Looking for small form-factor re-amp boxes
Postby Ben Asaro » Wed Oct 17, 2018 2:30 am
Pretty much what it says on the tin -- I am wondering if there is a small form-factor re-amp box commercially available. I currently have two Radial ProRMP passive re-amp boxes, which I LOVE -- but, they are not what I would call lightweight.
I need two of these boxes for use with my modular synth for rehearsals and gigging, so weight is a big factor. The issue I am having is that the signal coming out of my modular is too hot for outboard guitar pedals.
Ben Asaro
Re: Looking for small form-factor re-amp boxes
Postby Humble Bee » Wed Oct 17, 2018 4:12 am
Humble Bee
Postby forumuser913637 » Wed Oct 17, 2018 4:24 am
I haven't done an exhaustive search for lightweight reamp boxes or anything, but if you have a soldering iron, this kit is pretty small/light:
https://www.diyrecordingequipment.com/products/l2a
weigh: 6.9 ounces
length: 10.5 cm / 4"
width: 7 cm / 2.5"
Height: 4.5 cm / 1.5"
Ultra simple build if you care to do a little soldering.
forumuser913637
Postby ef37a » Wed Oct 17, 2018 8:48 am
Yes, the Orchid kit is excellent but if you are handy with a solder iron, a couple of these..
https://www.rapidonline.com/Vigortronix ... usQAvD_BwE
And a 10k pot and you are done. In fact that transformer is a bit TOO good! Google more and you could get cheaper.
Postby Mixedup » Wed Oct 17, 2018 9:18 am
There are quite a few to choose from, but I found DAV's DI/Reamp box to be decent and sturdy, yet lightweight.
Mixedup
Postby Sam Spoons » Wed Oct 17, 2018 9:52 am
ef37a wrote:Yes, the Orchid kit is excellent but if you are handy with a solder iron, a couple of these..
I built 8 of those into a box in 1976 to make a stagebox/multicore for an HH Stereo 12 mixer. No idea why but I guess the mics we had borrowed were unbalanced and, being borrowed we couldn't mod them. We were about to do a production of "Hair" (The NW amateur premier).
Postby Kayvon » Wed Oct 17, 2018 11:19 am
Assuming you can spare some space in your modular aren't there a few options in Eurorack?
I can't remember them all but a quick google showed up this Strymon module https://www.strymon.net/products/aa1/ and I think there's a mixer module thats aux sends work with pedals iirc.
That is of course assuming you can spare some space and you're using eurorack...
If not, perhaps look at some inline cable converters if you're really looking at saving space? I've looked into it before and they use miniature transformers, think Shure do some. Could be wrong but worth checking out.
Kayvon
Postby ef37a » Wed Oct 17, 2018 11:25 am
Kayvon wrote:Assuming you can spare some space in your modular aren't there a few options in Eurorack?
You can indeed find some very small, very cheap transformers but I don't know the levels involved? Unlike guitars, synths go down pretty low and so OP might need something a bit "hi fi"?
Postby jaminem » Wed Oct 17, 2018 3:16 pm
I have a Palmer Daccapo - its pretty dinky and light
jaminem
Postby Wonks » Wed Oct 17, 2018 3:20 pm
As Ben is in New York, he'd probably prefer units that can be sourced easily in the US.
Postby Ben Asaro » Wed Oct 17, 2018 4:27 pm
Wow, thanks for all of the great replies! I will parse through them this evening.
I am in NYC, but I am not opposed to ordering overseas if it's the right thing for the job!
Ben Asaro
Postby Ben Asaro » Wed Oct 17, 2018 5:01 pm
Forgot all about the AA.1!
Ben Asaro
Postby noblesavages » Wed Oct 17, 2018 9:28 pm
https://reverb.com/item/70186-saturnworks-reamp-pedal
This is a very light & sturdy box. Surprisingly affordable too. Same form factor as a regular guitar pedal. They're handmade in Davis, CA (near Sacramento). Totally passive too, so no need to bring a power supply.
noblesavages
Postby Ben Asaro » Thu Oct 18, 2018 12:26 am
noblesavages wrote:https://reverb.com/item/70186-saturnworks-reamp-pedal
That looks great, thanks!
Ben Asaro
Postby Ben Asaro » Fri Oct 19, 2018 8:25 pm
So, I totally forgot that my Doepfer Amplifier will also act as an attenuator! Going to try that. If it works, I can get a couple more for a fraction of the cost of these other solutions, and they take up only 4HP each.
Stay tuned!
Ben Asaro
