Cheers! :thumbup:
So, from the start... This is around a year ago when I’d finally gathered enough parts to get started on building. 10U rack case fitted with a power distro, Korg rack tuner, Voodoo Lab GCX switcher, and a heavy duty sliding shelf.
I tried a few different layouts for the pedals, and settled with this arrangement. Although it’s a fairly snug fit, I wanted to make sure there’s enough room to un-patch pedals without tearing everything up from the tray in case of any failures with cables or the pedals themselves. The box mounted on the back of the tray is a Kenton MIDI Thru 5, which feeds the MIDI inputs of the GCX and the 3 Strymons.
The idea is that pedal bypass, patch changes on the Strymons, and amp channel switching can all be programmed to a single footswitch, as well as real time control over any parameter on the Strymons via an expression pedal. Fun times.
I’ll keep digging through the photos and getting them uploaded each day. I’m still yet to start the pedalboard end, so hopefully I’ll catch up with myself before I get any further with the build.
