Innovative sounds & recording methods
Re: Innovative sounds & recording methods
Postby Martin Walker » Tue Feb 14, 2017 9:32 pm
Well this is most certainly different an innovative:
"::vtol:: volnovod
Two stepper motors constantly turn and intertwine the wire, moulding different types of waves. Motors operate in accordance with the random numbers-based program and randomly change the direction. Still they rotate within the preset number of steps range to prevent the wire from over-intertwining. The camera shoots a wire in front of a black background, which makes possible to achieve the highest picture contrast. Nine wave pictures are saved. Later they can be updated in automatic mode or refiled manually in semi-automatic mode or manual mode. These nine shots then morph into graphic tables with resolution of 270 x 240 points. The tables are the base to control sound synthesis options. The program can generate parameters in any suitable format: MIDI, OSC, CV. It allows to use it freely as within the system as with external devices. "
Postby Martin Walker » Mon Feb 20, 2017 3:46 pm
Now recording doesn't get much more innovative than this! ;)
"As music technology advances, a growing number of artists are exploring what it means to go “off the grid” and making their own transgressive Frankenstein instruments. Far outside DAW quantization and the digital realm, sound artist Graham Dunning uncovers what the unpredictability of the physical world can do for dance music with his sound experiments. Perhaps his most well-known is the Mechanical Techno Project, which uses turntables as the basis for towering contraptions that make techno music with no human involvement. They spin multiple records on the same axis and use nuts and bolts to trigger external effects, elevated planes to create rhythmic patterns and metal-plated locked grooves produce unpredictable noise. The setups are clumsy, inaccurate and prone to error—in other words, they’re not computer perfect. And that’s entirely the point."
Behold Graham Dunning's MECHANICAL TECHNO DEMONSTRATION
https://www.youtube.com/watch?v=wl1ZrEza7uY
Keep watching - it just gets better and better :thumbup:
Postby Martin Walker » Thu Mar 02, 2017 3:35 am
Now I've never personally considered using floppy disks as sound sources, but having heard what's possible in this video demonstration I'm going to dig out my PC parts box ;)
Behold: Star Wars - Imperial March on Eight Floppy Drives
Click here to engage the floppies: https://www.youtube.com/watch?v=cM_sAxrAu7Q
Postby Luke W » Thu Mar 02, 2017 1:24 pm
Martin Walker wrote:Now I've never personally considered using floppy disks as sound sources, but having heard what's possible in this video demonstration I'm going to dig out my PC parts box ;)
Similar thing here with a few hard drives for good measure...
https://www.youtube.com/watch?v=GwuCQ3u2N_A
Luke W
Techie / Musician Of Sorts
Postby Martin Walker » Sat Mar 04, 2017 12:25 am
Luke W wrote:Similar thing here with a few hard drives for good measure...
Oh wow - thanks for that link Link - that's an insane setup :headbang:
The floppotron indeed! :bouncy:
Postby Martin Walker » Tue Mar 07, 2017 12:26 am
Now I'm sure this video quite qualifies for its innovative sounds, but it most certainly does for their method of manufacture.
Ladies and gentlemen, I present to you Tim Linhart's Ice Instruments
"Tim Linhart was an ice sculptor in Colorado. One day he carved an upright string bass from ice and was astonished at the beautiful sound it made. Now he is the founder of Ice Music, based in Luleå, Swedish Lapland. Ice Music presents a winter concert series in a variety of music styles, all played on instruments made of ice and performed in a specially designed igloo."
Now watch the video of them in action: https://www.youtube.com/watch?v=U7iLFA2t8WQ
Not exactly chill-out music, not not far off :beamup:
Postby Martin Walker » Thu Mar 09, 2017 10:33 pm
Magnetic Movie
"Filmmakers Ruth Jarman and Joe Gerhardt (as Semiconductor) wondered what magnetic fields might look like, and they set out to animate their spirited dance. Their short film “Magnetic Movie” was filmed at the NASA Space Sciences Laboratory at UC Berkeley. VLF (very low frequency) recordings are paired with audio of space scientists discussing their findings about planetary and solar magnetic fields."
"But the visual portion of the film is what makes it so remarkable. The whistles, pops and various noises captured by the VLF recordings are animated with a sense of humor. The pictures bring to life perfectly the fields described by the scientists, and the shapes twist and dance in sync with the VLF recordings. Altogether, it’s a surreal 4.5 minutes watching something that the human eye wouldn’t normally be able to detect."
An inspiring combination of VLF and video animation techniques! 8-)
Postby Martin Walker » Mon Mar 13, 2017 6:41 pm
Until I Die uses blood-filled batteries to generate an electrical current.
Well, I've featured Russian artist Dmitry Morozov aka ::vtol:: in this thread before, but this time he has created a sound installation powered entirely by his own blood! :shock:
"Until I Die, which was shown at the Kapelica gallery in Ljubljana, Slovenia, last December, uses blood-filled “batteries” that power a small algorithmic synth module, which plays a sound through a small speaker.
It took 18 months for Morozov to collect all 4.5 liters (almost eight pints) of the blood necessary to power the installation, which went through a preservation process and was diluted to seven liters. When brought into contact with the aluminum and copper in the battery, the electrolytes in the blood generate a small electrical current."
