Pitbull guitar kits
Re: Pitbull guitar kits
Postby blinddrew » Mon Apr 30, 2018 8:37 pm
Postby Wonks » Mon Apr 30, 2018 10:18 pm
That's because you're referencing the page the photos are on, not the actual photo itself.
Postby zenguitar » Tue May 01, 2018 12:23 am
Looks good so far :)
Yogi Berra
Postby blinddrew » Tue May 01, 2018 10:15 am
Wonks wrote:That's because you're referencing the page the photos are on, not the actual photo itself.
Yeah, I tried linking to the photos (copy link address - as I have on the pitbull forum) the first time. So I tried the 'create link' option this time. Next time I'll just tell everyone it looks amazing and not provide any photographic evidence... ;)
zenguitar wrote:Looks good so far :)
Thanks Andy, I think it's shaping up ok. There have already been a few hitches along the way so I'm expecting plenty more before I'm done. I'm currently just avoiding thinking about how I'm actually going to install the electronics...
Postby garrettendi » Tue May 01, 2018 10:33 am
Good work! What finish do you plan to use - are you going to paint/stain it?
garrettendi
Postby blinddrew » Tue May 01, 2018 11:58 am
I have a thing for natural wood finish guitars so given how nice the ply is I'm going to add this to the collection. So from that perspective the work on the body is now largely just sand-oil-repeat using ever finer grit and moving to diluted oil.
The neck has a couple of spots that have highlighted where I haven't done a good enough job on the sanding yet, particularly around the inside of the heel curve. Might need to make myself a mini curved sanding block.
Postby Sam Spoons » Tue May 01, 2018 12:00 pm
Installing the electronics in an archtop is akin to performing gynaecology with a backhoe. But the basic principle is to feed everything in through the pickup aperture. Or you could just use a pickguard mounted volume and jack socket (and a floating pickup..... oh hang about the PU hole is already there)? It is easier with a single pickup guitar as you only need a single volume and tone and a jack socket (I wired an ES175 clone with 2 x V&T controls, selector switch on the upper bout and jack socket). If you can manage without a tone control, even easier. To get the jack installed make up a length of wire coat hanger with the tip and sleeve of a jack socket soldered to the end, feed the nut and washer on before threading it through to the pickup hole, pop the socket on it and pull it back through. The pots are a little more difficult but fee two ends of some link up wire through from the holes (nuts threaded first) to the PU hole and twist the stripped ends around the neck of the pot shafts, squeeze the wire onto the slot and gently pull through. Before you start wire up everything on a cardboard template so the lengths are right and Robert is you relative.
Postby Random Guitarist » Tue May 01, 2018 12:06 pm
If you can get some easily, silicon tubing is great pulling for the pots through.
Feed it into the hole and slip over the knurled shaft then just pull the tube out and the pot comes with it
Random Guitarist
Postby Sam Spoons » Tue May 01, 2018 2:22 pm
Random Guitarist wrote:If you can get some easily, silicon tubing is great pulling for the pots through.
Neat :clap:
Postby blinddrew » Tue May 01, 2018 5:19 pm
Thanks both! Suggestions filed for later :)
Postby zenguitar » Tue May 01, 2018 5:45 pm
And here's another wiring trick for semis.
Get a piece of cardboard and copy the pick-up cavity, holes for pots and switches, and the jack socket and also the f hole. Then you can flip the card over, put the pick-up and parts in place and wire everything up.
Then you have a complete wiring loom that you know will fit without lots of extra cable flapping around. And you can ensure that the loom is not visible through the f hole.
Yogi Berra
Postby Sam Spoons » Tue May 01, 2018 6:02 pm
Also neat :thumbup: I had thought of (and suggested) a cardboard template but wouldn't have thought of marking the f holes..... Genius......
Postby Wonks » Tue May 01, 2018 6:25 pm
It's an easier guitar compared to most as being hollow-bodied, you can fit full-sized pots and the jack through the pickup hole. It's a lot trickier with F-holes and semi-hollows.
I'd ditch the thin kit wire and use some stiff wire between the volume and tone pots and a decent capacitor with stiff legs (like a Sprague orange drop), and do the cardboard template thing, and it's really easy to pull things through. I normally use cotton for pots and string with knots in for the jack socket (I use blu-tac to weight the lines so they hang down when standing the body upright and so can angle them so they appear at the relevant hole).
The tubing can work well, but on some kits you need a lot of it and you've still got to get it through the small pot holes and then out again through the pickup hole. Easier to do on thinner semi-hollow kits where you're using the F-hole and that's near the control holes, but for a full deep hollow body, I'd think cotton and string would be easiest. An extra pair of hands is always welcome at this stage, so they can hold the end of the shaft whilst you cut the cotton away and do the nuts up.
Postby blinddrew » Tue May 01, 2018 8:37 pm
Thanking y'all. I'd had a template in mind but, like Sam, hadn't considered marking the F Holes. :)
Postby Wonks » Tue May 01, 2018 8:49 pm
TBH, it's not an issue on that kit with both controls on the one side of the F-hole. More of one on a 335-style with controls on both sides and you need to wire in a U-shape.
PreviousNext
