XRI Systems XR300 or XR03 help needed
Re: XRI Systems XR300 or XR03 help needed
Postby ramsammy » Tue Nov 20, 2018 4:20 pm
Hi I have a manual for the XRi xr300 as a zip file. If you still need it let me know.
ramsammy
Postby The Elf » Tue Nov 20, 2018 6:52 pm
ramsammy wrote:Hi I have a manual for the XRi xr300 as a zip file. If you still need it let me know.
I'd like a copy to make it available should anyone else ask.
Thanks! :thumbup:
Postby ramsammy » Wed Nov 21, 2018 5:45 pm
Please wait I have not yet worked out how to send you this zip file
Garry
ramsammy
Postby The Elf » Wed Nov 21, 2018 9:34 pm
No problem. There are plenty of folks here to advise if you're struggling.
Postby ramsammy » Wed Nov 21, 2018 9:47 pm
I think I maybe have to have 3 posts before I can move on. Any Ideas how to do this?
Garry
ramsammy
Postby blinddrew » Wed Nov 21, 2018 9:56 pm
Your first three posts have to be approved by a moderator (it's an anti-spam measure), after that you're free to go. The forum can't host content though so you'll need to host it somewhere else and then post a link here or in a pm.
The easiest way to PM someone is to click the envelope button next to their avatar at the bottom of a post.
Postby ramsammy » Thu Nov 22, 2018 8:28 pm
Thank you Blinddrew, I cannot see an envelope at the side of any avatar. so I presume I am still not able to PM anyone. As soon as I have been approved I will get this zip file out.
Thanks to all for your help
Garry
ramsammy
Postby musbase » Mon Nov 26, 2018 2:31 pm
Hi ramsammy,
If ever you find a way to do this I would be very interested in the XR300 manual too!
Good luck.
Best regards,
musbase
ramsammy wrote:Thank you Blinddrew, I cannot see an envelope at the side of any avatar. so I presume I am still not able to PM anyone. As soon as I have been approved I will get this zip file out.
Garry
musbase
Postby ramsammy » Mon Nov 26, 2018 8:38 pm
musbase wrote:Hi ramsammy,
Good luck.
Best regards,
musbase
Garry
I am still stuggling to either private message someone or reply with an attachment. If I can do it on another site I will let you know here
ramsammy
Postby ramsammy » Mon Nov 26, 2018 8:59 pm
There is a copy of the manual here
https://www.gearslutz.com/board/low-end ... logic.html
Garry
ramsammy
Postby blinddrew » Mon Nov 26, 2018 9:30 pm
The forum doesn't host attachments, so you'd need to find somewhere else to host and then link here.
If you're posting from a mobile I don't think the envelope shows. You have to go through the Control Panel, then Overview (change to PMs), then new message and then add in the user there.
It's not the most straightforward of systems but it's part of the forum software so... :roll:
Postby ramsammy » Mon Nov 26, 2018 9:51 pm
Thanks Blinddrew, I hope I have done it.
Garry
ramsammy
Postby The Elf » Mon Nov 26, 2018 9:55 pm
If I do come across a copy of the manual some time (and I feel sure I still have it somewhere) I'll create a PDF of it.
Postby musbase » Wed Nov 28, 2018 11:58 am
Hi Garry,
That did it for me, many thanks!
Best,
musbase
ramsammy wrote:There is a copy of the manual here
Garry
musbase
