Korg MS20 Kit Mods
Knowledgebase READ-ONLY collection of topics moved from other sub-forums to preserve them from auto-pruning. Only Moderators can start/reply or move topics into this archive.
Korg MS20 Kit Mods
Postby Hugh Robjohns » Mon May 09, 2016 6:24 pm
Anyone with any experience of modifying the Korg MS20 Kit -- the full-size keyboard version rather than the desktop MS20M variant or the mini?
I've scoured the interweb and have found some useful stuff, but some of it seems rather vague and optimistic rather than solid, so I was looking for any thoughts from anyone with direct personal experience.
In particular I want to:
1. add options to route the LFO (MG) or EG2 to control the Osc1's PWM, either via switches or an extra patch socket.
2. add a switch to sync osc2 from osc1
3. add a switch to select between the two filters (K35 or OTA)
4. add a switch to force the VCA to be permanently fully open or to follow the keyboard gate (in place of always following the EG2
5. Bring out some of Osc1's waveforms to patch sockets.
... and I'm open to other desirable ideas to increase flexibility and usability...
Re: Korg MS20 Kit Mods
Postby Martin Walker » Tue May 10, 2016 2:44 pm
I've added extensive mods to my MS-20 mini, but of course your circuit points will be in slightly different positions :beamup:
The only circuit diagrams I've ever been able to find are those of the original MS-20 (as shown here), so the component numbers are probably slightly different from model to model, although the circuit itself is largely identical in most places. Just track down the equivalent components on your kit version (judging by this photo of the kit circuit board, most patch points look to be far more clearly labelled than on previous MS-20 versions):
1. This one's easy - just add an extra jack socket for PWM Input at this point in the circuit:
Basically you're looking for the top of the existing pulse width rotary control. so that should be easy to track down. As soon as you plug in a CV signal from for example the LFO or Envelope output to this new socket, the existing pulse width control becomes the PWM level.
2. Sync is slightly more difficult, requiring a diode and switch as shown here:
The trick here is to track down the equivalent components on your full sized kit - I believe this is the pic for the kit, but you'll have to double check:
3. Not sure about this one, as my mini doesn't have both filters, but as far as I know you just need to bring out the connections from that red jumper at mid top of your kit circuit board (see my first photo above, just to the right of the multiway connector) to a front panel switch.
4. Haven't done this one myself, but this original MS20 schematic shows the principle for adding an EG2 to VCA switch:
5. Easy peasy - just add extra jack sockets to the three appropriate poles on your existing VCO1 waveform switch.
Again, this is the MS20 original schematic, but finding the equivalent points on your kit should be easy.
Hope this helps!
Postby Hugh Robjohns » Tue May 10, 2016 3:09 pm
Martin Walker wrote:The only circuit diagrams I've ever been able to find are those of the original MS-20...
Yes. Not surprisingly, Korg are reluctant top release schematics of current products -- as most manufacturers are.
...judging by this photo of the kit circuit board, most patch points look to be far more clearly labelled than on previous MS-20 versions
It's a trap! I've had a close look, and many of those silk screenings are misleading and don't do what they suggest because linking components are missing from the other side of the board! The PWM input markings are amongst the few that do appear workable, although I've not checked it in practice yet.
Yes, that's neat -- although I was thinking of omitting the socket and going for switch-selectable manual, LFO or EG2 options. Don't think I'd ever need more than that, and extra switches are a lot easier to install on the front panel than extra sockets!
Hmmm... bit unsure of this. The photo seems to show a connection between transistor bases -- I'm not convinced he applied the extra routing diode... will need some careful experimentation there.
3. Not sure about this one, as my mini doesn't have both filters.
That one's the easiest of the lot, as the MS20 Kit already brings out the options to a header with a link plug.
Yes, I just need to track down the right end of the equivalent of D22.
Hope this helps!
Its helpful to know that you've managed similar mods to the Mini, and that the thinking is broadly right. It's the practical implementation that represents the challenge now... but that's all part of the fun!
Postby Martin Walker » Tue May 10, 2016 3:27 pm
Hugh Robjohns wrote:It's a trap! I've had a close look, and many of those silk screenings are misleading and don't do what they suggest because linking components are missing from the other side of the board! The PWM input markings are amongst the few that do appear workable, although I've not checked it in practice yet.
Doh!! wasn't expecting that! :headbang:
Hugh Robjohns wrote:Yes, that's neat -- although I was thinking of omitting the socket and going for switch-selectable manual, LFO or EG2 options. Don't think I'd ever need more than that, and extra switches are a lot easier to install on the front panel than extra sockets!
Really? I found it easier to drill one more 6mm hole for an extra 3.5mm jack socket than all the flaff of a 3-way switch ;)
Martin Walker wrote:2. Sync is slightly more difficult, requiring a diode and switch as shown here
Hugh Robjohns wrote:Hmmm... bit unsure of this. The photo seems to show a connection between transistor bases -- I'm not convinced he applied the extra routing diode... will need some careful experimentation there.
