Zoom TAC-2 and new iMac 2017
Postby Jazzman1969 » Tue Nov 28, 2017 12:00 pm
Hi guys !
i wonder if there is anybody out there who successfully connected his Zoom TAC-2 via an TB3-TB2-Adpater (from Apple) with a new iMac (2017 Model with only TB3/USB-C). I tried it but without success. I tried it on macOS Sierra, the light on Zoom TAC-2 flashes shortly but disconnects then without being recognized by macOS. :cry:
Perhaps somebody got it and could give hints or a how to do !
Thanx in advance
Jazzman
Jazzman1969
Re: Zoom TAC-2 and new iMac 2017
Postby G-Doubleyou » Wed Nov 29, 2017 12:08 am
Check for the latest drivers, associated software, or firmware updates at the Zoom site.
Under the Apple menu/ About this Mac/ System Report, check under Thunderbolt.
Does your machine detect and identify the device.
If yes, open the Audio MIDI setup utility ( found in the utilities folder )
Can you select and configure ?
G-Doubleyou
2.3 GHz quad-core i7 Mini
Postby Jazzman1969 » Wed Nov 29, 2017 9:57 am
no, it is not detected as a device, thus i can't configure it. When i installed the zoom-drivers, they were the latest drivers (for sierra). No further software was available.
You did not say directly in your post, that you were able to install the Zoom Tac 2 with that hardware, so i assume, u do not have TB3-Apple Hardware. But thanx for that suggestions :thumbup:
Jazzman1969
Jazzman1969
Postby Jazzman1969 » Mon Dec 11, 2017 3:12 pm
Now i got a major update for those who are interested:
i got it ! :bouncy:
Took the new drivers form their website and followed a tip by zoom:
plug in first the apple-tb3-tb-adapter, then plugin the tb-cable and last plug in the zoom tac-2...and... it worked ! Don't really know, what it was, but at least i am happy !
Btw, the latency went down to 1,5 ms with 64 samples at 44.100 hz !!!
Cheers
Jazzman1969
Jazzman1969
Postby G-Doubleyou » Tue Dec 12, 2017 5:12 am
I don't own a TAC-2, just doing general troubleshooting.
G-Doubleyou
Postby ConcertinaChap » Tue Dec 12, 2017 2:54 pm
Good news for all of us with Tbolt 2 kit and facing a future upgrade to something with Tbolt 3/USB C. Thanks.
ConcertinaChap
A small fish in a small pond.
Postby RevitalRecords » Thu Dec 06, 2018 12:47 am
Hey you all!
I am absolutely frustrated. Been trying for hours, following all kind of tips and leads.
Installed, uninstalled & reinstalled the last driver. Updated the TAC-2R firmware...
Also did the cable plug one by one thing. No way.
It still does not work.
My TBolt does not recognize anything connected.
The Zoom works, because I tested it myself in other computer.
This one is a MacBook Pro 2018 High Sierra 10.13.4
Please, help! & Thanks a lot in advance....
RevitalRecords
Postby ConcertinaChap » Thu Dec 06, 2018 7:04 am
G-Doubleyou wrote:Under the Apple menu/ About this Mac/ System Report, check under Thunderbolt.
What's the result of doing this? If you can't see the device then it's probably a hardware rather than a driver problem.
ConcertinaChap
Postby Xyntec » Sun Jul 21, 2019 12:21 pm
After messing around for almost an hour I just discovered the solution (and that's the reason I just registered on this forum). :D
After installing the drivers you need to head over to the security settings (System options --> Security), and click on the button that says "allow". Check the entry "Zoom Cooperation" and grant access. Now restart your mac and the Tac 2R should be recognized by the system. Hopefully this works for you guys as well :)
Xyntec
Users browsing this forum: Hugh Robjohns, Malcolm Smith
