iZotope RX6
For feedback and suggestions about the SOS magazine, app, web site or forums.
Re: iZotope RX6
Postby James Perrett » Wed Aug 02, 2017 2:00 pm
Mike Stranks wrote:Is there a trial version of RX6 you could play with?
Only problem is that I'm still running Windows XP on my music computers which won't run RX6. A new laptop is under consideration - but I'd like one that would work with my Focusrite Firewire interface so it would probably have to be a refurbished model rather than brand new. I'm still trying to work out the best way to upgrade without breaking too many things that work fine at the moment.
Re: iZotope RX6
Postby Mike Stranks » Thu Aug 03, 2017 11:19 am
Hugh was, of course, right with regard to the Spectral view editor in Elemnts. Once you've highlighted the dodgy area you can then use the limited range of tools available to ameliorate the problem sound. Still not as good for full repairs as the Spectrum Editor available in the cheapy Magix Audio Lab 15... and later versions of that don't have it either...
Mike Stranks
Re: iZotope RX6
Postby Hugh Robjohns » Thu Aug 03, 2017 12:01 pm
While Elements is a lot more powerful than the previous RX5 plug-in pack, it is clearly designed to tempt you into upgrading to the Standard edition which opens the door to a far more sophisticated raft of spectral editing tools... and actually, I reckon the standard edition is pretty good value for money if you find yourself needing to fix things (for other people, naturally... :-) ) fairly regularly.
Re: iZotope RX6
Postby Aural Reject » Thu Aug 03, 2017 12:23 pm
Hugh Robjohns wrote:.... if you find yourself needing to fix things (for other people, naturally... :-) ) fairly regularly.
Sadly, I find, even for people who should know better!
Aural Reject
Re: iZotope RX6
Postby Mike Stranks » Thu Aug 03, 2017 5:27 pm
Hugh Robjohns wrote:;-)
Point well-made...
I'm on the cusp of needing the Standard version. I'm using de-click and de-clip a lot these days when dealing with material from others and the voice denoiser is pretty powerful. But I'd find it hard to justify the upgrade unless I move to more commercial status on projects. Stuff recorded here, in the 'studio' is, of course, pristine. :lol:
It's not helped by following someone on YouTube who keeps demonstrating the wizzy things you can do with the Standard version when live recordings have unexpected 'noises-off'! :)
Mike Stranks
Re: iZotope RX6
Postby James Perrett » Fri Aug 25, 2017 10:16 pm
Just had an email offering Elements for $29. As I've just bought myself a fairly powerful refurbished laptop I went for it. Just tried the de-click on an old vinyl transfer and, while initially impressive, I realised that I was also losing some of the life out of the recording. Reducing the strength helped but it then started to let through too many clicks. I tried the same recording with Audition and felt, that while it sounded a little rougher, it also kept more of the high frequencies. I only had 3 or 4 clicks to remove manually after the Audition process.
I'm going to try a few more side by side comparisons - just to see whether it was that particular track that gave problems - maybe RX doesn't like punk rock!
Re: iZotope RX6
Postby Mike Stranks » Sat Aug 26, 2017 2:56 pm
James:
I've found that playing around with the parameters in 'de-click' helps - as well as previewing in 'clicks only'. As you've discovered, you can end up with a technically perfect recording from a noise perspective which sounds totally lifeless from a musical perspective.
I'm currently doing some production work on a specialist jazz radio programme. Some of the raw material I get needs very careful handling to retain a true representation. The 30s stuff is easier as people expect an authentic sound; some of the late 50s and 60s vinyl albums are more challenging with their numerous clicks, pops, distorted highs etc from multiple plays, poor handling and (probably) dodgy styli...
Mike Stranks
Re: iZotope RX6
Postby Tim Gillett » Sun Aug 27, 2017 5:15 am
James Perrett wrote:... Just tried the de-click on an old vinyl transfer and, while initially impressive, I realised that I was also losing some of the life out of the recording. Reducing the strength helped but it then started to let through too many clicks. I tried the same recording with Audition and felt, that while it sounded a little rougher, it also kept more of the high frequencies. I only had 3 or 4 clicks to remove manually after the Audition process.
