Soldering.
For feedback and suggestions about the SOS magazine, app, web site or forums.
Re: Soldering.
Postby wireman » Sun Jun 21, 2020 4:31 pm
I decided to build a DC load box to test a couple of power supplies.
I got a nice 190x110x60mm Aluminium box and a load of high-power resistors from ebay.
The resistors are riveted to the box and 6 4mm connectors provide combinations of resistors to give...
10Ω @ 500W
20Ω @ 100W
along with connections to a
100°C Thermostat
Of course in practice it is best to limit the main load to 200W for a short time.
At the last minute I changed from the 4mm connectors I had been using which I like but need a 12.2mm hole.
I chose these...
Wired it all up, started testing and then my error dawned on me.
wireman
Re: Soldering.
Postby MOF » Sun Jun 21, 2020 5:01 pm
I presume the error is that they will only work with a plastic (non-conducting) box.
MOF
Re: Soldering.
Postby wireman » Sun Jun 21, 2020 5:07 pm
MOF wrote:I presume the error is that they will only work with a plastic (non-conducting) box.
That's right, unless you want an expensive way to get 0Ω
Had to unsolder, replace all the sockets, resolder.
wireman
Re: Soldering.
Postby Folderol » Sun Jun 21, 2020 5:16 pm
Commiserations. However, I'd have been inclined to cut a piece of tuffnol as a panel, and mount them on that.
Re: Soldering.
Postby blinddrew » Sun Jun 21, 2020 5:28 pm
Ah yes, made a similar error with a guitar pedal power supply once.
