Rack Effects Build
Re: Rack Effects Build
Postby Luke W » Mon Oct 01, 2018 4:13 pm
Yep, that's the idea. It has 3 TRS outputs and a MIDI out which can send up to 3 channels of data out. The plan is to connect one TRS output to the SuperEgo, and the other two to the Ground Control, which then converts them to MIDI CC messages. That paired with the MIDI capability on the pedal itself will mean 5 separate parameters in the rack, and the SuperEgo on the board can all be controlled by the one pedal.
It's a pretty cool pedal, different curves can be assigned each output, as well as LFOs that can be synced to MIDI clock. Again, presets can be saved on the pedal itself and then recalled from the Ground Control. It really is going to be silly noise central :D
Luke W
Techie / Musician Of Sorts
Postby jaminem » Mon Oct 01, 2018 4:35 pm
Hey mate, that's an amazing build.
Just one question though...?
Where does the ADA MP1 go? is that the final piece of the puzzle, just waiting to go in?
Your post is entitled Rack Effects Build, which immediately says to me: 80's hair metal, which requires aforementioned ADA MP1.
Please advise...
jaminem
Postby Luke W » Mon Oct 01, 2018 8:17 pm
Cheers mate!
I'm hoping to find a deal with a suitable wig bundled in :thumbup:
Luke W
Postby jaminem » Tue Oct 02, 2018 9:14 am
Luke W wrote:Cheers mate!
Billy Duffy would be proud....
jaminem
Postby Hewesy » Tue Oct 23, 2018 3:11 pm
How are you getting on with the pedal build Luke? Looking forward to seeing this put together and on the 'board.
Hewesy
Hewesy
Postby Luke W » Tue Oct 23, 2018 4:19 pm
Not a great deal of progress recently I'm afraid, I've got it mostly wired up and managed to test it last weekend. All nice and quiet with everything working as intended, so it'll probably be together and waiting for a pedalboard before too long.
I'm about to go and demo some new studio monitors though (have a fairly good idea how that's going to end...), and after that my next bit of time off will be dedicated to designing and building a new desk and rack for the studio, and a mass rewire of everything. So for the moment, this project will be on hold. Not for that long hopefully, as I've only got a couple more bits to acquire and I'm keen to get it up and running.
Luke W
Postby Hewesy » Wed Oct 24, 2018 8:47 am
Fair play fella, just missing my fix of rack goodness that's all :-) Glad to hear the maiden test worked as hoped, looking forward to seeing it all done as you have time.
Planning on doing a revamp thread for the studio??
Hewesy
Hewesy
Postby Luke W » Wed Oct 24, 2018 9:50 am
I know the feeling! I may throw some bits up about the studio at some point, I actually built the panels in quite a while ago, but as usual I took a crazy amount of pictures while building and there were some fairly "interesting" cuts needed to make everything fit in the space so may be of interest for other people wanting to do some D.I.Y treatment. There's still more to make but with the room fairly well treated and some nice heavy stands in place I feel I can justify a proper set of monitors now.
Luke W
Postby Hewesy » Thu Oct 25, 2018 3:11 pm
Sounds like a plan mate, I'm sure a few of us would find it useful - and like you say helps justify the costs once you've got the room tamed/controlled.
Hewesy
Hewesy
