Korg MS20 Kit Mods
Re: Korg MS20 Kit Mods
Postby Hugh Robjohns » Thu Sep 22, 2016 4:30 pm
The keyboard is scanned by the microprocessor on the power and control board, and on the full-size version there are two connectors carrying the various connections to and from the keyboard.
The chances are you have partially dislodged one of those connectors, or that you have dropped solder or wire across the microprocessor terminals.
Shouldn't be too hard to find visually.
Postby midierror » Fri Sep 23, 2016 2:04 pm
Thanks Hugh, I did de solder everything and go over it with a magnifying glass. its good to know how it functions, thanks for that...I will have a look again tonight.
I appreciate your help
midierror
Postby midierror » Tue Sep 27, 2016 2:01 pm
okay - I have some photos and an audio example of the state its in.
To save hijacking this thread - I'll start a new one here: http://www.soundonsound.com/forum/viewt ... 23&t=54536
midierror
Postby zaphod betamax » Thu Jan 26, 2017 8:50 pm
The fun really begins when you have 2 MS-20kits (modded or unmodded)
In my case they are both unmodded stock MS-20kits.
With Hz/V and Trig S you get
4 oscillators
4 EGs
and the ability to cross cable between the two and create some IMHO unique textures
As I run them both quite BPish, I fill in the bass with two Monotribes!
zaphod betamax
Postby Martin Walker » Fri Jan 27, 2017 9:06 pm
zaphod betamax wrote:The fun really begins when you have 2 MS-20kits (modded or unmodded)
4 oscillators
4 EGs
Audio demos please zaphod betamax! 8-) :thumbup:
Postby BillB » Fri Jan 27, 2017 9:25 pm
Hmmm, Zaphod Betamax.... don't you have a more famous brother?
:beamup:
BillB
Postby Wonks » Fri Jan 27, 2017 11:43 pm
BillB wrote:Hmmm, Zaphod Betamax.... don't you have a more famous brother?
:beamup:
Sony?
Postby awjoe » Sat Jan 28, 2017 12:43 am
:beamup:
Sony?
Behringer.
awjoe
Fringe member of the Party Pooper People's Party
Postby vinyl_junkie » Tue Mar 14, 2017 12:42 am
I have schematics for the Mini filter from Korg, a lot of the things share the same design/part number to the kit it appears.
Check the attached pics at the bottom of my post
http://www.soundonsound.com/forum/viewtopic.php?f=24&t=56471
vinyl_junkie
Users browsing this forum: Wonks
