Aria Sinsonido preamp repair
Re: Aria Sinsonido preamp repair
Postby Folderol » Fri Jun 15, 2018 9:24 am
Dr R wrote:
Martin Walker wrote:
ef37a wrote:
Dr R wrote:So what should I look for next?
Folderol's postal address and bubble wrap?
:clap: :bouncy:
Well that's no pressure on the good gentleman then!
It's OK, these are my friends... I think :lol:
If you really are stuck, send me a priv message - I'm a sucker for an unusual challenge :shh:
Yes. I am that Linux nut.
Postby ef37a » Fri Jun 15, 2018 12:36 pm
Did I bolt you up Will? Sorry if so, I thought you had made an offer?
Postby Folderol » Fri Jun 15, 2018 3:03 pm
Now that's an expression I've not heard before - must be one of those Northern things :lol:
Anyway, I'm quite happy with the idea.
Postby ef37a » Fri Jun 15, 2018 3:11 pm
Folderol wrote:Now that's an expression I've not heard before - must be one of those Northern things :lol:
Oh! Yes, getting "bolted up" is being volunteered/pressed into a task that you did not want and is not actually in your job descrip'!
Not to be confused with "fitted up" which is something our police never do or ever did.
Postby Dr R » Fri Jun 15, 2018 4:51 pm
Folderol wrote:If you really are stuck, send me a priv message - I'm a sucker for an unusual challenge :shh:
In that case I most definitely will, thank you.
Rich
Dr R
My ambition: To one day have enough experience to answer technical questions on the SOS forums, as well as asking them
Postby Folderol » Wed Jun 27, 2018 11:46 pm
This is proving to be a very strange design indeed! I've worked out a drawing, and it's so strange I had to keep re-checking it :o
See here.
(Updated diagram shown above)
Cold checks with a meter suggest there are no faults, so the tone control should work, if there are no dried out caps, although with such low impedances I'm not quite sure how! The unmodified gain of the amplifers is 20, so those 1u feedback caps will behave as if they were about 20u.
Notice that DC supply to the microphones. This makes me think they are electrets
As soon as i can get into the office, I'll snaffle their all-singing cap tester and find out what the actual values are.
The 150n 'dry' caps are a guess based on the amp spec sheet.
The 0u22 ones are actually mis-printed so any dot would be off the edge of the cap. Size-wise they couldn't realistically be 22u, and it wouldn't make sense, bearing in mind the feed caps are only 33u.
All very strange :?
Postby zenguitar » Thu Jun 28, 2018 12:13 am
Bravo Folderol.
Yogi Berra
Postby Martin Walker » Thu Jun 28, 2018 3:44 pm
And I agree with you that it's a very strange circuit! :?
Are you sure those 1u caps are not connected between pins 1 and 8 of the LM386?
Postby Folderol » Thu Jun 28, 2018 4:33 pm
Absolutely. Pins 1, 7, 8 are as naked as a newborn baby.
Also today I did a few active tests in my {cough}kitchen{cough} workshop, using my signal generator (of DIY amp fame) and a modern true RMS multimeter. At these low frequencies they're pretty good.
I worked with an output level of 1V, which is quite reasonable as a headphone level, and as I'm not sure of the correct source impedance, I used 600ohms, 2.2k and 47k. The result was entirely consistent across all of these, which is something I didn't expect actually.
I can confirm the tone control has no measurable effect at all over the range 40Hz to 4kHz :o
Also, the -3dB point relative to 400Hz is 70Hz, which is way too high for a bass.
I might try tapping caps across those present (particularly those 33u coupling ones) and see what transpires.
I'm not at work tomorrow, but if I'm down that way I might drop in and see if I can borrow the cap tester - I should probably get one myself :roll:
Postby Dr R » Thu Jun 28, 2018 6:05 pm
;) :clap: Huge thanks to Folderol for taking this on. It's beyond the limit of any electronics I have ever forgotten. Which is the tone pot pair??
I think we've found someone who can measure the microphone impedances as requested in a PM. Will let the forum know the outcome.
Thanks again to everyone!
Rich
Dr R
Postby Folderol » Thu Jun 28, 2018 6:13 pm
OK, there is an error in tracing the circuit, and it now makes much more sense :blush:
(Updated image -- HR)
If you click on the link itself, you'll get the corrected drawing. The 1u caps are compensation ones that go from the top of the volume control to the wiper.
This doesn't invalidate any of the actual tests. Also the latest news is that the 0.47u caps are dead, tapping one across them immediately made the tone control work.
The 'dry' cap and the 33u one are effectively forming a 2nd order high pass filter, both of them are dropping a significant voltage at 70Hz. Using an R/C calculator, the 33u one against the volume pot at full volume should give a -3dB point of 4.8Hz! so it looks like those are also dead-ish and the only ones that's supposed to be affecting the roll off should be the 'dry' ones. I only guessed their values, but with the behavior shown and good caps elsewhere I would expect the -3dB point to be nearer 45Hz - much more reasonable.
I'm wondering if the unit has been left somewhere hot for an extended period, or is much older than I thought.
Postby Hugh Robjohns » Thu Jun 28, 2018 6:14 pm
Pretty sure they are going to be electret mics given the DC supply present on the mic lines. All electrets have an active impedance converter-cum-output-driver. So they will have a very low output impedance of the order of 100 Ohms or less.
Postby Martin Walker » Thu Jun 28, 2018 8:39 pm
Aha - the 1uF caps now make FAR more sense Folderol! 8-)
Postby Dr R » Fri Jun 29, 2018 6:30 am
The instrument lives in north Wales - but does travel to South Africa and France for extended periods so heat damage is entirely plausible.
As an aside: Apparently it's great to travel with as it's light and will go in an aircraft overhead locker. The downside is that in its bag it looks like a rifle and airport security get very twitchy :-)
Dr R
Postby ef37a » Fri Jun 29, 2018 12:21 pm
Well done that man!
Are you sure those capacitors are not old Tantalums? They promised much but after just a few years generally delivered shorts! I guess a few also went open circuit.
PreviousNext
