Isolation Headphones & HD25 types
Knowledgebase collection of topics moved/copied from other sub-forums to preserve them from auto-pruning. Registered members can reply to topics here, but only Moderators can start or copy/move topics into this archive.
Re: Best Isolation Headphones?
Postby tonemangler » Thu Feb 20, 2014 4:15 am
Daniel Drummond wrote:Others ways around it:
1) use a visual metronome (app on yourphone or the "midi bug");
2) have someone listen to the metronome in the control room and conduct you through the studio glass;
3) get a vic-firth isolation phone;
4) get a ear protection cover (for industries and construction) and use an ear-phone inside it.
This sounds a little too outside the box for me.
Thanks anyway.
tonemangler
"I'm hovering like a fly, waiting for the windshield on the freeway." Peter Gabriel
Postby John Willett » Thu Feb 20, 2014 9:09 am
tonemangler wrote:My searches only bring up the HD 25-1 II, so I assume this is the latest incarnation of this model.
There was no change in the headphones themselves between the Mk.I and Mk.II models.
The only changes were the length of the -1 cable (from 1.2m to 1.5m), more cable options (eg: there was a 2m version and a coiled cable version added in the Mk.II series) and the adaptor was changed to a screw-on type, rather than a plug-on one.
John Willett
Postby John Willett » Thu Feb 20, 2014 9:11 am
chris... wrote:HD25 rocks.
I have two pairs and have failed to break either after 10-15 years of trying.
Yours are new ones then :D
I bought mine in 1989 - still going strong after 25 years use (4th set of earpads, though and on the second set of headband pads).
John Willett
Postby John Willett » Thu Feb 20, 2014 9:18 am
tonemangler wrote:
You don't want the HD25-1 II, you want HD25 II http://www.decks.co.uk/products/headphones/sennheiser/hd25_2...
DM
I've tried searching for the HD25 II but I can't find them on this side of the pond. On Ebay there was one listing but the seller was from United Kingdom. In North America I've found the HD-25 SPII which looks different. The HD 25-1 II looks identical to the HD25 II except for the cable. I assume the degree of isolation is the same on both.
Talk to Sennheiser Canada.
the versions are:-
HD 25-1 II - 70Ω - 1.5m steel cable with rt.angled connector.
HD 25 II - 70Ω - 2m steel cable with straight connector.
HD 25-C II - 70Ω - 2/3m coiled copper cable with straight connector.
HD 25-13 II - 600Ω - 3m steel cable with straight connector.
All the above have the split headband and single-sided cable.
The one below has a cheap headband and a double-sided "Y" cable and lower quality downrated capsules:
HD 25-SP II - 90Ω - 3m steel cable with straight connector.
John Willett
Postby tonemangler » Thu Feb 20, 2014 1:06 pm
the versions are:-
Thanks for the info
On the Sennheiser Canada website only the HD 25-1 II is shown, I've emailed them to see if I can buy the other model here.
It's a drag that the second model has a shorter cable, I assume it's because these phones are geared towards the DJ market.
tonemangler
Postby tonemangler » Fri Feb 21, 2014 4:12 am
This is what Sennheiser Canada emailed me:
"Hello,
Unfortunately the HD 25 models we have are as follows:
HD 25-13-II
HD 25-SP-II
HD 25-C-II
HD 25-1-II
HD 25 Aluminum
We do not have just the HD 25-II
Thank you"
I was wondering if there would be a sonic difference between the 70 ohm HD 25 II and the 600 ohm HD-25-13-II. Someone online was selling a pair and was describing the superior sound of the 600 ohm model. I'm not sure why someone would prefer a higher impedance headphone to a lower one. I would be driving it with a Yamaha 01V96 mixer, or a Line 6 UX1 interface. It seems like the HD 25-13-II would be a better fit for me because of the long cable and straight lead.
Paul
tonemangler
Postby John Willett » Fri Feb 21, 2014 10:17 am
Sennheiser Canada can supply any of them without any problem - though they may have to get it in specially in their next shipment - it shouldn't be a problem.
But, if you want it and they refuse to get it, give me a shout and I'll sort something via the UK for you.
The HD 25 was never designed for DJs - it was originally designed for ENG (outside broadcast) use (HD 25-1) and studio use (HD 25-13). It was only later that DJs discovered it and now more are sold to DJs than broadcasters - but, in Europe, it's still the standard headphone for film and broadcast sound recordists.
The -1 version had a rt.angled cable so it would plug into Betacams without getting in the way - also, a rt.angled jack just twists when knocked and does not bend or damage the socket.
The -1 version is the most popular, especially with sound recordists.
teh 2m cable version was for DJs and for sound recordists who wanted to listen wjile the recorder was on the floor.