What some musicians will do during their pursuit of art! ;)
Postby Martin Walker » Thu Mar 23, 2017 9:47 pm
Not sure how I feel about this one. Neil Mendoza's 'Rock Band' (using real rocks) is nicely done, but rather more of a contrived gimmick to me than true innovation.
Nevertheless, it's well worth a view:
Postby Martin Walker » Sat Apr 01, 2017 2:47 pm
"In his native Guatemala, interactive artist Balam Soto is a “Maestro" of Visual Arts, thanks to an honor by his country’s National Congress. Like a cyberpunk from a William Gibson novel, Soto blends low and high tech to create interactive art installations, for his own studio and Open Wire Lab, both located in Hartford, Connecticut.
Using software, touch sensors, plexiglass tubes, projections and sound, Soto’s latest, Exp.Inst.Rain, blurs artistic boundaries. He describes it as both an interactive installation and “experimental instrument.”
Postby Martin Walker » Wed Apr 12, 2017 1:29 pm
I always love new instruments, especially when they are as novel as this one, built by makers Stephanie McCarty and Andrew Siu and described as a 'Tone Garden'
"A stand-alone Interactive Musical Device that produces tones and loops. Made using Arduino Boards, Wave Shields, IR Sensors and Servo Motors, sound can be manipulated by physically moving and controlling certain elements of the device.
IR sensors detect the distances of propeller blades triggering a corresponding tone to emit from the device.
Rotations of the propellers are controlled by 2 potentiometers (silver knobs) at the front of the device which alter the tempo of the resulting tones."
Postby Martin Walker » Mon Apr 17, 2017 5:22 pm
Some installations can make stunning use of sound, while others fall at the first fence. This is most definitely one of the former! :thumbup:
Travelon Gamelon - Promenade
Originally performed in 2011, Professor Richard Lerman’s Travelon Gamelon is a unique musical experience falling somewhere between a concert, a flash mob, and a bicycle race. A group of cyclists rig their bicycles up with audio electronics and then ride together through the streets of Amsterdam. The sounds produced by the natural resonances and rhythmic qualities of the bicycle creates a musical effect surprisingly similar to a traditional Balinese gamelan.
Now this is fun with a capital F, but also thought-provoking AND musical ;)
Postby Martin Walker » Wed Apr 26, 2017 2:36 pm
Raven Kwok's new music video for Karma Fields is what happens when Artificial Intelligence meets tessellations
"Through Kwok’s visual productions—the artist is best-known for what he calls ‘code-driven creatures’—Fields has been able to develop an artistic persona, a narrative of being a form of artificial intelligence progressively becoming self-aware.
The visuals were inspired by mathematical model, the Voronoi tessellation, which Kwok describes as being at the heart of the video's generative visual patterns."
Intrigued? then watch the video right now ;)
www.youtube.com/watch?v=mTzbax2daKs
Postby Martin Walker » Wed May 03, 2017 3:25 pm
I do love mechanical sequencers, and here's a corker from Benny Hofer
Ladies and gentlemen, behold Bam Bam
And now listen to it in action: https://www.youtube.com/watch?v=s4kieFpukeE
Lovely work Benny! 8-)
Postby Martin Walker » Wed May 17, 2017 3:11 pm
As some of you may have noticed, I do love mechanical music, so here's another chance to enjoy Sonic Robots with their Tripods One - Teaser:
The best use of scrap metal ever! ;)
Postby Ramirez » Wed May 17, 2017 5:26 pm
Martin Walker wrote:As some of you may have noticed, I do love mechanical music, so here's another chance to enjoy Sonic Robots with their Tripods One - Teaser:
How ace!
Did you get your hands on those Dadamachines solenoids?
Ramirez
Postby Martin Walker » Thu May 18, 2017 9:23 pm
Ramirez wrote:How ace!
I have one that I originally bought for my Koma Field Kit that is now destined for the forthcoming Dadamachines board, but will order a larger batch in a few months when dadamachines start shipping. I've bookmarked several Ebay suppliers.
I can't decide yet how many simultaneous solenoids I'll actually use in practice - I originally thought 8 in total (dadamachines supports up to 12), but that will probably be overkill. Maybe four, plus four electric motors (for spinning buzzes and threshing external objects will be the way forward, since I don't need a 'full mechanical orchestra'.
This is partly why I'm currently exploring what other artists are doing with mechanical music.
Thanks for your interest! ;)
Postby Martin Walker » Thu May 25, 2017 8:36 pm
Well this post most certainly qualifies for 'Innovative Sounds', yet remains pleasingly musical:
Ladies and gentlemen, I present for your entertainment and education, pitanga, from Andreas Trobollowitsch, featuring marina kifferstein, violin / leah asher, violin / anne lanzilotti, viola / meaghan burke, cello
Enjoy!
Postby ManFromGlass » Sat May 27, 2017 2:12 pm
Repost as my first one disappeared and I got ejected from the forum -
As I was trying to post - Yaaaaaaa Martin! These posts give me hope for the future of music. Especially if one has a good sense of humour!
Postby Martin Walker » Sat May 27, 2017 8:27 pm
Glad you enjoyed that most recent post MFG - as I said, it may exhibit humour, yet ultimately it remains musical :clap:
In a similar vein, here's hecker (part3), once again from Andreas Trobollowitsch
Enjoy! ;)
PreviousNext
Users browsing this forum: n o i s e f l e ur, Random Guitarist