My 15 year old Steinberg Declicker when pushed would start to add a "furry" distortion to wanted content, so I backed it off until the distortion just disappeared. I also found that in quiet passages I could apply Declicking more heavily without the same onset of distortion.
In my experience when someone claims a tool "sucks the life out of the track" they are usually referring not to a Declicker but a broadband Denoiser (spectral subtraction).
A year or so ago I bought an Acon basics package with Declick, Denoise, Dehum and Declip. The Declick is split into two sections, a Declick and a Decrackle. I found that while the Declick worked well, the Decrackle added watery artifacts, usually associated with a Denoiser. Does the RX6 Declicker possibly contain both Declick and Decrackle? If so, it maybe worth temporarily disabling the Decrackle to see if that is causing the problem.
Interestingly well regarded 78RPM reissue engineers Ward Marston and Mark Obert Thorn freely use Declickers but appear to draw the line at Denoisers, which may also include Decracklers.
Tim Gillett
Re: iZotope RX6
Postby ConcertinaChap » Wed Sep 06, 2017 11:22 am
Point well-made...
Indeed, and as a new purchaser of RX6 Elements those nice folks at Izotope have just sent me an email that says in part: "Special Loyalty Savings! As an RX owner, you can save $200 when you upgrade to RX 6 Standard. $199".
Isn't that nice of them? And yes, I am tempted. I've got until September 29th to decide.
PS Not quite sure whether 10 days of ownership really justifies the loyalty tag, but whatever floats their boat ...
ConcertinaChap
Re: iZotope RX6
Postby blinddrew » Fri Oct 06, 2017 12:17 pm
We've recently started doing a lot more video stuff at work but one of the things I'm struggling with is air-conditioner noise. It sounds like this is the kind of thing that this should help with, does anyone have any experience of using it in this way?
Drew
Re: iZotope RX6
Postby Mike Stranks » Fri Oct 06, 2017 2:35 pm
blinddrew wrote:We've recently started doing a lot more video stuff at work but one of the things I'm struggling with is air-conditioner noise. It sounds like this is the kind of thing that this should help with, does anyone have any experience of using it in this way?
Drew
Check out the videos/demos on their website and elsewhere... I'm sure there's one about using one of the modules available in Elements to deal with this.
Also check out the YouTube videos by Curtis Judd. He's a videoman who takes sound very seriously and has posted several vids about using RX6 to deal with issues.
Mike Stranks
Re: iZotope RX6
Postby blinddrew » Fri Oct 06, 2017 3:28 pm
Thanks Mike, i shall do that very thing.
Cheers
Re: iZotope RX6
Postby Martin Walker » Fri Oct 06, 2017 4:01 pm
If you're not sure about iZotope RX6 (and it does always get excellent reviews), air conditioner noise tends to be fairly consistent and therefore relatively easily removed by any noise reduction app/plug-in that lets you create a noise profile from just the air conditioner noise and then apply that to the remainder of the audio.
I remember doing this way back in my Sound Forge days, and still have their Acnoise.wav test file dated 1999 ! :beamup:
Re: iZotope RX6
Postby blinddrew » Fri Oct 06, 2017 6:48 pm
Cheers Martin, i had thought about that but I remembered this thread and thought I'd lob the question out there.
As normally turns out to be the case, i need to go and do my research.
Drew
Re: iZotope RX6
Postby Mike Stranks » Sat Oct 07, 2017 10:39 am
I've done some more digging myself... here's Curtis's video where he talks about aspects of RX6
https://www.youtube.com/watch?v=Aq7IVMtw_ek&t=3s
The module I've used for the sort of thing you describe is 'Voice Denoise' - which Curtis demos. The good news is that's in Elements - which is why I've got it! Much more sophisticated than the 'reverse polarity noise print' tools of which I have several. Oh! And I've found that it can be good on music too - if set-up properly. :)
Mike Stranks
PreviousNext
