ContinuuMini
Re: ContinuuMini
Postby BobTheDog » Tue Nov 20, 2018 6:04 pm
Kickstarter has started: https://www.kickstarter.com/projects/16 ... ntinuumini
I got in early and will get one of the first batch, I will let you know how it goes...
BobTheDog
Re: ContinuuMini
Postby BJG145 » Tue Nov 20, 2018 7:31 pm
Tier 1 was gone within hours, and Tier 2 is selling fast.
I agonised about it for a few minutes and had just decided not to, then I saw your post and went for it.
Thanks (I think)...
Re: ContinuuMini
Postby BobTheDog » Tue Nov 20, 2018 8:31 pm
I think you made the right choice, hopefully.
When it was first announced I wasn't sure if the point of it thinking it was just a controller, I didn't realise it had the Eigen synth inside.
From the kickstarter video it looks like this is also playable over midi.
Got to be a bargain ;)
BobTheDog
Re: ContinuuMini
Postby BJG145 » Fri Dec 07, 2018 1:25 pm
278 backers with 4 days to go.
It would be nice to reach the stretch goal for 300 backers...go on, you know you need one! New video available...
https://youtu.be/c_DvPykpJrc?t=689
Re: ContinuuMini
Postby BobTheDog » Wed Dec 12, 2018 8:56 pm
I think it reached 300.
Two weeks before they get the money though so my idea of spending Christmas Day locked away playing it are beginning to look a distant hope :(
BobTheDog
Re: ContinuuMini
Postby resistorman » Thu Dec 13, 2018 6:49 am
I played one and it felt like I was sticking my fingers into a mail slot. I often touched the sides. Great sound though.
resistorman
future26.com
Re: ContinuuMini
Postby BobTheDog » Thu Dec 13, 2018 8:28 am
I did wonder about that, on one of the videos you can see the playing surface moving down quite a bit.
BobTheDog
Re: ContinuuMini
Postby BJG145 » Wed Apr 03, 2019 7:31 pm
...so, Continuumini arrived today. WDYT BobTheDog...?
I'm perhaps fortunate in never having played a full Continuum, because then I'd want one for sure...but at £3800 or so for a half-size one, it's just not going to happen. They never turn up secondhand, and there are several cheaper things higher up on my "...that looks nice..." list.
...I like that it has the same excellent built-in synth engine, the EagenMatrix, since most of my gadgets are MIDI controllers. It's nice and compact and light, and I'm looking forward to showing it off with a guitar strap. There aren't many ribbon synths around, and it's a pretty nice one.
Pressing the control plate probably isn't quite the same as carressing the red cloth of a full-blooded Continuum, and you might want an additional control for full 3-axis expression rather than relying on the tilt sensor. But, it ain't half bad if you like ribbon synths. I've seen a second-hand Persephone go for more, and - yes, those look pretty cool, but as an expressive musical instrument, I doubt it has the potential of the Continuumini.
I'm going to have some fun with this. :D
Re: ContinuuMini
Postby BobTheDog » Wed Apr 03, 2019 7:44 pm
BJG145 wrote:...so, Continuumini arrived today. WDYT BobTheDog...?
Well EagenMatrix is fantastic, for me this is worth the asking price but that is because I am playing it from the Linnstrument, they are perfect partners.
The Continuum playing surface though I think for me is not so good, the Y axis is basically unusable and the Z axis is not linear across the surface.
So for me it is rescued as a sound module for the Linnstrument, without that I would have been disappointed.
BobTheDog
Re: ContinuuMini
Postby BJG145 » Wed Apr 03, 2019 8:38 pm
...that's an interesting idea; I've not seen a Linnstrument yet. I'd agree that EagenMatrix is nice, but that the playing surface may leave something to be desired if you're used to certain other controllers.
Here's a random example of what it sounds like after the first couple of minutes of playing...
https://soundcloud.com/qchord/continuumini/s-5iZq4
(...just the initial sequence, not whatever Soundcloud plays next...)
Re: ContinuuMini
Postby Sam Spoons » Wed Apr 03, 2019 8:45 pm
I really fancy an EigenHarp, the Pico being the only affordable one, but at my advancing years I don't know if I could justify the time to learn to play one. Then a mate gave me one of these :-
I like to think is might be a sort of analogue ContinuuMini, but I'm probably wrong :(
Re: ContinuuMini
Postby BJG145 » Wed Apr 03, 2019 8:55 pm
I haven't seen one of those before...looks like a phonofiddle without the bell...?
Sam Spoons wrote:I really fancy an EigenHarp
(...yeah, me too...I was thinking that the EagenMatrix would be nice to play with an Alpha...)
Re: ContinuuMini
Postby Sam Spoons » Wed Apr 03, 2019 8:57 pm
I've seen those before. I suspect it might predate the Phono Fiddle (a mate of a mate had one) I plan to learn a couple of Gypsy Jazz tunes on mine when I have rebuilt it.....
Re: ContinuuMini
Postby BobTheDog » Wed Apr 03, 2019 9:12 pm
I have a Pico, the engineering of the hardware is top notch, the software left a lot to be desired though but I think this may have improved now.
Mark Harris (thetechnobear) who is a smart cookie has worked on the eigenharp software and general MPE so I am guessing there is a way there with eigenmatrix.
I cannot recommend the Linnstrument enough though.
Compared to an Alpha, not only is it much cheaper you don't need some sub-par software running on a computer to use it. Everything on the Linnstrument can be controlled/setup from the Linnstrument surface itself, it is a masterclass in design.
