a an enlightening piece and one I'll gain much from. I love to see this kind of content :thumbup:
Some of my works
Postby Phil Ward » Tue Jan 28, 2020 12:56 pm
James Perrett wrote:I don't have anything to add to the graph discussion, but I just wanted to say that it is great to see someone with the knowledge and experience of monitor design that Andrew Goldberg has writing in the magazine. Mind you, with the likes of Phil Ward and Hugh writing for the mag it already set a high standard for monitoring expertise.
Careful James, the last thing anybody wants is me strutting around Brighton feeling pleased with myself :-). Andrew's piece is really great by the way and I for one would commend it to anybody with the slightest interest in speaker specs.
Phil
Phil Ward
Freelance audio product designer/writer: https://musicandmiscellany.com Hi-Fi Prints: https://audio-icons.com
