Pitbull guitar kits
Re: Pitbull guitar kits
Postby blinddrew » Fri Apr 13, 2018 10:48 am
Think it's just a scratch rather than a dent or a ding but I'll have a proper look in decent light at the weekend.
Or gaffa tape... ;)
Postby blinddrew » Fri Apr 13, 2018 9:28 pm
Looks like it's just a glue smear, should sand off hopefully.
Postby Sam Spoons » Fri Apr 13, 2018 10:51 pm
use a cabinet scraper first, they don't tear up the grain like sandpaper?
Postby zenguitar » Sat Apr 14, 2018 12:56 am
+2
The cabinet scraper remains my favourite tool.
Yogi Berra
Postby blinddrew » Sat Apr 14, 2018 10:07 am
I was assuming that since the whole thing will require extensive sanding I'd pick it up with that. However, whilst there's no such thing as a dumb question, not listening to the answer is a different matter...
It's not something I currently own but I shall have a look in my grandad's toolkit next time I'm down at my parent's place.
Thanks gents, :)
Postby Sam Spoons » Sat Apr 14, 2018 10:15 am
Time for a quick treatise on use of the cabinet scraper in modern Lutherie Andy? :thumbup:
Postby Wonks » Sat Apr 14, 2018 12:02 pm
The body won't need much in the way of sanding at all. it's basswood ply, which is a closed pore wood and it won't have the machining marks that solid wood bodies will have. Normally just some tidying up round the F-hole binding and a drag sand over the body after damping it with water to raise the loose fibres. It's the neck that will need the most sanding, but even then, not a huge amount.
Postby blinddrew » Sat Apr 14, 2018 12:30 pm
That makes sense, cheers
Postby zenguitar » Sat Apr 14, 2018 12:34 pm
It would appear that the trend in modern luthierie is to use sandpaper ;)
But the benefits of a scraper are that it can be quicker and leaves a better finish. Plus you don't have to buy as much sandpaper and you don't get all that nasty sanding dust.
Yogi Berra
Postby Wonks » Sat Apr 14, 2018 1:23 pm
Just scrapey dust. ;)
Postby Sam Spoons » Sat Apr 14, 2018 3:34 pm
Little scrapey curls are much nicer than what my father in law (a craftsman joiner) used to refer to as "wood dust" (he consistently refused to call it "sawdust").
Postby blinddrew » Sun Apr 29, 2018 9:48 pm
Just thought I'd share a few pics for them as is interested.
So far I've cut and shaped the headstock, leveled and sanded/polished the frets, and sanded and grain-sealed the body and neck. It has not all been plain sailing.
The headstock:
The heel:
The back:
The front:
Postby zenguitar » Sun Apr 29, 2018 11:49 pm
I tried to view the image links but was invited to sign in to Google to view them.
Yogi Berra
Postby Wonks » Mon Apr 30, 2018 8:23 am
I could see them yesterday, now I can't.
Postby blinddrew » Mon Apr 30, 2018 1:33 pm
Head.
Desk.
Interface.
Sorry, will repost tonight with a different link. Google-hosted images work differently on different forums and I chose incorrectly on this one. I obviously used the link that requires you to be signed in this time rather than the general access one.
Ho Hum.
I miss having my own web hosting. :(
But not enough to pay for it... ;)
PreviousNext
