Hello
Can an effects loop be added to any guitar amplifier? I'm guessing it's just an insert point between the pre-amp and the power-amp. I have a Supro Tremoverb (re-issue). Is it something a decent local tech could do?
I've been having all sorts of fun processing guitar with some Eurorack in the studio and now I want to take it out live. I don't really want to rely on going through a PA and in any case some of our songs need a cranked up amp sound. An effects loop seems like the correct solution.
Jim
• Page 1 of 1
jellyjim - Frequent Poster
Re: Can an effects loop be added to any guitar amplifier?
Depends on the amp, a hand wired on turret board or similar job should be no problem for an experienced valve tech (and fully reversible too), A modern PCB with SMCs probably not doable. I'd think the Supro would be worth getting a tech to have a look at but find someone who has experience of valve kit.
Sam Spoons - Jedi Poster
Sam Spoons wrote:Depends on the amp, a hand wired on turret board or similar job should be no problem for an experienced valve tech (and fully reversible too), A modern PCB with SMCs probably not doable. I'd think the Supro would be worth getting a tech to have a look at but find someone who has experience of valve kit.
Cool, thanks
The Supro marketing blurb suggested it was pretty much identical to the 60s original. Though I am a succor for such things so there could be a Raspberry PI in it running an amp sim for all I know!
I suspect the internal construction will be a fair bit different...
http://www.marshallforum.com/threads/current-supros-for-jimmy-page-led-zeppelin.96125/
Not entirely sure the pic is pukka but, if it is, the modern version will be much more difficult to mod successfully than the vintage. Still worth taking to a good valve amp tech though.
Ooh, nice find. Interesting photo
No Raspberry PI. Phew!
jellyjim wrote:I'm guessing it's just an insert point between the pre-amp and the power-amp.
It may be that simple, but probably isn't. There are many things to consider such as where in the signal path you want the insert point to be (before of after EQ, etc), and then what the nominal signal level is at that point in the circuit path and whether it is appropriate for an external FX pedal. There's also the impedances of the circuitry at that point to consider in terms of whether the preceding amp stage is suitable to drive an external loop, and whether the following stage is suitable to receive a signal from it with appropriate RF rejection etc. It may be necessary to add an additional output drive and/or input receive buffer stage(s) so sort out the signal levels, impedances, and RF protection.
Hugh Robjohns - Moderator
Hugh Robjohns wrote:jellyjim wrote:I'm guessing it's just an insert point between the pre-amp and the power-amp.
Never is, is it?
Somebody on another forum suggested using a remap instead - for my purposes, obviously it's not an alternative to an effects loop
electric guitar > doepfer a119 external input > eurorack processing > output at eurorack level > reamper > guitar amp
Jim
The return for the effects loop needs to come before the master volume control otherwise you won't be able to change volume once you've set up the gain structure of your external effects.
I had a Carlsbro guitar amp in the late 80s whose effects loops came after the master volume control which entered it pretty much useless.
BigRedX - Frequent Poster
RockinRollin' VampireMan
As Hugh says, it is not a trivial piece of design as evidenced by the fact that so many amp manufacturers have got it wrong for years!
There is also a valve amp topology that is problematic. If the preamp stage has an odd number of inverting stages this gets put to rights by feeding them onto the two grids of the Phase Inverter. Where then do you put the FX loop?
Regarding levels and impedances I commend folks to "Tube* preamps for guitar and bass" by Merlin Blencowe. He includes good circuit explanations and many circuits of FX loops.
*Do not worry my fellow Brits! He reverts to "valve" in the actual texts. A bit of pandering by the marketing men I shouldn't wonder? (at it everywhere!).
- ef37a
- Jedi Poster
Look into trying one of these Fryette Power Station PS2 devices... It does fx-loop and attenuation with any amp. I've played a plexi head with some strymon and it worked really nicely.
Just a thought as you dont have to modify the amp itself.
Humble Bee - Regular
Humble Bee wrote:Look into trying one of these Fryette Power Station PS2 devices... It does fx-loop and attenuation with any amp. I've played a plexi head with some strymon and it worked really nicely.
nice, thanks!
Back when I was a kid and didn't know any better, I would just reroute the signal from the top of the last volume pot and wire it to a TRS switching jack and send it back to the pot. It always worked fine. The joys of ignorant youth...
resistorman - Frequent Poster
future26.com