BobTheDog
Re: ContinuuMini
Postby BJG145 » Wed Apr 03, 2019 9:28 pm
BobTheDog wrote:...I cannot recommend the Linnstrument enough though...it is a masterclass in design...
...not listening...la la la... :beamup:
Re: ContinuuMini
Postby Sam Spoons » Thu Apr 04, 2019 9:49 am
Not really what I'm looking for though. I play flute and whistle (very badly) and can't play brass or reeds, I want an EWI of some kind to replace my old, and only occasionally used, Casio Digital Horn. The downside of the Pico is no onboard sounds (though it does share that with most EWIs).
Re: ContinuuMini
Postby BJG145 » Thu Apr 04, 2019 3:13 pm
Sam Spoons wrote:I play flute and whistle...The downside of the Pico is no onboard sounds
Bob Bickerton was recently praising the Sylphyo, which now seems to have its own built-in sounds and is more flute/whistle like than a Pico or an EWI because it allows full airflow.
https://www.soundonsound.com/forum/view ... yo#p592690
Another thing I'd like to try out...
Re: ContinuuMini
Postby Sam Spoons » Thu Apr 04, 2019 3:44 pm
The Aerophone does what I want and is a decent price but it does look pretty clunky as has been said. The Sylphyo looks great and the demo is lovely but it's also €800 so, sadly, too much for me. The Akai EWI USB has no sounds but is a very good price at Andertons as I type (£259, tempting). But I've just contradicted my last post and made an offer on an Eigenharp Pico, waiting to see if it's accepted (I feel a Raspberry Pi sound module coming on.......)
edit :- Offer accepted on the Pico :D
So, I can use it with a MBP, iPad/iPhone or 'droid (with the appropriate adapters) if I ever get the bottle to play it live or the MacPro in the studio but is there a way to connect a USB controller to my Model D without a computer in the middle?
edit 2 :- Oh, and sorry for the thread hijack BJG
Re: ContinuuMini
Postby BJG145 » Thu Apr 04, 2019 6:56 pm
Sam Spoons wrote:Offer accepted on the Pico
Great, congrats...!
Sam Spoons wrote:So, I can use it with...iPad/iPhone or 'droid...but is there a way to connect a USB controller to my Model D without a computer in the middle?
...huh...?? In your dreams... :tongue:
*spoiler alert*
...this may become a long-winded self-opinionated rant. But what's new...
I have a Pico, which I'm fond of, because the sticker on it says: "Engineering sample - not for sale". Which means some hapless Eigenlabs tech swiped it and flogged it anyway. I can get behind that.
Once again, BobTheDog's assessment is on point. The engineering behind the Eigenharp range is terrific, but the software is terrible.
Perhaps, in a way, it was over-ambitious. There's this idea that MIDI was inadequate - the resolution of the Eigenharp sensors exceeded the MIDI spec. So it had its own software. But beyond the first rudimentary proprietary instruments, no other ones were forthcoming. So you're bound to use MIDI anyway; but you're stuck with the cumbersome PC/Mac software as an interface.
The software was made open source, and fortunately experts like Mark Harris ("The Technobear") have since made many improvements to it. Mark is into his Linux devices, and has got it working on hardware platforms such as the Raspberry Pi, but it's quite hard work. There's certainly no way to use the Pico directly with an iPad or MIDI device.
The good news is that the software is quite deep and powerful, if you have the time to figure it out. There's a component called "FIngerer" which allows you to configure any fingering you like, and that's its salvation IMHO.
In the default settings for the the Pico, you're confined to note-per-button systems which usually leave people noodling badly on pentatonic scales. But Fingerer makes things much more interesting.
Fingering is all. I'm a big fan of the system developed by Nyle Steiner for the "EVI" which I talked about here. It's very efficient and economical, providing chromatic playing over several octaves, and can still be dialled up on subsequent EWI models right up to the current Akai EWI 5000.
OK, so the trumpet was my first instrument, but...it just works. The underlying concept is to have chromatic half-octave fingering on three right-hand keys, while the left hand moves upwards in half-octaves using some method. On the original EVI, the left-hand control was this curious rotating cylinder...
On a modern Akai EWI, it's an "octave roller"...
On the Morrison Digital Trumpet I posted about here, it's this pattern of left-hand buttons...
...they all do the same thing. Before I got hold of the Morrison Trumpet and discovered that system, I configured the same pattern on my Eigenharp Pico, because it's just a natural way to implement Steiner EVI fingering with a row of buttons.
I posted up this example at the old Eigenharp Google Group (Pico through Papen Blue with EVI fingering), and...I'm simply bragging here, but the Eigenharp's inventor John Lambert seemed quite impressed. You'll have to take my word for it, because Google Groups has been discontinued now.
There's a post on the old original Eigenharp forum here with links to an archive of some of the old Google Groups material and their new home in a subsection of a group devoted to Midi Polyphonic Expression.
My ramblings about an EVI implementation for Fingerer can be found here:
http://www.eigenlabs.com/forum/threads/ ... _post12420
It's gotta be better than someone else's suggestion of Gray Code... :headbang:
Re: ContinuuMini
Postby Sam Spoons » Thu Apr 04, 2019 10:32 pm
Ah, interesting, thanks BJG, you might get the odd PM from me for your pains (sorry in advance). TBH I'll probably only use the Pico for basic melody playing and brass/string section stuff, anything live would be unlikely so the lack of 'normal' midi probably is not going to be a real problem. We'll see, but at the price I paid I shouldn't lose much if I decide to move it on and buy the Akai EWI USB instead. Maybe I can configure it as a sort of 'super melodica' ;) I could probably cope with that.....
