Which ways of reverb application do you prefer? filtered one or the full range one?
Postby Parco » Tue Jun 19, 2018 5:42 pm
Full freq. range reverb like this?
https://soundcloud.com/parcolee/wheneve ... ush-reverb
https://www.youtube.com/watch?v=4EUU_Xppg9w
Or just keeping the 200Hz - 5000Hz freq. of reverb and filtering all the rest like this?
https://soundcloud.com/parcolee/wheneve ... red-reverb
https://www.youtube.com/watch?v=j6jj30V4pXI
I think the filtered one sounds closer but the full range one sounds similar as the Maxwell's one. :beamup:
Parco
Sonar PLT + Foobar2000 -> ASIO + MMCSS + Windows 10 -> SIIG NN-E20012-S2 -> Echo AudioFire 4 -> HH MX250 + Wharf Delta70 A native USA style contemporary R&B artist in HongKong
Re: Which ways of reverb application do you prefer? filtered one or the full range one?
Postby Dave B » Tue Jun 19, 2018 7:12 pm
Some reverbs do have high and low pass filters - the Eventide 2016 Room reverb certainly does. For me, I tend to put an eq in to remove highs and lows before the reverb if I don't have appropriate control in the reverb plugin. So, either way, I still filter the signal hitting it.
Dave B
Postby ken long » Tue Jun 19, 2018 7:46 pm
I've just acquired a long time want in the shape of a PCM60. So at the moment nothing gets filtered and I tend to drown everything in it. I'm sure I will settle down to a conservative setting with treble contour on :)
ken long
I'm All Ears.
Postby Martin Walker » Tue Jun 19, 2018 7:48 pm
Dave B wrote:For me, I tend to put an eq in to remove highs and lows before the reverb if I don't have appropriate control in the reverb plugin. So, either way, I still filter the signal hitting it.
+1
You really do need EQ some way or another with reverb.
Postby ken long » Tue Jun 19, 2018 7:48 pm
I prefer the full fat version myself.
ken long
I'm All Ears.
Postby CS70 » Tue Jun 19, 2018 8:25 pm
On the main reverbs usually I put some hi and lo pass filters, and sometimes shape the response. On track-specific, it depends on the content. for example in a vocal track there's little to reverberate in the low end so I may well not bother
Postby James Perrett » Tue Jun 19, 2018 8:38 pm
I also like reverbs with different time constants for high and low frequencies.
Postby Bob Bickerton » Tue Jun 19, 2018 9:08 pm
I prefer something like the UAD Lexicon 224 for most applications.
Manipulation of decay time over frequency bands works best for me.
Bob Bickerton
http://www.bickerton.co.nz
Postby Sam Inglis » Tue Jun 19, 2018 10:17 pm
It totally depends on the application. On a snare drum, anything goes. On a solo violin, less so.
Sam Inglis
Users browsing this forum: Arpangel, wdsteele
