Let’s talk about CHIPTRACKERS and writing Chiptune music!
Postby Ben Asaro » Fri Aug 10, 2018 1:10 pm
Sorry, long post below. Skip to the TL;DR if you cba. :)
My dive into Synth Obscura continues! A recent recommended video on YouTube sent me digging into the world of Chiptune— electronic music made to emulate the soundtracks from old 8/16 bit video games, particularly the Nintendo GameBoy.
As with everything else, there are two approaches to writing Chiptune; one approach is to use your DAW as normal but with limited tracks and emulation plugins or raw wave forms; the other approach is to use what is called a Tracker ... actual software in the style used by the original game composers. Trackers can export either wav files or the actual file type used by the game system. In theory you can then play your music on the actual original game system. (This has been done by some creative people in the DIY/maker community).
There is also a third branch of the Chiptune tree, called LSDJ; they use an actual GameBoy hack to make the unit itself into a tracker for writing, recording, and playing back music.
The fourth branch of Chiptune enthusiasts are non-musicians who hack old video games and use trackers to play back the music only.
And the fifth branch are similar to the fourth except they take the ripped music and then create remixes in the tracker.
I think the appeal of a Chiptune is its minimalist approach— how much can do do with how little? That really appeals to me, so I looked online for a tracker. I settled on DefleMask after watching some tutorials (plus it works for Mac).
At first it was utterly confusing, but after an hour or so I was able to start writing music on it. I chose a very simple system to practice on (NES) and started figuring out how to navigate through the vertical, pre-DAW interface. The biggest hurdle is sorting out tempo and time signatures. Since it is Base 16 and the tempo is derived from the clock frequency of the system you are using, it takes a lot of experimentation to get the precise feel and level of swing down.
Starting with the most simple waveform available, a pulse wave, you can set up a number of ‘instruments’. An Instrument is actually just an arpeggiator and amplitude envelope that your draw by hand. You can assign any individual note to any Instrument, which is how you can add expression from short to longer (or sliding) notes.
Each track can then have a certain number of ‘effects’ added like panning, overall volume, and start/stop codas. These are input by hexadecimal code, of course. :D
TL;DR
If you already have an understanding of synthesis and music production it will not take long to figure out how a tracker works and the results are surprisingly accurate! I definitely recommend trying a chiptarcker out for authentic 8-bit music reproduction.
Ben Asaro
Re: Let’s talk about CHIPTRACKERS and writing Chiptune music!
Postby Martin Walker » Fri Aug 10, 2018 7:34 pm
Hi Ben,
This takes me back almost 30 years, when I was composing 8-bit computer game soundtracks and creating sound fx for them - I had over 100 commissions in total!
I always worked on the actual hardware, so I could hear exactly what the end-user would hear, and developed my own music drivers and editors.
Over the years I worked on Atari 400/800, Commodore 64, Atari ST, Commodore Amiga, Sega Gamegear, NIntendo Gameboy, Nintendo SNES, Sega Megadrive and the PC itself (motherboard buzzer, Adlib soundcard, Roland LAPC-1 MIDI soundcard...)
It all seems so long ago, although I now find myself being asked to create music on the Commodore 64 all over again! 8-)
I did do some work using tracker software (notably on the Amiga), but much preferred to use my own Music editors.
Postby Ben Asaro » Fri Aug 10, 2018 11:14 pm
Wow, that is super cool/interesting!
Hmm, Commodore 64 is certainly a challenge, it’s even more limited than the GameBoy! I would love to hear some of your stuff!
Ben Asaro
Postby Martin Walker » Sun Aug 12, 2018 2:53 pm
There's loads of it on YouTube Ben ;)
Here are some of the Commodore 64 tunes:
https://www.youtube.com/results?search_ ... walker+c64
Postby Ben Asaro » Sun Aug 12, 2018 3:00 pm
Thanks, I will definitely check them out!
I found a great Chiptracker/Chiptune tutorial from 2013 on Youtube, for anyone following this thread and is curious how to get started. Just search on Youtube for "Brandon Walsh Milkytracker".
Which brings me to the subject of trackers! I started using DefleMask but think I prefer Milkytracker. It's not as slick as DefleMask but I prefer its look and workflow.
Ben Asaro
Postby Ben Asaro » Wed Aug 15, 2018 3:27 pm
Martin, this stuff is AWESOME!!
Ben Asaro
Postby Ben Asaro » Wed Aug 15, 2018 3:40 pm
A couple of quick questions, if I may, Martin?
How did you achieve that thick pwm lead sound? Did you start with a sample that had several pulse waves and then hand-drew the duty cycles so that when it was looped it would simulate pwm? Or is it done in another way? I don't see any real modulation aside from 'vibrato' in my effects choices.
Also, it sounds like some of the leads were done on two tracks and one was detuned slightly? Is that correct?
Thanks in advance!!
Ben Asaro
Postby nathanscribe » Wed Aug 15, 2018 6:43 pm
As soon as anybody mentions 8-bit micro music, I think of Tim Follin, whose work I think is incredible, given the limitations of the early machines. 1-bit multitracks? No problem!
https://www.youtube.com/watch?v=GC1dTzyb5Gs
nathanscribe
Postby Ben Asaro » Wed Aug 15, 2018 6:50 pm
Thanks for posting that, interesting stuff! It also explains how to get pwm (or at least one method)! Gonna try it tonight. :)
Ben Asaro
Postby nathanscribe » Wed Aug 15, 2018 7:06 pm
Nice work Martin! Didn't know you were behind some of those!
The Citadel 'scope view shows nicely how a single channel can be used to generate more than one 'simultaneous' (spoiler: not really) tone by quickly alternating between them. Handy but there's a knack in getting it right, I seem to remember!
nathanscribe
Postby Ben Asaro » Wed Aug 15, 2018 7:08 pm
nathanscribe wrote:Nice work Martin! Didn't know you were behind some of those!
I'm using Milkytracker/XM so I have the luxury of polyphony!
Ben Asaro
Postby Martin Walker » Thu Aug 16, 2018 5:06 pm
Ben Asaro wrote:A couple of quick questions, if I may, Martin?
Thanks in advance!!
All done with pulse width modulation, which you can do by updating the pulse width 50 times a second on each of the three SID channels).
Postby Martin Walker » Thu Aug 16, 2018 5:08 pm
Thanks nathan!
Just like the PWM, the 'chords' are generated by cyclically changing the frequency every 1/50th of a second around the notes of your desired chord. I did occasionally expand on this by having multiple chords going at different rates in different channels, for that really big 'soundtrack' effect (Armalyte and Citadel both used this approach) ;)
Postby Martin Walker » Thu Aug 16, 2018 5:11 pm
Oh, and here's an example of my 1-bit multitrack music
The First Samurai PC Speaker Intro, played on a motherboard buzzer :headbang:
https://www.youtube.com/watch?v=AiURTmwpX2U
Postby Ben Asaro » Fri Aug 17, 2018 1:01 pm
Started working on my first mod. Will post a link when it’s done, would love feedback!
Ben Asaro
Next
