Recording 'line out' virtually
Postby Elephone » Tue Oct 09, 2018 1:28 am
Hello. There are some delay effects in adobe audition that I like, and don't appear to be automate-able. I was going to take a line out and record, then play it back in, but I'd much rather capture it virtually.
Is there any way to route or capture the output in realtime without taking a line out, with standalone software like audition? Is there some software similar to streaming software that will capture it? In full quality obviously.
Thanks in advance.
Elephone
Re: Recording 'line out' virtually
Postby ef37a » Tue Oct 09, 2018 7:13 am
If you are running Win 7 there should be an option to use the On Board Soundcard usually Realtech or some such moniker.
You might have to do a bit of hacking around in the W7 Sounds menu (quite possible that OBS is turned off. Enable it for the duration) . What you need is to record "Stereo Mix".
Quality? This is all in the digital domain, no converters involved so good as it gets?
If you are running W10 I understand the facility has been removed and you will need some additional software. Someone here will know what.
Postby Mixedup » Tue Oct 09, 2018 12:42 pm
Voicemeeter Banana might do what you want?
Mixedup
Postby Elephone » Tue Oct 09, 2018 6:26 pm
Thanks!
Elephone
