Mixers with built in effects - Any with chain function?
Postby Heading West » Tue Nov 14, 2017 6:23 pm
My ancient SPX 990 has a footswitch enabling a pre programmed sequence of effects to be stepped through......very useful for solo instrumentalists who don’t have someone to do this for them. My question/gripe is given the many mixers that come with built in effects, why is it that none are made with a similar facility? The most you can hope for is a bypass socket for the footswitch but that’s it. Not unless anyone can put me right?
Heading West
Re: Mixers with built in effects - Any with chain function?
Postby The Elf » Tue Nov 14, 2017 6:46 pm
A simple chain stepper seems pretty inflexible to me. Even my humble DigiTech RP55 has a pair of up/down pedals to let me go forward *and* backward through the effects chain, and most effects boards allow something similar, even over MIDI, if required.
As to it being included specifically in a mixer... A MIDI pedal would let you change scenes on a digital mixer - even an old O2R, or the like. Would that achieve what you want?
Postby Heading West » Tue Nov 14, 2017 7:48 pm
Thanks for the info - I’ll look into the 02r idea - I’m on a very restricted budget though.
Heading West
Postby The Elf » Tue Nov 14, 2017 8:09 pm
The O2R was only one example. It's a fairly huge old monster. Lots of much more economical, modern and smaller devices would do the same.
Hopefully others will be along to offer advice - mixers are something I've not looked into for a long time! :headbang:
Postby resistorman » Tue Nov 14, 2017 8:34 pm
It would appear you can do this with the Behringer digital mixers, including the XR series.
resistorman
future26.com
Postby Sam Spoons » Wed Nov 15, 2017 12:50 am
Yup, the Berry X32 and XR series have pretty sophisticated midi options. Should do what you want fine.
Postby Heading West » Wed Nov 15, 2017 8:45 am
Thanks for the suggestions folks.
Heading West
Users browsing this forum: shufflebeat
