Essential Safety Tips for Working with Electrical Circuits
Knowledgebase READ-ONLY collection of topics moved from other sub-forums to preserve them from auto-pruning. Only Moderators can start/reply or move topics into this archive.
Re: Essential Safety Tips for Working with Electrical Circuits
Postby Frank Eleveld » Mon Nov 27, 2006 11:28 pm
Clunk wrote:I have tried a few variations on this theme but without much luck, and ideas before I spend £100 on a proper electrician?
Consulting a qualified electrician seems the absolute best thing to do - trying to 'experiment' what works without having proper knowledge of an electrical system is very hazardous and may even turn out to be lethal. Don't mess with electrics until you know what you're doing.
Frank Eleveld
Postby PWGLE » Tue Nov 28, 2006 1:49 am
Clunk wrote:anyone help me out?
I'm trying to add a light and a switch to an existing lighting ring. (I did once know this about 20 years ago!)
the existing ring has one light and one switch.
can anyone provide a step by step guide to what goes where?
the existing ring is live(red) common(yellow) nuetral(blue) and earth.
I know what you mean!
Ceiling rose lighting is also very confusing if you don't understand it!
I'll draw and scan you a diagram. But if in doubt, get someone to check it or pay them to sort it! ;)
Laurence
PWGLE
Postby IvanSC » Mon Sep 08, 2008 5:08 pm
Not exactly OT but worth a mention.
Threee very dear friends of mine *almost* shuffled off the mortal coil last week.
Playing at an outdoor "do" and the 3 phase had been wired up wrong. Amps lasted for the first set & then all three blew - one guys lethally frying the mains tfr down to the chassis ground and sending a swift 400-odd volts to the earthy side of his guitar jack.
Fortunately he wasn`t grabbing anything & simply got hurled across the stage. And he already had curly hair....
Let`s be CAREFUL out there!
RDF`s and mains testers at all times, chaps!
P.S. Can all you techie types refrain from correcting me as to how many volts, where the earth potential lies, etc. this time?
Regardless of my technical coherence or lack thereof, the message needs to get across.
IvanSC
Two bottles of Corona lemon and lime,  please!
Postby Hugh Robjohns » Tue Sep 09, 2008 12:47 am
You're right. The important message is what can happen, not the detail of voltages.
But who on earth managed to mis-wire the mains supplies so utterly incompetently, and are they still in business, or banged up in prison for attempted manslaughter?
Hugh
Postby dubbmann » Tue Sep 09, 2008 2:02 am
excellent thread, well worth a sticky. i, too, have long heard the 'one-armed electrician' rule from a friend who studied electrical engineering at one of the top research unis in the states. they taught it to freshman in their first circuit class and the lesson stuck. electricity is one of those topics, along with exotic foods and problem women, that merit an entire chapter in the 'big book of famous last words' ;-)
cheers,
d
dubbmann
http://www.thinkbluecounttwo.com/ http://www.phichibe.com
Postby IvanSC » Wed Sep 10, 2008 8:36 am
Hugh Robjohns wrote:You're right. The important message is what can happen, not the detail of voltages.
Hugh
Have`nt managed to contact any of them yet, but apparently it was a smallish private "do" so who knows WHO was allowed to do the wiring.
I agree with you 100% - hopefully the survivors are now carrying their OWN safety kit, like I have for years!
The only thing I can think of here is that somehow they wound up being on 2 different phases at the same time, but surely an RDF would have seen this immediately and killed the power? The idea that anyone would hook up a temporary 3 phase supply without automatically fitting some sort of safety devices (particularly with the weeather we have been having recently) makes me shudder.
IvanSC
Postby Folderol » Tue Dec 02, 2008 12:25 am
Might have been a faulty neutral. Get this happen quite a lot on 3 phase machinery. As long as the phases remain in balance nobody notices, but as soon as someone puts a significant load from one phase to the (faulty) neutral all bets are off.
Postby ef37a » Tue Mar 09, 2010 10:17 am
Not really a safety problem as such, well, for the lashup perhaps...
Always fit an on off switch in the supply line(s)even for the most crude of rats nests so you can bang it off at the first sign of smoke.
