Transcribing CDs to MP3 - 3 helpful utilities
PostPosted: Thu Nov 29, 2018 4:56 pm
by Mike Stranks
Of late I've had to transcribe hundreds of CD tracks into MP3 format and index them. No big deal, but they've got a combination of either spurious gunk at the front or end of the filename or filenames that say 'Track 1' etc.. Before you ask, no; libraries such as Gracenote know not of these tracks' existence...
Three little free utilities have helped hugely:
1) Bulk Name Utility - allows you to manipulate the file name - eg. delete the first 5 characters; add extra stuff on the end etc.
2) Mp3tag - allows you to copy the filename into the tag information - and do much more besides.
3) Karen's Directory Printer- allows you to export all sorts of information from the directory tree structure either to print or as a file to be used in Excel etc. Brilliant for compiling lists of songs as a library list.
All three thoroughly recommended and have saved me oodles of time.
Re: Transcribing CDs to MP3 - 3 helpful utilities
PostPosted: Thu Nov 29, 2018 7:20 pm
by blinddrew
Definitely one for the Useful Information Archive!
:clap: :clap:
PostPosted: Fri Nov 30, 2018 12:34 am
by Martin Walker
Thanks Mike - always good to have some links to helpful Windows utilities :thumbup:
Just tracked down Bulk Rename Utility here:
https://www.bulkrenameutility.co.uk/Main_Intro.php
PostPosted: Fri Nov 30, 2018 11:52 am
blinddrew wrote:Definitely one for the Useful Information Archive!
:clap: :clap:
Agreed... and moved!
PostPosted: Mon Dec 02, 2019 6:30 am
by Philbo King
Another very useful utility. It reads the audio from CD, allows you to use the LAME mp3 encoder, and will pull in MP3 tag info and album art from the web (for commercially released CDs) as well.
http://exactaudiocopy.de/
PostPosted: Mon Dec 02, 2019 2:57 pm
by The Elf
Two of those I use almost constantly, but I'd not come across the directory printer thing.
I'd wholeheartedy concur with your comments on those utilities - indispensable.
PostPosted: Mon Dec 02, 2019 3:38 pm
by ken long
[quote="Mike Stranks"]
3) Karen's Directory Printer- allows you to export all sorts of information from the directory tree structure either to print or as a file to be used in Excel etc. Brilliant for compiling lists of songs as a library list.[/quote]
I use a batch script for directory lists:
1. Open Notepad
2. Copy and paste the following: dir *.wav /b > list.txt
3. Save As Batch
4. Double click to run
5. A new .txt is created in the same directory
you can replace .wav with anything else.
PostPosted: Mon Dec 02, 2019 7:42 pm
by The Elf
Applause!
(for some reason my Smilies are switched off, though they're switched on in my preferences...)