It worked for me - it's actually connecting the collector of the VCO1 transistor to the base of the VCO2 transistor via the diode, thus forcing VCO2 waveform to reset each time VCO1 output goes high.
Hugh Robjohns wrote:Its helpful to know that you've managed similar mods to the Mini, and that the thinking is broadly right. It's the practical implementation that represents the challenge now... but that's all part of the fun!
Indeed - the very best of luck!
Postby Hugh Robjohns » Tue May 10, 2016 3:57 pm
Martin Walker wrote:Doh!! wasn't expecting that! :headbang:
Quite -- and it seems to have thrown a few others if other interweb forums are to be believed! ;)
Ah... but the MS20 Kit uses proper manly quarter-inch sockets! There is the option to mount a load of switches and socketry on the flat top of the front panel, but if I can squeeze a couple of miniature toggles onto the right places of the front panel, that would be my preferred option. Time and careful measurements will tell... ;)
Yes, I can see how it's supposed to work. I'm just not convinced that the photo shows those exact connection points. I have a sneaking suspicion that the picture shows the VCO1 wire leaving from the junction of the two transistor bases and the diode's cathode. Maybe it still works that way!
I'll report back if/when I succeed! 8-)
Postby Hugh Robjohns » Tue May 10, 2016 5:48 pm
Hugh Robjohns wrote:Yes, I can see how it's supposed to work. I'm just not convinced that the photo shows those exact connection points.
Okay... Happy now! I've worked it through... The wires shown in the pic connect the collector of Q3 in the MS20-kit (shown as Q4 in the original schematics) to the collector/base of Q17 (shown as Q11 in the original docs)... which is as the unofficial mod shows it. The extra routing diode is presumably on the switch.
Postby Martin Walker » Tue May 10, 2016 6:47 pm
Yup, that's the way I viewed it as well :thumbup:
Whatever - the screaming sync sounds great in action 8-)
Postby Wonks » Tue May 10, 2016 6:58 pm
Martin Walker wrote:Whatever - the screaming sync sounds great in action 8-)
Your waste disposal unit playing up again?
Postby BigRedX » Tue May 10, 2016 7:07 pm
Have Korg added the ability to be able to modulate each oscillator separately on the latest versions? Because that certainly wasn't possible on the original MS20 which IMO doesn't make adding oscillator sync very useful.
BigRedX
RockinRollin' VampireMan
Postby Hugh Robjohns » Tue May 10, 2016 8:20 pm
BigRedX wrote:Have Korg added the ability to be able to modulate each oscillator separately on the latest versions? Because that certainly wasn't possible on the original MS20 which IMO doesn't make adding oscillator sync very useful.
On the ms20m desktop model, yes... But not the mini or the ms20 kit.
As the review of the ms20m desktop said:
SOS wrote:When you activate FM, several things happen. Firstly, VCO1 becomes a frequency-modulation source for VCO2, the amount set by the ‘MG/T.Ext’ knob. Secondly, the VCO pitch component of the ‘Total’ input jack is disconnected, denying at a cruel stroke the opportunity for voltage-controlled FM intensity. Thirdly, and significantly for oscillator sync, the ‘EG1/Ext’ amount knob now points exclusively at VCO2. In other words, only with FM active can you enjoy envelope-swept sync.
A little later I discovered that it is possible to access VCO2’s frequency in (almost) isolation, despite the loss of the dedicated CV input. It’s not clear from the manual, but when FM is active, the ‘Freq’ input (which ordinarily affects both VCOs) only affects VCO2. Now you can pipe in an LFO or other modulation source without disturbing the pitch of VCO1, although CV received at the main input still drives both in parallel.
http://www.soundonsound.com/SOS/may15/a ... 0m-sq1.htm
Postby Zukan » Wed May 11, 2016 9:05 am
Why do you want to do all this H? After all, it's just an MS 20.
Zukan
Postby Wonks » Wed May 11, 2016 9:23 am
It's not just an MS20, it's an M&S MS20.
Postby Hugh Robjohns » Wed May 11, 2016 9:53 am
Zukan wrote:Why do you want to do all this H? After all, it's just an MS 20.
I had a hankering to play again with a simple monosynth, away from the computer screen. Nostalgia!
I've owned various over the years, but mostly Rolands of various sorts; I've never had a Korg, and the opportunity arose... but there are few things that I'd like to do but which the Korg doesn't support directly.
I must say I'm very impressed with the quality of this re-issue. The mainly surface-mount components don't make it the easiest to modify, but it's still do-able... I think...
Postby Jumpeyspyder » Wed May 11, 2016 11:43 am
That sync mod, is it applicable to other synths ?
(assuming I can find a similar circuit on the schematics) I'd love to add sync to my Crumar ds-2
Jumpeyspyder
Postby Hugh Robjohns » Wed May 11, 2016 11:51 am
Depends on the oscillator circuitry. The Korg makes it easier than many because the oscillators are built from discrete circuitry, so getting into the innards to force a cycle reset isn't too hard. That may not be the case with other designs.
If you can find the schematics it will be easier to offer an opinion...
