Tape Hiss Emulation: White Gaussian vs White Uniform Noise?
Postby Uncle Freddie » Wed Jul 18, 2018 2:11 pm
For several projects, I am incorporating a quiet track of stereo white noise to emulate "high quality" tape hiss.
By high quality I mean tape hiss from a properly calibrated pro open reel machine (in addition to noise from the console it would have been connected to) as opposed to a cassette deck.
I use iZotope RX6 to generate the white noise files; it offers several flavors of noise:
White Gaussian
White Uniform
White Triangular
White Binary
I know enough to know that White Triangular and White Binary are not useful in this case. So it comes down to White Gaussian vs White Uniform.
I created some 1 minute, -15dBFS RMS, 24bit, 96kHz files here:
http://substrate.com/whitenoise/rx6,noi ... df,01m.wav
(While these files are indeed loud, a project would use them at a much lower volume.)
FWIW, looking at Gaussian white noise on a goniometer, it is a more rounded blob, whereas Uniform white noise is a diamond blob:
http://substrate.com/whitenoise/white_gaussian.png
http://substrate.com/whitenoise/white_uniform.png
Finally, while I have to admit that they both sound fine, Gaussian sounds different from Uniform; I hear the difference clearly. In situations like this, I turn to science.
So, from a purely analytical, physical and magnetic standpoint: which one makes the correct impersonation of tape hiss?
Thanks,
Fred
Uncle Freddie
Re: Tape Hiss Emulation: White Gaussian vs White Uniform Noise?
Postby Hugh Robjohns » Wed Jul 18, 2018 2:30 pm
The different white noise descriptors relate to the probability distribution function properties of the noise signal, which becomes relevant if used for dithering. But in your situation, Gaussian is probably the best one to use.
However, genuine tape noise is actually a lot more complicated than simple 'constant' white noise because there are all kinds of noise modulation and filtering effects going on in a real tape machine.
Postby Uncle Freddie » Wed Jul 18, 2018 8:09 pm
Thank you very much, Hugh.
-Fred
Uncle Freddie
Postby James Perrett » Wed Jul 18, 2018 8:24 pm
Oddly enough I saw something about this a few days ago but can't find the link. The tape noise spectrum is dependent upon the speed and equalisation used and often contains more energy in the high midrange than a white noise signal. U-he's Satin tape emulator will generate noise and allows you to play with different eq settings.
If you don't mind short files I can probably dig out some noise excerpts from various tapes I've transferred.
Postby John Willett » Thu Jul 19, 2018 3:22 pm
Just makes me laugh - all those years trying to minimise all the the problems of hiss, modulation noise, wow, flutter, and all the other problems.
And when we *do* get rid of them - people want to put them backing again. :headbang:
John Willett
Users browsing this forum: Aural Reject