The -C version was for those (mainly DJs I think) who demanded a coiled cable.
The -13 (600Ω) version with a 3m cable was for studio use where a higher impedance does not load the circuit.
The -SP version was originally devised by Sennheiser UK for Concord. BA wanted headphones for concord, but didn't want to pay the price of the HD 25. Sennheiser UK realised that the split headband of teh HD 25 was expensive to make as opposed to the cheapo headband of the HD 414 - and - that the capsules of the HD 25 fitted the HD 414 headband. So a special version was made for Concord, using special 300Ω capsules, fitted to the cheap HD 414 headband.
Sennheiser in Germany then realised that this could make a cheaper HD 25 - hence the -SP version. BUT - you cannot have a cheaper headphone of the same quality as it would be commercial suicide - so the capsules of the -SP were downrated. Still excellent value, though.
I hope this helps explain things.
(Please note - I wrote this reply last night, but forgot to post it, I only posted it this morning when I woke up and realised I had not pressed "send")
John Willett
Postby John Willett » Fri Feb 21, 2014 10:28 am
tonemangler wrote:This is what Sennheiser Canada emailed me:
"Hello,
HD 25-13-II
HD 25-SP-II
HD 25-C-II
HD 25-1-II
HD 25 Aluminum
Thank you"
They *can* get it - Sennheiser website:-
HD 25 II
Article No. 502105
As HD 25-1 II, but with 2m steel cable and straight jack plug
Try telling them the article number.
If they won't get it and you still want it, send me a PM.
tonemangler wrote:I was wondering if there would be a sonic difference between the 70 ohm HD 25 II and the 600 ohm HD-25-13-II. Someone online was selling a pair and was describing the superior sound of the 600 ohm model. I'm not sure why someone would prefer a higher impedance headphone to a lower one. I would be driving it with a Yamaha 01V96 mixer, or a Line 6 UX1 interface. It seems like the HD 25-13-II would be a better fit for me because of the long cable and straight lead.
There should be no sonic difference at all - it would just be an impedance difference that meant that it sounded better for him in his particular amplifier. The maximum sound pressure level is 5dB lower on the -13 version. Often it's better to use the high impedance version on mains equipment and the low impedance version on battery powered equipment.
I hope this helps.
John Willett
Postby BJG145 » Fri Feb 21, 2014 10:48 am
tonemangler wrote:I have a pair of Sennheiser HD265's and although they are closed back I find the click track sometimes leaks into the recordings of my acoustic guitar
If you have a bright, loud click, I'm just wondering if a different metronome sound (more of a dull thud, like a stompbox) might help.
Daniel Drummond wrote:use a visual metronome (app on yourphone or the "midi bug");
(I like the sound of that...might give it a try.)
Postby tonemangler » Sat Feb 22, 2014 4:41 am
Thanks for all the info John, I appreciate it. I still want to audition the Focal Spirit Pros, but if I decide to go with the Sennheiser it will most likely be the HD 25 II. I will quote the article number you provided and hopefully they can accommodate. If I hit a road block I'll take you up on your offer and PM you (not sure how to do that but I'll figure it out).
Thanks again :)
tonemangler
Postby tonemangler » Sat Feb 22, 2014 4:58 am
BJG145 wrote:If you have a bright, loud click, I'm just wondering if a different metronome sound (more of a dull thud, like a stompbox) might help.
I could try that. I've always used the generic click that comes with my DAW because I couldn't be bothered to set up a midi device and search for the right sound. When starting a new project I just want to quickly find the right tempo and start recording.
I want to buy new headphones anyway because my HD265 is pretty old and beat up and I've had issues with its' cable and jack. Anyways the only thing better than owning one set of headphones is owning two!
Thanks for the post
Paul
tonemangler
Postby chris... » Sat Feb 22, 2014 12:59 pm
tonemangler wrote: When starting a new project I just want to quickly find the right tempo and start recording.
Yes, which is why many people have a "template" new project setup, prepared such that everything's ready to go, just as they like it, including click sound etc.
chris...
Postby John Willett » Sat Feb 22, 2014 1:22 pm
tonemangler wrote: If I hit a road block I'll take you up on your offer and PM you (not sure how to do that but I'll figure it out).
To send a PM, you click on the posters name on the left - at the bottom you then click on "send a private message".
Or reply to the one I will send you now.
John Willett
Postby tonemangler » Sat Feb 22, 2014 2:46 pm
It's funny you say this because as I was typing that post I was thinking about how I never seem to get around to making a project template. My problem is I live by the motto "Why do today what I can do tomorrow" Very sad I know :frown:
tonemangler