Also worth having a couple of LEDs setup with a few K in the positive leg to tack in to show various operations, e.g. small 5V relays cannot be seen or heard to operate.
Miswired three phase
Postby damoore » Sun Aug 08, 2010 2:21 pm
(Yikes.
The mains tester I carry just tells me that there is an actual earth (not waving its leg in the air) and that active and neutral are the correct way round.
Its just got three bulbs on it. There's a placard with expected "correct" display (two ambers) and the various faults. None of them say "you are across two phases of a three phase".
I wonder what that would display. Especially if, as well as being across the phases, it was miswired as well - anybody who can get it that wrong can't even be trusted to get the earth right.
Maybe it indicates this condition by emitting smoke?
Were they running through surge protectors? Be useful to know if they were and they failed to give protection.
damoore
Re: Miswired three phase
Postby James Perrett » Sun Aug 08, 2010 7:09 pm
damoore wrote: None of them say "you are across two phases of a three phase".
Remember that standard practice is totally different in your part of the world and (as I understand it) things like tumble driers are commonly wired across two phases of a three phase supply in the US.
If you don't have a good knowledge of the standard wiring practices of the country that you are in then leave all mains wiring to someone who does. There are massive differences between the US and UK.
James.
Postby ROLO46 » Tue Feb 22, 2011 6:49 pm
Howabout the Newbury Races horse deaths recently?
What happened there? :angel:
ROLO46
Postby intense » Wed Apr 13, 2011 11:58 pm
ROLO46 wrote:Howabout the Newbury Races horse deaths recently?
There doesn't appear to have been much further news after the incident, perhaps because of the possible big bucks involved and concerns about liability. From what was reported it sounded like the insulation had broken on a disused underground mains cable that hadn't been isolated, and current to earth created a large enough potential difference at ground level to kill the two horses. All the stuff in the reports about the other horses being saved because they were wearing aluminium shoes couldn't have been right though - the danger zone was probably very localised and they missed it, or got away sufficiently quickly.
Evidently the fault current was insufficient to blow a fuse or trip a circuit breaker, which is strange considering that the cable should have been armoured and the metal armour strands connected to earth at both ends and, probably, to neutral at the supply end. But then again, the cable shouldn't have been live in the first place so it might not have been intentionally connected via a protection device.
Chris
intense
Postby dmills » Thu Apr 14, 2011 3:40 am
Horses and cattle are notoriously prone to electrocution from ground voltage differences simply because the 4 legs are a reasonable distance apart.
There is actually considerable guidance in the 'special locations' section of the wiring regs dealing with stables and similar locations for exactly this reason.
Regards, Dan.
dmills
Postby Folderol » Sat Jun 18, 2011 7:49 pm
More for protecting what you're working on than for yourself...
Make a pair of needle probes.
To do this solder a conventional sewing needle to a test lead in place of the normal probe (it is surprisingly easy to solder to the eye of a new needle). Try and make this joint as small and smooth as possible.
Then use the insulation from a thin wire to make a sleeve that goes over the needle itself right up to the joint and only leaving 2-3mm of the point exposed. Hold this in place with heatshrink tubing going over the joint and about 10mm either side. Put another piece of heatshrink on top of this going about 15mm either side, so you have a small firm 'probe' that's reasonably well insulated - not suitable for high voltage work!
Your new probes are ideal for testing chips and surface mount stuff as they are small enough for you to actually see what you're hitting and far less likely to accidentally bridge across two legs. Also, the very sharp points will easily punch through dirt and oxides, and even most PCB varnishes.
With care, you can also use them to spike through the insulation of ribbon cables etc. when you have possible faulty connectors.
P.S.
After you've stabbed yourself with them a few times, you'll learn to respect them :D
Postby ef37a » Sat Jun 18, 2011 8:05 pm
Folderol wrote:More for protecting what you're working on than for yourself...
P.S.
Lot of work Will?
I just used to get something like this: http://www.maplin.co.uk/moulded-4mm-test-probe-leads-5665
and tickle the ends up on a grinding wheel (now I have to do it laboriously with a file!).
Also a good idea to makeup a jack plug and jack socket to 4mm conns, saves a lot of bad language when interfacing with amps, AI's and such.
